14-02-2024 09:31 PM - edited 14-02-2024 10:09 PM
Hi,
I'm trying to portforward a port to a server running linux. I know for a fact the device is connected to the internet via my helix router. However, it doesnt show up in the list of connected device on the app.
Therefore when i try to create a port forwarding rule my server doesnt show in the possible devices to forward to. I, very annoyingly, cant just enter the ip adress to port forward to. Is there a workaround to this badly designed system? Or is there a way to use an ip adress when setting up port forwarding?
Edit:
The server doesnt use an IPv6 adress.
I can ping the gateway from the server without any packet loss
16-02-2024 01:48 PM
Good afternoon tyrede, we would like to verify this with you, we will write to you in private. Thank you!
