Avatar de iosman123
iosman123
Hello,
I was wondering: is there a way to turn on/off call forwarding using the * + number combo ?
thanks
iosman
2 Réponses
  • Avatar de Anonymous
    Anonymous
    you have to use GSM code to manage the call forwarding...
    more info here http://www.geckobeach.com/cellular/secrets/gsmcodes.php
    Most of them will work on videotron.
    that said, if you want to completely desactivate your voicemail, you should call videotron to do it.
    • Avatar de guylogan
      guylogan
      Thanks for the information. It really helped me!
