mcrootay
11-10-2018Chevalier
- Anonymous11-10-2018
mcrootay
12-10-2018Chevalier
I would guess that my videotron sim is LTE, as the phone says as much at this moment...I got it Fall 2017.
So then based on your statements my options for using this adapter are to find a cheap plan on a compatible network (ZTE's website says Fido, Rogers, Koodo and Virgin). I'll check what those guys offer....
Thanks again!
mcrootay
12-10-2018Chevalier
Interesting development....I tried one of Videotron's Fizz sims in the ZTE adapter...and it worked
- Anonymous13-10-2018
mcrootay wrote:
Interesting development....I tried one of Videotron's Fizz sims in the ZTE adapter...and it workedMaybe you got one of the newer sim with Fizz... those compatible with VoLTE.
older LTE sim from Vidéotron are not necessarily compatible with VoLTE thus might not support the same fallback to Rogers frequencies/bands.
