This sounds like an issue with the VoLTE option. For the Voice-over-LTE option to work , you need not only to have your cellphone compatible and certified with the VoLTE option, but for your SIM card to be compatible and have the option provisionned onto your SIM card.
Because the 3G network is still available for a little over a year in Québec or in the rest of Canada, you wouldn't notice any problem until you are unable to reach Canadian cellphone towers. Similarly, if it was a problem with service reception in general, your text services and mobile data wouldn't work.
While unlikely, it is possible that your SIM card is not compatible with the VoLTE option, it is very unlikely. The most probable answer to this problem is that it might not be provisioned to your SIM card. A quick callor chat with our technical support can help shed some light on the situation. If the SIM card isn't provisioned with the correct options, we'll be happy to rectify that mistake.
Hope to see you soon! 😸 ","board":{"__ref":"Forum:board:mobilephone-english"},"conversation":{"__ref":"Conversation:conversation:40995"},"author":{"__typename":"User","login":"JoéCL"},"postTime":"2023-05-04T23:01:32.217-04:00","kudosSumWeight":0}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8b3w1fDE2OjAsNDE6MXwy","node":{"__typename":"ForumReplyMessage","uid":41372,"body":"
I had a chat in early May with support. That concluded that I needed to have my SIM card upgraded once I returned to Ottawa. Supposedly I had received emails notifying my that I needed to upgrade with the changes to 5G in the states....but could not find any record of that.
Anyway, I did go to a kiosk in Ottawa upon my return and the clerk remarked that yes indeed my SIM card was \"old\". That was in early May.
I am now visiting again in New Jersey and travelling in the same region. Besides one halting phone call I was able to make upon landing at the airport my phone is behaving exactly as described in my original post.
This is beyond frustrating. Despite my plan covering unlimited calling in Canada/US, out of desperation today I thought maybe there was a billing/account issue and if I just paid for a daily travel pass I'd be able to call out. That did not work either, so probably bought that for nothing.
Below are two maps from CellMapper.net. I am located in the middle of this area. The first map is LTE-ATT towers, signal. The second is LTE-T-Mobile. When using automatic network selection my phone always selects AT&T. When I manually select a nearby T-Mobile it does not help.
AT&T
T-Mobile
","board":{"__ref":"Forum:board:mobilephone-english"},"conversation":{"__ref":"Conversation:conversation:40995"},"author":{"__typename":"User","login":"rpcanam"},"postTime":"2023-06-03T10:59:59.702-04:00","kudosSumWeight":0}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8b3w1fDE2OjAsNDE6MXwz","node":{"__typename":"ForumReplyMessage","uid":41374,"body":"This is \"Carrier Settings version\" : videotron_ca-43000000050.58 2022-12-08
Hi! It might still be an issue with the VoLTE option which is now necessary for travelling to the United-States. We invite you to contact our technical support directly for this; https://videotron.com/en/contact-us Thank you
It seems like you're facing calling-related issues in Ocean County, New Jersey, despite having a mobile plan with unlimited voice/data in the US. While your phone image resize works well in other regions, you're experiencing difficulties with calls when visiting family there. Despite previous attempts to manually select networks, the issue persists. You've already taken several troubleshooting steps, including updates and resets.
"}},"componentScriptGroups({\"componentId\":\"custom.widget.Utility_Nav_FR\"})":{"__typename":"ComponentScriptGroups","scriptGroups":{"__typename":"ComponentScriptGroupsDefinition","afterInteractive":{"__typename":"PageScriptGroupDefinition","group":"AFTER_INTERACTIVE","scriptIds":[]},"lazyOnLoad":{"__typename":"PageScriptGroupDefinition","group":"LAZY_ON_LOAD","scriptIds":[]}},"componentScripts":[]},"cachedText({\"lastModified\":\"1742218158000\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/customComponent/CustomComponent\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/customComponent/CustomComponent-1742218158000"}],"cachedText({\"lastModified\":\"1742218158000\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/community/NavbarDropdownToggle\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/community/NavbarDropdownToggle-1742218158000"}],"cachedText({\"lastModified\":\"1742218158000\",\"locale\":\"fr-FR\",\"namespaces\":[\"shared/client/components/users/UserAvatar\"]})":[{"__ref":"CachedAsset:text:fr_FR-shared/client/components/users/UserAvatar-1742218158000"}],"cachedText({\"lastModified\":\"1742218158000\",\"locale\":\"fr-FR\",\"namespaces\":[\"shared/client/components/ranks/UserRankLabel\"]})":[{"__ref":"CachedAsset:text:fr_FR-shared/client/components/ranks/UserRankLabel-1742218158000"}],"cachedText({\"lastModified\":\"1742218158000\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/MessageListMenu\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/MessageListMenu-1742218158000"}],"cachedText({\"lastModified\":\"1742218158000\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/AcceptedSolutionButton\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/AcceptedSolutionButton-1742218158000"}],"cachedText({\"lastModified\":\"1742218158000\",\"locale\":\"fr-FR\",\"namespaces\":[\"shared/client/components/common/Pager/PagerLoadMore\"]})":[{"__ref":"CachedAsset:text:fr_FR-shared/client/components/common/Pager/PagerLoadMore-1742218158000"}],"cachedText({\"lastModified\":\"1742218158000\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/MessageView/MessageViewInline\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/MessageView/MessageViewInline-1742218158000"}],"message({\"id\":\"message:42191\"})":{"__ref":"ForumReplyMessage:message:42191"},"message({\"id\":\"message:40997\"})":{"__ref":"ForumReplyMessage:message:40997"},"message({\"id\":\"message:41372\"})":{"__ref":"ForumReplyMessage:message:41372"},"message({\"id\":\"message:41374\"})":{"__ref":"ForumReplyMessage:message:41374"},"message({\"id\":\"message:41482\"})":{"__ref":"ForumReplyMessage:message:41482"},"message({\"id\":\"message:42584\"})":{"__ref":"ForumReplyMessage:message:42584"},"cachedText({\"lastModified\":\"1742218158000\",\"locale\":\"fr-FR\",\"namespaces\":[\"shared/client/components/nodes/NodeIcon\"]})