mcrootay
11-10-2018Chevalier
- ApprouvéAnonymous11-10-2018
ralvy007
20-10-2018Initiate
Hi sorry for my english but yes i have a zte wf721 and it works with a videotron sim card but the sim card in the device is big so i bought a nano-sim adapter turns any nano sim card to fit anny device look for sim card adapter on amazon and my zte came from rogers and i unlocked it with a very simple way but yours is allready unlocked.
