Avatar de mwronsky
mwronsky
12-11-2017
Roaming on CDMA network in USA (and elsewhere)
Can anyone tell me if there Videotron phone roams on Verizon CDMA when in the USA? I'm thinking of buying an iPhone X from Apple but I would prefer the Qualcomm version with CDMA coverage?
Thanks,
Mitch
  • Hello mwronsky!
    After a few verifications, it does not appear that we have a roaming partnership with Verizon in the US. We do, however, have roaming deals with several other providers, including T-Mobile and AT&T.
    If your question concerns CDMA (2G) coverage, fewer and fewer providers support this older technology so we cannot say for certain that it will be supported by the local providers. If your question is about WCDMA (3G/4G) coverage, then the answer is: Yes, you will be able to roam in the US with a Videotron SIM card and an iPhone X as long as there is coverage from any provider we have a roaming deal with.
    You may check roaming coverage per country and device model here : https://videotron.com/residential/b/mobile/travel/N-1r4y30r .
    Have a great evening!
1 Réponse
  • Avatar de JFrancoisD
    JFrancoisD
    Moderator - Solution Expert
    Hello mwronsky!
