mcrootay
8 years agoChevalier
Blocking incoming international calls
Is there a way to block all incoming international calls? With my G4 I used to be able to put in (for example) "+1 302" and that would block any call from that area code. I now have an Xperia XA1 Ult...
- 8 years ago
Hi!
We can certainly understand the inconvenience. Unfortunately, it does not seem possible to block a specific area code with this model. You would have to add the full telephone number. However, the phone call rejected will still be forwarded to the voicemail service. As an alternative, you might want to look for third-party call block apps that may offer additional features and can be downloaded from the Play Store app.
We also recommend that you add your phone number to the "National do not call list", which can help reduce the volume of calls. Additional information about unwanted calls and the registration to this list can be found here: http://crtc.gc.ca/eng/phone/telemarketing/
PatrickM
8 years agoModérateur - Expert solutions
Hi!
