Avatar de wspeeckaert
wspeeckaert
10-09-2019
HELIX Terminal FORCE 5G connection
How can I force my Helix TV Terminals to remain on the 5G connection? I only have 2 terminals connected using WI-FI, all my other devices are connected using a different WI-Fi and wired connections using my own wireless router. Sometimes one of the terminals switches to a 2.4G connection. Can I force the gateway to always use the 5G connection for devices?
  • Hi wspeeckaert! The only way you could do that would be to access 10.0.0.1 ( username: admin /  password: password ) and to rename one of the WiFi networks. By having two different network names, you will be able to force your equipment on the 2.4 or 5 GHz. If needed, please reach our technical support through this link: < http://bit.ly/FB_Contact_Us >. Have a good day!
  • Avatar de CedrikS
    CedrikS
    Moderator - Solution Expert
