mcrootay
11-10-2018Chevalier
- Anonymous11-10-2018
Anonymous
12-10-2018if one of these providers ever offered the same ZTE device, they might block it (based on the IMEI of the device) from their regulard plans.
mcrootay
12-10-2018Chevalier
Dude you're killing me :smileyvery-happy:
