TheDuclos's avatar
TheDuclos
09-01-2021
Helix TV Terminal work if it’s wire to my inquiries switch if put my helix Fi 2 in bridge mode
Helix TV Terminal work if it’s wired to my ubiquity Switch Pro 24 PoE if I put my helix Fi 2 gateway in bridge mode. Helix Fi will connected to ubiquity Dream machine that will connect to switch.
  • Hi! We do not recommend connecting any powered ethernet to the Helix TV Terminal as this -may- damage the device. This being said, if the power is removed, everything should work as intended. As long as the Helix Fi gateway is working and acting as the modem.
    Hope this helps!
    Hope this helps!
    • viaujoc's avatar
      viaujoc
      Now with the second generation of Helix Fi Gateway 2 and TV Terminal 2, can any of those be powered using PoE?