":[{"__ref":"CachedAsset:text:fr_FR-shared/client/components/nodes/NodeIcon-1742218158000"}]},"Theme:customTheme1":{"__typename":"Theme","id":"customTheme1"},"User:user:-1":{"__typename":"User","id":"user:-1","uid":-1,"login":"Anonymous","email":"","avatar":null,"rank":null,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":"ANONYMOUS","registrationTime":null,"confirmEmailStatus":false,"registrationAccessLevel":"VIEW","ssoRegistrationFields":[]},"ssoId":null,"profileSettings":{"__typename":"ProfileSettings","dateDisplayStyle":{"__typename":"InheritableStringSettingWithPossibleValues","key":"layout.friendly_dates_enabled","value":"false","localValue":"true","possibleValues":["true","false"]},"dateDisplayFormat":{"__typename":"InheritableStringSetting","key":"layout.format_pattern_date","value":"dd-MM-yyyy","localValue":"MM-dd-yyyy"},"language":{"__typename":"InheritableStringSettingWithPossibleValues","key":"profile.language","value":"fr-FR","localValue":null,"possibleValues":["en-US","fr-FR"]},"repliesSortOrder":{"__typename":"InheritableStringSettingWithPossibleValues","key":"config.user_replies_sort_order","value":"DEFAULT","localValue":"DEFAULT","possibleValues":["DEFAULT","LIKES","PUBLISH_TIME","REVERSE_PUBLISH_TIME"]}},"deleted":false},"CachedAsset:pages-1746520795442":{"__typename":"CachedAsset","id":"pages-1746520795442","value":[{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"BlogViewAllPostsPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId/all-posts/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"CasePortalPage","type":"CASE_PORTAL","urlPath":"/caseportal","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"CreateGroupHubPage","type":"GROUP_HUB","urlPath":"/groups/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"CaseViewPage","type":"CASE_DETAILS","urlPath":"/case/:caseId/:caseNumber","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"InboxPage","type":"COMMUNITY","urlPath":"/inbox","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"HelpFAQPage","type":"COMMUNITY","urlPath":"/help","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"IdeaMessagePage","type":"IDEA_POST","urlPath":"/idea/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"IdeaViewAllIdeasPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/all-ideas/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"LoginPage","type":"USER","urlPath":"/signin","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"BlogPostPage","type":"BLOG","urlPath":"/category/:categoryId/blogs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"ThemeEditorPage","type":"COMMUNITY","urlPath":"/designer/themes","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"TkbViewAllArticlesPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId/all-articles/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"OccasionEditPage","type":"EVENT","urlPath":"/event/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"OAuthAuthorizationAllowPage","type":"USER","urlPath":"/auth/authorize/allow","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"PageEditorPage","type":"COMMUNITY","urlPath":"/designer/pages","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"PostPage","type":"COMMUNITY","urlPath":"/category/:categoryId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"ForumBoardPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"TkbBoardPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"EventPostPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"UserBadgesPage","type":"COMMUNITY","urlPath":"/users/:login/:userId/badges","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"GroupHubMembershipAction","type":"GROUP_HUB","urlPath":"/membership/join/:nodeId/:membershipType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"MaintenancePage","type":"COMMUNITY","urlPath":"/maintenance","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"IdeaReplyPage","type":"IDEA_REPLY","urlPath":"/idea/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"UserSettingsPage","type":"USER","urlPath":"/mysettings/:userSettingsTab","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"GroupHubsPage","type":"GROUP_HUB","urlPath":"/groups","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"ForumPostPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"OccasionRsvpActionPage","type":"OCCASION","urlPath":"/event/:boardId/:messageSubject/:messageId/rsvp/:responseType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"VerifyUserEmailPage","type":"USER","urlPath":"/verifyemail/:userId/:verifyEmailToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"AllOccasionsPage","type":"OCCASION","urlPath":"/category/:categoryId/events/:boardId/all-events/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"EventBoardPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"TkbReplyPage","type":"TKB_REPLY","urlPath":"/kb/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"IdeaBoardPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"CommunityGuideLinesPage","type":"COMMUNITY","urlPath":"/communityguidelines","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"CaseCreatePage","type":"SALESFORCE_CASE_CREATION","urlPath":"/caseportal/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"TkbEditPage","type":"TKB","urlPath":"/kb/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"ForgotPasswordPage","type":"USER","urlPath":"/forgotpassword","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"IdeaEditPage","type":"IDEA","urlPath":"/idea/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"TagPage","type":"COMMUNITY","urlPath":"/tag/:tagName","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"BlogBoardPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"OccasionMessagePage","type":"OCCASION_TOPIC","urlPath":"/event/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"ManageContentPage","type":"COMMUNITY","urlPath":"/managecontent","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"ClosedMembershipNodeNonMembersPage","type":"GROUP_HUB","urlPath":"/closedgroup/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"CommunityPage","type":"COMMUNITY","urlPath":"/","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"ForumMessagePage","type":"FORUM_TOPIC","urlPath":"/discussions/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"IdeaPostPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"BlogMessagePage","type":"BLOG_ARTICLE","urlPath":"/blog/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"RegistrationPage","type":"USER","urlPath":"/register","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"EditGroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"ForumEditPage","type":"FORUM","urlPath":"/discussions/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"ResetPasswordPage","type":"USER","urlPath":"/resetpassword/:userId/:resetPasswordToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"TkbMessagePage","type":"TKB_ARTICLE","urlPath":"/kb/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"BlogEditPage","type":"BLOG","urlPath":"/blog/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"ManageUsersPage","type":"USER","urlPath":"/users/manage/:tab?/:manageUsersTab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"ForumReplyPage","type":"FORUM_REPLY","urlPath":"/discussions/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"PrivacyPolicyPage","type":"COMMUNITY","urlPath":"/privacypolicy","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"NotificationPage","type":"COMMUNITY","urlPath":"/notifications","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"UserPage","type":"USER","urlPath":"/users/:login/:userId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"HealthCheckPage","type":"COMMUNITY","urlPath":"/health","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"OccasionReplyPage","type":"OCCASION_REPLY","urlPath":"/event/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"ManageMembersPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/manage/:tab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"SearchResultsPage","type":"COMMUNITY","urlPath":"/search","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"BlogReplyPage","type":"BLOG_REPLY","urlPath":"/blog/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"GroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"TermsOfServicePage","type":"COMMUNITY","urlPath":"/termsofservice","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"CategoryPage","type":"CATEGORY","urlPath":"/category/:categoryId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"ForumViewAllTopicsPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/all-topics/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"TkbPostPage","type":"TKB","urlPath":"/category/:categoryId/kbs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1746520795442,"localOverride":null,"page":{"id":"GroupHubPostPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"}],"localOverride":false},"CachedAsset:text:fr_FR-components/context/AppContext/AppContextProvider-0":{"__typename":"CachedAsset","id":"text:fr_FR-components/context/AppContext/AppContextProvider-0","value":{"noCommunity":"Impossible de trouver la communauté","noUser":"Impossible de trouver l'utilisateur actuel","noNode":"Impossible de trouver le nœud avec l'identifiant {nodeId}","noMessage":"Impossible de trouver le message avec l'identifiant {messageId}","userBanned":"Nous sommes désolés, mais vous avez été banni de l'utilisation de ce site.","userBannedReason":"Vous avez été banni pour la raison suivante : {reason}"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/common/Loading/LoadingDot-0":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/common/Loading/LoadingDot-0","value":{"title":"Chargement..."},"localOverride":false},"Rank:rank:19":{"__typename":"Rank","id":"rank:19","position":37,"name":"Initiate","color":null,"icon":null,"rankStyle":"TEXT"},"User:user:31331":{"__typename":"User","id":"user:31331","uid":31331,"login":"rpcanam","deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-5.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"email":"","messagesCount":3,"biography":null,"topicsCount":1,"kudosReceivedCount":0,"kudosGivenCount":0,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2023-05-04T22:46:25.108-04:00","confirmEmailStatus":null},"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:31331"},"Category:category:en":{"__typename":"Category","id":"category:en","entityType":"CATEGORY","displayId":"en","nodeType":"category","depth":1,"title":"English","shortTitle":"English","parent":{"__ref":"Category:category:top"}},"Category:category:top":{"__typename":"Category","id":"category:top","entityType":"CATEGORY","displayId":"top","nodeType":"category","depth":0,"title":"Top","shortTitle":"Top"},"Forum:board:mobilephone-english":{"__typename":"Forum","id":"board:mobilephone-english","entityType":"FORUM","displayId":"mobilephone-english","nodeType":"board","depth":2,"conversationStyle":"FORUM","repliesProperties":{"__typename":"RepliesProperties","sortOrder":"LIKES","repliesFormat":"threaded"},"tagProperties":{"__typename":"TagNodeProperties","tagsEnabled":{"__typename":"PolicyResult","failureReason":null}},"requireTags":false,"tagType":"PRESET_ONLY","description":"Find all the answers to your mobile questions: devices, networks, plans, features, apps . . . it’s all here!","title":"Mobility","shortTitle":"Mobility","parent":{"__ref":"Category:category:en"},"ancestors":{"__typename":"CoreNodeConnection","edges":[{"__typename":"CoreNodeEdge","node":{"__ref":"Community:community:ogevo67675"}},{"__typename":"CoreNodeEdge","node":{"__ref":"Category:category:en"}}]},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"theme":{"__ref":"Theme:customTheme1"},"boardPolicies":{"__typename":"BoardPolicies","canViewSpamDashBoard":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.access_spam_quarantine.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.access_spam_quarantine.allowed.accessDenied","args":[]}},"canArchiveMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.content_archivals.enable_content_archival_settings.accessDenied","key":"error.lithium.policies.content_archivals.enable_content_archival_settings.accessDenied","args":[]}},"canPublishArticleOnCreate":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","key":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","args":[]}}},"eventPath":"category:en/community:ogevo67675board:mobilephone-english/"},"ForumTopicMessage:message:40995":{"__typename":"ForumTopicMessage","uid":40995,"subject":"Can not make or receive phone calls from an specific locale in United States","id":"message:40995","revisionNum":1,"repliesCount":8,"author":{"__ref":"User:user:31331"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:mobilephone-english"},"conversation":{"__ref":"Conversation:conversation:40995"},"readOnly":false,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:40995"},"body":"
My mobile plan includes unlimited voice/data in US.
This is a location specific issue for me.
I can use my ~3 year old Pixel 6 in my home region of Ottawa, Ontario for calls/text. It works well when travel to Montreal and Vancouver as well. But when I travel to Ocean County, New Jersey to visit family, calling in and out works erratically.
* calls in go immediately to voicemail
* calls out end immediately with \"call ended\" message, including trying to check voicemail
* text/SMS still works
* data still works
* home carrier is Videotron, visiting network defaults to AT&T
In past visits I've been able to get *sporadic* calling-capable connections by turning off Automatically Select Network and manually selecting a T-Mobile or Verizon connection. These may work for 1 call, sometimes more, before I have to select a different one.
That describes how I got through a few stressful visits last year. Now none of my past fiddling does any good.
My phone is updated as of this AM, I've rebooted multiple times, reset to factory for Wi-Fi, BT, cellular, and cleared the phone app cache. Preferred Network Type = LTE, Voice Over LTE is on.
The entire state of NJ is supposedly covered in the online Partner Network coverage map, but no joy.
Is there a known solution to this issue or troubleshooting tips?
","body@stringLength":"1625","rawBody":"
* data still works
","kudosSumWeight":0,"postTime":"2023-05-04T22:44:47.689-04:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:40995_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":4829},"visibilityScope":"PUBLIC","canonicalUrl":null,"seoTitle":null,"seoDescription":null,"isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"archivalData":null,"searchSnippet":"My mobile plan includes unlimited voice/data in US. This is a location specific issue for me. I can use my ~3 year old Pixel 6 in my home region of Ottawa, Ontario for calls/t...","replies":{"__typename":"MessageConnection","edges":[{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8b3wxMHwxNjowLDQxOjF8MQ","node":{"__ref":"ForumReplyMessage:message:40997"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8b3wxMHwxNjowLDQxOjF8Mg","node":{"__ref":"ForumReplyMessage:message:41374"}},{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8b3wxMHwxNjowLDQxOjF8Mw","node":{"__ref":"ForumReplyMessage:message:42191"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"Conversation:conversation:40995":{"__typename":"Conversation","id":"conversation:40995","solved":false,"topic":{"__ref":"ForumTopicMessage:message:40995"},"lastPostingActivityTime":"2023-09-13T08:11:41.778-04:00","lastPostTime":"2023-09-13T08:11:41.778-04:00","unreadReplyCount":8,"isSubscribed":false},"ModerationData:moderation_data:40995":{"__typename":"ModerationData","id":"moderation_data:40995","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:40995_1":{"__typename":"Revision","id":"revision:40995_1","lastEditTime":"2023-05-04T22:44:47.689-04:00"},"CachedAsset:theme:customTheme1-1746520795039":{"__typename":"CachedAsset","id":"theme:customTheme1-1746520795039","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"50%","collections":["default"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"Favicon-1730465696192.png","imageLastModified":"1730465698198","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"logo-videotron_header2fr-1730818064436.png","imageLastModified":"1730818067042","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1300px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_BROWSER","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"3px","borderRadius":"3px","borderRadiusLg":"5px","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"12px","paddingXLg":"16px","paddingXHero":"60px","fontStyle":"NORMAL","fontWeight":"700","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-body-bg)","primaryTextHoverColor":"var(--lia-bs-body-bg)","primaryTextActiveColor":"var(--lia-bs-body-bg)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-primary)","secondaryTextHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.9))","secondaryBgColor":"#FDD200","secondaryBgHoverColor":"hsl(49.80000000000001, 100%, 47.6%)","secondaryBgActiveColor":"hsl(49.80000000000001, 100%, 45.6%)","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-gray-900)","tertiaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-danger)","destructiveTextHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.95))","destructiveTextActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.9))","destructiveBgColor":"var(--lia-bs-gray-200)","destructiveBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","destructiveBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"LIGHT","sideContent":"NONE","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08)","sm":"0","md":"0","lg":"0","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"var(--lia-bs-link-color)","defaultMessageLinkDecoration":"underline","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","defaultMessageFontFamily":"var(--lia-bs-font-family-base)","forumColor":"#000000","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#24AD72","blogColor":"#000000","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#E06643","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#FF8000","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#D13A1F","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#FFDE45","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#000000","secondary":"#333333","bodyText":"#575754","bodyBg":"#FFFFFF","info":"#FFD200","success":"#24AD72","warning":"#DA8000","danger":"#C14D00","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#FDD200","#C14D00"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":{"link":{"color":"#0069D4","hoverColor":"#0061c2","decoration":"none","hoverDecoration":"underline","__typename":"EmailLinkSettings"},"border":{"color":"#e4e4e4","__typename":"EmailBorderSettings"},"buttons":{"borderRadiusLg":"5px","paddingXLg":"16px","paddingYLg":"7px","fontWeight":"700","primaryTextColor":"#ffffff","primaryTextHoverColor":"#ffffff","primaryBgColor":"#0069D4","primaryBgHoverColor":"#005cb8","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","__typename":"EmailButtonsSettings"},"panel":{"borderRadius":"5px","borderColor":"#e4e4e4","__typename":"EmailPanelSettings"},"__typename":"EmailThemeSettings"},"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Blender Pro Book","fontStyle":"NORMAL","fontWeight":"500","h1FontSize":"52px","h2FontSize":"36px","h3FontSize":"24px","h4FontSize":"22px","h5FontSize":"16px","h6FontSize":"14px","lineHeight":"1.3","subHeaderFontSize":"11px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":"10px","size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"var(--lia-bs-border-radius-sm)","borderRadius":"var(--lia-bs-border-radius)","borderRadiusLg":"var(--lia-bs-border-radius-lg)","formTextMarginTop":"4px","textAreaBorderRadius":"var(--lia-bs-border-radius)","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-black)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":"","imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"40px","defaultMessageHeaderMarginBottom":"20px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"30px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"40px","specialMessageHeaderMarginBottom":"20px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"30px","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Open Sans","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.5","fontSizeBase":"16px","fontSizeXxs":"11px","fontSizeXs":"12px","fontSizeSm":"14px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Crossten Book-V","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"},{"style":"NORMAL","weight":"500","__typename":"FontStyleData"},{"style":"NORMAL","weight":"700","__typename":"FontStyleData"},{"style":"NORMAL","weight":"300","__typename":"FontStyleData"},{"style":"NORMAL","weight":"600","__typename":"FontStyleData"}],"assetNames":["CrosstenBook-V-normal-400.woff2","CrosstenBook-V-normal-500.woff2","CrosstenBook-V-normal-700.woff2","CrosstenBook-V-normal-300.woff2","CrosstenBook-V-normal-600.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Blender Pro Book","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"},{"style":"NORMAL","weight":"500","__typename":"FontStyleData"},{"style":"NORMAL","weight":"700","__typename":"FontStyleData"},{"style":"ITALIC","weight":"400","__typename":"FontStyleData"}],"assetNames":["BlenderProBook-normal-400.woff2","BlenderProBook-normal-500.woff2","BlenderProBook-normal-700.woff2","BlenderProBook-italic-400.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/common/Loading/LoadingDot-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/common/Loading/LoadingDot-1742218158000","value":{"title":"Chargement..."},"localOverride":false},"CachedAsset:quilt:videotron.prod:pages/forums/ForumMessagePage:board:mobilephone-english-1746520793396":{"__typename":"CachedAsset","id":"quilt:videotron.prod:pages/forums/ForumMessagePage:board:mobilephone-english-1746520793396","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"MAIN_SIDE","bgColor":null,"showTitle":null,"showDescription":null,"textPosition":null,"textColor":null,"sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"MainSideQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"messages.widget.relatedContentWidget","className":null,"props":{"hideIfEmpty":true,"enablePagination":false,"useTitle":true,"listVariant":{"type":"unstyled","props":{"listItemSpacing":"xxl"}},"pageSize":5,"style":"compact","pagerVariant":{"type":"none"},"viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"useCompactSpacing":true,"boardIconSize":"24","useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useNodeLink":true,"useViewCount":false,"usePreviewMedia":true,"useBody":false,"timeStampType":"postTime","useTags":false,"clampSubjectLines":2,"useBoardIcon":true,"useMessageTimeLink":true,"useTextBody":true,"useSolvedBadge":false,"renderPostTimeBeforeAuthor":true,"useAvatar":false,"useAuthorLogin":true,"useVideoPreview":false}},"lazyLoad":false,"panelType":"standard"},"__typename":"QuiltComponent"},{"id":"messages.widget.messageListForNodeByRecentActivityWidget","className":null,"props":{"hideIfEmpty":true,"useTitle":true,"showTabs":false,"pageSize":5,"pagerVariant":{"type":"loadMore"},"style":"compact","viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","truncateBodyLength":-1,"useNodeLink":true,"usePreviewMedia":false,"timeStampType":"conversation.lastPostingActivityTime","avatarSize":"40","useTextBody":true,"useSolvedBadge":true,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":true,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":false,"useMessageTimeLink":true,"clampBodyLines":3,"useAuthorLogin":true,"useUnreadCount":false,"useNodeHoverCard":true,"useSearchSnippet":false}},"panelType":"divider","sorts":{"conversationLastPostingActivityTime":{"direction":"DESC"}}},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:fr_FR-components/common/EmailVerification-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/common/EmailVerification-1742218158000","value":{"email.verification.title":"Vérification