Burialfaith
10-06-2026Initiate
Block incoming connections and ports - ZyXEL EMG2926-Q10A
Greetings, On the Videotron modem ZyXEL EMG2926-Q10A, does anyone know how to block all incoming traffic (from the internet to the modem) and how to lock all ports from incoming connections? When...
olivia55mix
27-07-2026Initiate
Hello,
You normally do not need to block every IP range manually (0.0.0.0–255.255.255.255). Instead, look for a firewall rule option such as WAN → LAN direction and set the action to Deny/Reject for unwanted inbound traffic. If the firmware does not expose direction settings, the router may already handle inbound blocking automatically.
Best Regards
