gordynorth
17-07-2017Initiate
Does Videotron have a wireless home phone solution?
Hello I am a Videotron customer for home phone. My wiring in the home has become defective and causes static on the line.
Other operators are able to offer a home phone using a wireless conection. This would enable me to have the wireless access near the home phone and bypass the bad wiring.
I am hoping that the wireless home phone costs less than replacing the phone.
Does Videotron have a wireless home phone.
There is no wireless phone solution available currently
What you could also do is plug your main phone base and plug it directly in the telephone 1 or 1/2 outlook in the back of the modem, should already be a phone wire in there so simply remove and put phone there.
It will bypass the wall lines and make it so that set on phones (main base + all extra handhelds) will work.