de l'adresse e-mail requise","email.verification.message.update.email":"Pour participer à la communauté, vous devez d'abord vérifier votre adresse e-mail. L'e-mail de vérification a été envoyé à {email}. Pour changer votre adresse e-mail, visitez Mes paramètres .","email.verification.message.resend.email":"Pour participer à la communauté, vous devez d'abord vérifier votre adresse e-mail. L'e-mail de vérification a été envoyé à {email}. Renvoyer l'e-mail ."},"localOverride":false},"CachedAsset:text:fr_FR-pages/forums/ForumMessagePage-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-pages/forums/ForumMessagePage-1742218158000","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"Ce message est introuvable","name":"Page de message de Forum","section.message-list.title":"Discussion de forum","archivedMessageTitle":"Ce contenu a été archivé"},"localOverride":false},"CachedAsset:quiltWrapper:videotron.prod:Common:fr-FR-1746520742861":{"__typename":"CachedAsset","id":"quiltWrapper:videotron.prod:Common:fr-FR-1746520742861","value":{"id":"Common_oIbWvI","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"custom.widget.Utility_Nav_FR","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"usePageWidth":true,"backgroundColor":"var(--lia-bs-primary)","useBackground":false,"backgroundOpacity":1,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"community.widget.navbarWidget","props":{"showUserName":false,"showRegisterLink":true,"useIconLanguagePicker":true,"showLanguagePicker":true,"useLabelLanguagePicker":true,"links":{"sideLinks":[],"mainLinks":[{"children":[],"linkType":"INTERNAL","id":"super-utilisateurs-link","params":{"boardId":"SuperUtilisateurs","categoryId":"SuperUtilisateurs"},"routeName":"ForumBoardPage"},{"children":[{"linkType":"INTERNAL","id":"mobile-link","params":{"boardId":"mobile","categoryId":"fr"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"internet-telephonie-link","params":{"boardId":"internet-telephonie","categoryId":"fr"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"television-divertissement-link","params":{"boardId":"television-divertissement","categoryId":"fr"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"mon-videotron-link","params":{"boardId":"mon-videotron","categoryId":"fr"},"routeName":"ForumBoardPage"}],"linkType":"INTERNAL","id":"fr-link","params":{"categoryId":"fr"},"routeName":"CategoryPage"},{"children":[],"linkType":"INTERNAL","id":"le-blogue-link","params":{"boardId":"LeBlogue","categoryId":"fr"},"routeName":"BlogBoardPage"},{"children":[],"linkType":"EXTERNAL","id":"external-link","url":"https://forum.videotron.com/help","target":"SELF"}]},"className":"QuiltComponent_lia-component-edit-mode__0nCcm","style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"400","controllerHighlightColor":"#C14D00","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"14px","linkBoxShadowHover":"none","backgroundOpacity":0.8,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"52px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"5px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"1px solid var(--lia-bs-border-color)","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"flex-start","linkColor":"var(--lia-bs-body-color)","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerHighlightTextColor":"var(--lia-yiq-light)","background":{"imageAssetName":"","color":"var(--lia-bs-white)","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"var(--lia-bs-primary)","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"0","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"5px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-body-color)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-body-color)"},"showSearchIcon":true,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":{"backgroundColor":"#FDD200","visualEffects":{"showBottomBorder":true},"backgroundOpacity":100,"backgroundImageProps":{"assetName":"community-widget-bannerWidget-1733422118937.png","backgroundSize":"COVER","lastModified":"1733422120000","backgroundPosition":"CENTER_CENTER","backgroundRepeat":"NO_REPEAT"},"fontColor":"var(--lia-bs-primary)"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"transparent","linkHighlightColor":"var(--lia-bs-primary)","visualEffects":{"showBottomBorder":true},"linkTextColor":"var(--lia-bs-gray-700)"},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"var(--lia-bs-primary)","items":[{"id":"community.widget.footerWidget","props":null,"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:text:fr_FR-components/common/ActionFeedback-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/common/ActionFeedback-1742218158000","value":{"joinedGroupHub.title":"Bienvenue","joinedGroupHub.message":"Vous êtes maintenant membre de ce groupe et abonné aux mises à jour.","groupHubInviteNotFound.title":"Invitation non trouvée","groupHubInviteNotFound.message":"Désolé, nous n'avons pas trouvé votre invitation