To add a bit on what @Anonyme started. (about closing apps when you leave them)
If you possess an android device, you could always active the developper options in the settings (see bellow) and then scroll through the dev options to activate the "don't keep activities - force quit every activity on exiting apps"
It does pretty much what it says
-----How to activate dev options-----
- Go to the settings menu, and scroll down to "About phone." Tap it.
- Scroll down to the bottom again, where you see "Build number."
- Tap it seven (7) times.
