I received my invoice where I am being charged QST of 9.975%
My billing address is Ontario so it should be 8%.
Can someone clarify on this?
Solved! Go to Solution.
@thorntcl wrote:I received my invoice where I am being charged QST of 9.975%My billing address is Ontario so it should be 8%. Can someone clarify on this?
Hello @thorntcl
You simply need te call them. They will be able to make the change for you.
Thank you Nicaii -- Yes, I called them and they corrected the invoices and my region so it should not happen in the future.
Thank for the clarification!
never-displayed