au groupe. Le propriétaire a peut-être annulé l'invitation.","groupHubNotFound.title":"Groupe introuvable","groupHubNotFound.message":"Le grouphub que vous avez essayé de rejoindre n'existe pas. Il a peut-être été supprimé.","existingGroupHubMember.title":"Déjà membre","existingGroupHubMember.message":"Vous êtes déjà membre de ce groupe.","accountLocked.title":"Compte verrouillé","accountLocked.message":"Votre compte a été verrouillé en raison de plusieurs tentatives infructueuses. Réessayez dans {lockoutTime} minutes.","editedGroupHub.title":"Modifications enregistrées","editedGroupHub.message":"Votre groupe a été mis à jour.","leftGroupHub.title":"Au revoir","leftGroupHub.message":"Vous n'êtes plus membre de ce groupe et ne recevrez plus de mises à jour à l'avenir.","deletedGroupHub.title":"Supprimé","deletedGroupHub.message":"Le groupe a été supprimé.","groupHubCreated.title":"Groupe créé","groupHubCreated.message":"{groupHubName} est prêt à être utilisé","accountClosed.title":"Compte fermé","accountClosed.message":"Le compte a été fermé et vous serez maintenant redirigé vers la page d'accueil.","resetTokenExpired.title":"Le lien de réinitialisation du mot de passe a expiré","resetTokenExpired.message":"Essayez de réinitialiser votre mot de passe à nouveau","invalidUrl.title":"URL invalide","invalidUrl.message":"L'URL que vous utilisez n'est pas reconnue. Vérifiez votre URL et réessayez.","accountClosedForUser.title":"Compte fermé","accountClosedForUser.message":"Le compte de {userName} est fermé","inviteTokenInvalid.title":"Invitation invalide","inviteTokenInvalid.message":"Votre invitation à la communauté a été annulée ou a expiré.","inviteTokenError.title":"Erreur de vérification de l'invitation","inviteTokenError.message":"L'URL que vous utilisez n'est pas reconnue. Vérifiez votre URL et réessayez.","pageNotFound.title":"Accès refusé","pageNotFound.message":"Vous n'avez pas accès à cette zone de la communauté ou elle n'existe pas","eventAttending.title":"Répondu comme participant","eventAttending.message":"Vous serez notifié en cas d'activité et rappelé à l'approche de l'événement","eventInterested.title":"Répondu comme intéressé","eventInterested.message":"Vous serez notifié en cas d'activité et rappelé à l'approche de l'événement","eventNotFound.title":"Événement introuvable","eventNotFound.message":"L'événement auquel vous avez essayé de répondre n'existe pas.","redirectToRelatedPage.title":"Affichage du Contenu Connexe","redirectToRelatedPageForBaseUsers.title":"Affichage du Contenu Connexe","redirectToRelatedPageForBaseUsers.message":"Le contenu que vous essayez d'accéder est archivé","redirectToRelatedPage.message":"Le contenu que vous essayez d'accéder est archivé","relatedUrl.archivalLink.flyoutMessage":"Le contenu que vous essayez d'accéder est archivé Voir le Contenu Archivé"},"localOverride":false},"QueryVariables:TopicReplyList:message:40995:1":{"__typename":"QueryVariables","id":"TopicReplyList:message:40995:1","value":{"id":"message:40995","first":10,"sorts":{"kudosSumWeight":{"direction":"DESC","order":0},"postTime":{"direction":"ASC","order":1}},"repliesFirst":3,"repliesFirstDepthThree":1,"repliesSorts":{"kudosSumWeight":{"direction":"DESC","order":0},"postTime":{"direction":"ASC","order":1}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":true,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":true,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:component:custom.widget.Utility_Nav_FR-fr-fr-1746520801561":{"__typename":"CachedAsset","id":"component:custom.widget.Utility_Nav_FR-fr-fr-1746520801561","value":{"component":{"id":"custom.widget.Utility_Nav_FR","template":{"id":"Utility_Nav_FR","markupLanguage":"HTML","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Utility_Nav_FR","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:text:fr_FR-components/community/Breadcrumb-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/Breadcrumb-1742218158000","value":{"navLabel":"Fil d'Ariane","dropdown":"Navigation supplémentaire des parents de la page"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageBanner-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageBanner-1742218158000","value":{"messageMarkedAsSpam":"Ce post a été marqué comme pourriel","messageMarkedAsSpam@board:TKB":"Cet article a été marqué comme pourriel","messageMarkedAsSpam@board:BLOG":"Ce post a été marqué comme pourriel","messageMarkedAsSpam@board:FORUM":"Cette discussion a été marquée comme pourriel","messageMarkedAsSpam@board:OCCASION":"Cet événement a été marqué comme pourriel","messageMarkedAsSpam@board:IDEA":"Cette idée a été marquée comme pourriel","manageSpam":"Gérer le pourriel","messageMarkedAsAbuse":"Ce message a été marqué comme abus","messageMarkedAsAbuse@board:TKB":"Cet article a été marqué comme abus","messageMarkedAsAbuse@board:BLOG":"Ce poste a été marqué comme abus","messageMarkedAsAbuse@board:FORUM":"Cette discussion a été marquée comme abus","messageMarkedAsAbuse@board:OCCASION":"Cet événement a été marqué comme abus","messageMarkedAsAbuse@board:IDEA":"Cette idée a été marquée comme abus","preModCommentAuthorText":"Ce commentaire sera publié dès qu'il aura été approuvé","preModCommentModeratorText":"Ce commentaire est en attente de modération","messageMarkedAsOther":"Ce message a été rejeté pour d'autres raisons","messageMarkedAsOther@board:TKB":"Cet