MnJ
14-09-2018Initiate
LTE on Videotron Calls
Hey all, New to Videotron here in Ottawa and was wondering when making calls are they on LTE? I made a call today and noticed it was in 3G. Aren't call able to be in LTE as well as data? Jus...
- Anonyme15-09-2018
MnJ wrote:
Thanks for the reply, I do have a compatible iPhone but it was a byod. I would think that it would be a network related issue. No?If you have an iPhone 7 or better, you can get VoLTE on your iPhone even if it’s byod.
you first need to have a compatible sim... compatible sim came in a yellow card and it has « nfc » on the card.
also, contact customer service to get VoLTE added to your account.
Videotron will not allow VoLTE for byod on Android devices... but they will do it for iPhone since it’s the same hardware and software for all iPhone sold in Canada.
pastisfmontreal
14-09-2018Super utilisateur
good evening,
you need to have a compatible device for that, like an iPhone or a Galaxy S7-8-9. And if I am not mistaken, the device needs to be from Vidéotron.
- MnJ14-09-2018InitiateThanks for the reply, I do have a compatible iPhone but it was a byod. I would think that it would be a network related issue. No?
- Anonyme15-09-2018Not applicable
- macadacious27-09-2018InitiateSo for androids that are byod they wont allow volte? So that means i have to get rid of my android and get one of their android phones? ..
- pastisfmontreal14-09-2018Super utilisateur
You will have to see with support, as it is not a Vidéotron device.
good luck.
