mcrootay
11-10-2018Chevalier
- Anonyme11-10-2018
mcrootay
12-10-2018Chevalier
I would guess that my videotron sim is LTE, as the phone says as much at this moment...I got it Fall 2017.
So then based on your statements my options for using this adapter are to find a cheap plan on a compatible network (ZTE's website says Fido, Rogers, Koodo and Virgin). I'll check what those guys offer....
Thanks again!
12-10-2018if one of these providers ever offered the same ZTE device, they might block it (based on the IMEI of the device) from their regulard plans.
- mcrootay12-10-2018Chevalier
Dude you're killing me :smileyvery-happy:
