richardbuffet
05-09-2017Initiate
When I roam on to a partner network (usually partner1), i sometimes get a "x" on my signal bar. it works for text and phone calls, but not for data. I have to restart my phone 5-6 times before the "x...
wrapper
25-01-2019Squire
relatively new subscriber here. It worked going to Toronto, no problem. Coming back on the 401, I could make calls but no Internet.
Called Tech, no help. Opened a ticket.
I turned off Cellular -> network selection from Automatic and select Prtn 1 no good. Prtn 2, it worked.
Your milage will vary.
- Anonyme28-01-2019Not applicable
wrapper wrote:relatively new subscriber here. It worked going to Toronto, no problem. Coming back on the 401, I could make calls but no Internet.
I went to Toronto end of last week... I have two colleagues that are on Rogers/Fido... even for them, coverage on the 401 is not very good... so it was not better for me with Videotron.
The main Canadian roaming partner is Rogers... you phone will stay on Rogers as long as signal is present even when signal is not very powerfull or is Edge only. So this means that until Rogers adds some tower in this region, signal will be problematic.
