Did you also reconnect your phone to the 2.4Ghz network? Your Phone has to be using the same band as the device. With Helix, both 2.4Ghz and 5Ghz use the same SSID so phones only show one network name, so you have to rename the 2.4Ghz so that your devices can detect it as a separate network, you then have to connect your phone to the new 2.4Ghz band so that both devices are on the same network.
