25-05-2018 03:53 AM
Solved! Go to Solution.
25-05-2018 10:18 AM
25-05-2018 11:29 AM
Hi @Branden514,
It's always possible to keep your rebated plan even when you switch phones. However, it's possible that if you want the latest devices at their full rebate a minimum monthly amount will be required like @Jeffg1 mentionned.
You can see all of our current mobile devices here.
In order to have the exact answer in regards to your account, I would suggest you contact us by phone or go to one of our stores: Contact us
Thank you for your understanding!
Vincent Quigley
Your Community Manager
27-05-2018 05:17 PM
You can keep it as long as it is above the amount to purchase a new phone.
I have kept mine (14 gig for 66$) and I have upgraded to the pixel 2xl for 300$. It is perfect.
