I have a new Helix router installed, and am currently running a Google Home network with 6 wi-fi access points and a 24-port wired switch in the DMZ of the router. My house is fully wired in CAT6 so I'd like to connect my Helix TV receivers by wire instead of over Wi-Fi. No problem to plug them directly into the router while it's running in default mode with the DMZ, but if I put it into bridge mode, should the TVs then still be connected to the router or should I connect them to the Google Home network switch instead?
