LTE on Videotron Calls
- Anonyme15-09-2018
MnJ wrote:
Thanks for the reply, I do have a compatible iPhone but it was a byod. I would think that it would be a network related issue. No?If you have an iPhone 7 or better, you can get VoLTE on your iPhone even if it’s byod.
you first need to have a compatible sim... compatible sim came in a yellow card and it has « nfc » on the card.
also, contact customer service to get VoLTE added to your account.
Videotron will not allow VoLTE for byod on Android devices... but they will do it for iPhone since it’s the same hardware and software for all iPhone sold in Canada.
good evening,
you need to have a compatible device for that, like an iPhone or a Galaxy S7-8-9. And if I am not mistaken, the device needs to be from Vidéotron.
- Anonyme15-09-2018Not applicable
- macadacious27-09-2018InitiateSo for androids that are byod they wont allow volte? So that means i have to get rid of my android and get one of their android phones? ..
- Anonyme27-09-2018Not applicable
macadacious wrote:
So for androids that are byod they wont allow volte? So that means i have to get rid of my android and get one of their android phones? ..That is mostly true...
but if you have a Samsung phone, you can change the CSC to that VTR setting.
if you manage to get the compatible sim and also get the VoLTE option added to your account, it should work.
- pastisfmontreal14-09-2018Super utilisateur
You will have to see with support, as it is not a Vidéotron device.
good luck.
