McFly
31-05-2017Samurai
Hi, I was wondering: is there a way to turn on/off call forwarding using the * + number combo ?
JenniferM
02-06-2017Moderator - Solution Expert
Hi McFly,
For an unconditional call forwarding, this is *21# to turn it on and #21# to turn it off. You have to dial **21*(destination number)# to program the number you want your calls forwarded to.
For a conditional call forwarding:
Call forward busy: *67# to turn it on, #67# to turn it off. To program the number, this is **67*(destination number)#
Call forward no reply: *61# to turn it on, #61# to turn it off. To program the number, this is **61*(destination number)#
Call forward not reachable (device turned off): *62# to turn it on, #62# to turn it off. To program the number, this is **62*(destination number)#
Thank you!
WindGhost
21-10-2019Initiate
I heard that Tech must 1st remove the Voicemail to get Conditional Forwarding enabled
is that true ?
If NOT
Is I can set voicemail only when I'm on a call (busy) & get call forwarding for when I'm not able to reply within 20 seconds rings ?
Thanks !
