Avatar de iosman123
iosman123
Hello,   I was wondering: is there a way to turn on/off call forwarding using the * + number combo ?   thanks iosman
  • Avatar de Anonyme
    22-07-2019
    you have to use GSM code to manage the call forwarding...
    more info here http://www.geckobeach.com/cellular/secrets/gsmcodes.php
    Most of them will work on videotron.
    that said, if you want to completely desactivate your voicemail, you should call videotron to do it.
