Avatar de JustCurious
JustCurious
10-17-2022
Hotspot capabilities?
I'm shopping for mobile CAN-US plans.  Bell has one such plan and shows "Hotspot capabilities" as a feature.  Do the Videotron CAN-US plans offer this feature?  If so, where can I find out about the details?  For example, are hotspot speeds capped in any way?
  • Hi.
    You can use your mobile phone as a hotspot even in the US. The speed will remain the same as the speed you get on LTE (or any data network available in the area). Your hotspot will use your data, so you'll simply need to make sure that you're aware of your monthly data allowance.
  • I'm especially stayed aware of the article and I will get many benefits from it. Subsequently, thank you for sharing it.That is what I was looking for, what information, present here at this site. www.cfahome.com
  • Avatar de CharlesR
    CharlesR
    Moderator - Solution Expert
    Hi.
