mcrootay
11-10-2018Chevalier
- Anonyme11-10-2018
11-10-2018Not applicable
mcrootay
12-10-2018Chevalier
Thanks for your reply zadigre, that was very helpful and I think testing I did last night confirmed what you wrote....I unlocked the device and it worked with a Telus sim, but did not want to work with my Videotron sim.
- Anonyme12-10-2018Not applicable
mcrootay wrote:Thanks for your reply zadigre, that was very helpful and I think testing I did last night confirmed what you wrote....I unlocked the device and it worked with a Telus sim, but did not want to work with my Videotron sim.
do you have one of the newer LTE videotron sim or it's one that has access to 3G only?
if 3G only, I believe you absolutely need a device that has support for the AWS band.
If LTE, again technically, it should connect to 850/1900MHz Rogers frequencies on 3G since essentially this is need for a fallback from the LTE network (for calls non VoLTE device or when outside of LTE coverage).
But again, this is just a guess... this is the way that it's supposed to work with a "real" cellphone...- mcrootay12-10-2018Chevalier
I would guess that my videotron sim is LTE, as the phone says as much at this moment...I got it Fall 2017.
So then based on your statements my options for using this adapter are to find a cheap plan on a compatible network (ZTE's website says Fido, Rogers, Koodo and Virgin). I'll check what those guys offer....
Thanks again!
if one of these providers ever offered the same ZTE device, they might block it (based on the IMEI of the device) from their regulard plans.
