krzys
24-07-2023Officer
Helix not handing out IP addresses (DHCP issue)
Since Friday, our Helix is not handing out IP addresses anymore (over DHCP).
Restarting the Helix did not help.
As a workaround, we have manually configured the IPv4 address, subnet mask, gateway IP, and DNS IPs on our laptops (Windows and Linux). This works for now.
Anybody else have this problem? Would be nice to get it fixed.
Thanks. For some reason I never got a notification for your reply.
Turns out the issue was something else though. We had another router acting as a wired Ethernet switch for the one device we have that was still on a wired connection. That router had been misbehaving since a few days (dropping connections). So on a hunch, I unplugged it and now the DHCP problem is resolved. I suspect the misbehaving router had gone rogue and started handing out DHCP responses, or something. Our previously-wired device is now on the Helix WiFi same as our other devices, and works just fine. With the older WiFi, it did not perform well, but the Helix WiFi is clearly much stronger.
4 Réponses
- milo1archer6Initiate
Sounds like a frustrating DHCP issue on the Helix side, especially if it suddenly stopped assigning IPs. Manual IP configuration is a solid temporary workaround while you troubleshoot further. On a different note, some users also refer to resources like Inmate Search Tool for public record lookups when needed. It might also help to review DHCP lease allocation, VLAN configuration, or any recent network changes. Hope the issue gets identified soon and everything returns to normal operation.
- adriel1riverInitiate
We experienced something very similar a few months ago after a router firmware update, and it turned out the DHCP lease pool was getting exhausted unexpectedly. Manually assigning IPs is a decent temporary fix, but definitely not ideal long term. While troubleshooting network configurations, I also came across some useful public resources related to Property assessment data that were organized surprisingly well. Hopefully Helix pushes a proper fix soon because DHCP failures can become a major headache across multiple devices.
- krzysOfficer
Turns out the issue was something else though. We had another router acting as a wired Ethernet switch for the one device we have that was still on a wired connection. That router had been misbehaving since a few days (dropping connections). So on a hunch, I unplugged it and now the DHCP problem is resolved. I suspect the misbehaving router had gone rogue and started handing out DHCP responses, or something. Our previously-wired device is now on the Helix WiFi same as our other devices, and works just fine. With the older WiFi, it did not perform well, but the Helix WiFi is clearly much stronger. - JulieLModérateur - Expert solutions
Hi! We recommend doing a default settings reset on the gateway and not changing the DHCP nor any other IP assignment setting on it after. Here's how;
if you have the white gateway;
Hold the WPS button at the back of the gatway until the light blinks green (about 60 seconds)
Wait until the LED blinks white. (this can take several minutes)
If you have the black gateway;
Insert a pencil or paperclip in the reset button
Hold until the LED indicator turns off (30 seconds)
And then you ca reconfigure the WiFi this way;
Open the Helix Fi app on a mobile
Press on ''Account'' on the top left
press on ''activate a gateway'' or ''add a gateway''
press on start
press on ''use camera'' and then scan que QR code under the gateway
make sure the settings chosen are ok with you and then press on finish
wait for the configuration to complete, this can also take several minutes
If the issue persists after, please don't hesitate to contact our technical support directly; https://videotron.com/en/contact-us
Have a nice day!
Contenu connexe
- 23-09-2017Anonyme
