Duudette
14-05-2017Chevalier
Going over my data plan
How do I know how much it will cost me when I bust my data plan?
Is there a way to block data if I realize I just busted?
I don't want to have a crazy bill at the end of the month.
What are my options!?!
I have a iPhone 7 btw. I don't know if that helps.
1 Réponse
- DominiqueChevalier
Hi Duudette,
First let me reassure you. Thanks to a law from the CRTC which have was implemented at Vidéotron, your data will be blocked if you spend for 50$ over your data plan in Canada or 100$ in Europe for exemple.
So you hopefully will not have a crazy bill.
But if you want, and usually it's a good idea, you can use an option in your iPhone to disable the data when you're not in Canada. Go in the settings, choose cellular network then options and deactivate the data Roaming.
And if you want you can look at the new option we have at Vidéotron : the daily traveller pass (http://www.videotron.com/residential/mobile/travel#/tab/cat3700012) it allows you to use your data like in Canada when you're in an other country.
I hope it will help you. Feel free to ask us if there's any question you have.
Have a nice day!
Dominique