article a été rejeté pour d'autres raisons","messageMarkedAsOther@board:BLOG":"Ce poste a été rejeté pour d'autres raisons","messageMarkedAsOther@board:FORUM":"Cette discussion a été rejetée pour d'autres raisons","messageMarkedAsOther@board:OCCASION":"Cet événement a été rejeté pour d'autres raisons","messageMarkedAsOther@board:IDEA":"Cette idée a été rejetée pour d'autres raisons","messageArchived":"Ce poste a été archivé le {date}","relatedUrl":"Voir le contenu associé","relatedContentText":"Affichage du contenu associé","archivedContentLink":"Voir le contenu archivé"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageView/MessageViewStandard-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageView/MessageViewStandard-1742218158000","value":{"anonymous":"Anonyme","author":"{messageAuthorLogin}","authorBy":"{messageAuthorLogin}","board":"{messageBoardTitle}","replyToUser":" à {parentAuthor}","showMoreReplies":"Afficher plus","replyText":"Répondre","repliesText":"Réponses","markedAsSolved":"Marqué comme Solution","movedMessagePlaceholder.BLOG":"{count, plural, =0 {Ce commentaire a été} other {Ces commentaires ont été} } déplacé(s).","movedMessagePlaceholder.TKB":"{count, plural, =0 {Ce commentaire a été} other {Ces commentaires ont été} } déplacé(s).","movedMessagePlaceholder.FORUM":"{count, plural, =0 {Cette réponse a été} other {Ces réponses ont été} } déplacée(s).","movedMessagePlaceholder.IDEA":"{count, plural, =0 {Ce commentaire a été} other {Ces commentaires ont été} } déplacé(s).","movedMessagePlaceholder.OCCASION":"{count, plural, =0 {Ce commentaire a été} other {Ces commentaires ont été} } déplacé(s).","movedMessagePlaceholderUrlText":"déplacé.","messageStatus":"Statut : ","statusChanged":"Statut modifié : {previousStatus} en {currentStatus}","statusAdded":"Statut ajouté : {status}","statusRemoved":"Statut supprimé : {status}","labelExpand":"développer les réponses","labelCollapse":"réduire les réponses","unhelpfulReason.reason1":"Le contenu est obsolète","unhelpfulReason.reason2":"L'article manque d'informations","unhelpfulReason.reason3":"Le contenu concerne un produit différent","unhelpfulReason.reason4":"Ne correspond pas à ce que je cherchais"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/ThreadedReplyList-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/ThreadedReplyList-1742218158000","value":{"title":"{count, plural, one{# Réponse} other{# Réponses}}","title@board:BLOG":"{count, plural, one{# Commentaire} other{# Commentaires}}","title@board:TKB":"{count, plural, one{# Commentaire} other{# Commentaires}}","title@board:IDEA":"{count, plural, one{# Commentaire} other{# Commentaires}}","title@board:OCCASION":"{count, plural, one{# Commentaire} other{# Commentaires}}","noRepliesTitle":"Pas de Réponses","noRepliesTitle@board:BLOG":"Aucun Commentaire","noRepliesTitle@board:TKB":"Aucun Commentaire","noRepliesTitle@board:IDEA":"Aucun Commentaire","noRepliesTitle@board:OCCASION":"Aucun Commentaire","noRepliesDescription":"Soyez le premier à répondre","noRepliesDescription@board:BLOG":"Soyez le premier à commenter","noRepliesDescription@board:TKB":"Soyez le premier à commenter","noRepliesDescription@board:IDEA":"Soyez le premier à commenter","noRepliesDescription@board:OCCASION":"Soyez le premier à commenter","messageReadOnlyAlert:BLOG":"Les commentaires ont été désactivés pour ce poste","messageReadOnlyAlert:TKB":"Les commentaires ont été désactivés pour cet article","messageReadOnlyAlert:IDEA":"Les commentaires ont été désactivés pour cette idée","messageReadOnlyAlert:FORUM":"Les réponses ont été désactivées pour cette discussion","messageReadOnlyAlert:OCCASION":"Les commentaires ont été désactivés pour cet événement"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageReplyCallToAction-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageReplyCallToAction-1742218158000","value":{"leaveReply":"Laisser une réponse...","leaveReply@board:BLOG@message:root":"Laisser un commentaire...","leaveReply@board:TKB@message:root":"Laisser un commentaire...","leaveReply@board:IDEA@message:root":"Laisser un commentaire...","leaveReply@board:OCCASION@message:root":"Laisser un commentaire...","repliesTurnedOff.FORUM":"Les réponses sont désactivées pour ce sujet","repliesTurnedOff.BLOG":"Les commentaires sont désactivés pour ce sujet","repliesTurnedOff.TKB":"Les commentaires sont désactivés pour ce sujet","repliesTurnedOff.IDEA":"Les commentaires sont désactivés pour ce sujet","repliesTurnedOff.OCCASION":"Les commentaires sont désactivés pour ce sujet","infoText":"Arrêter de me piquer!"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/RelatedContentWidget-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/RelatedContentWidget-1742218158000","value":{"title":"Contenu connexe","emptyDescription":"Aucun contenu à afficher"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageListForNodeByRecentActivityWidget-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageListForNodeByRecentActivityWidget-1742218158000","value":{"title@userScope:other":"Contenu récent","title@userScope:self":"Contributions","title@board:FORUM@userScope:other":"Discussions récentes","title@board:BLOG@userScope:other":"Blogs récents","emptyDescription":"Pas de contenu à afficher","MessageListForNodeByRecentActivityWidgetEditor.nodeScope.label":"Portée","title@instance:1729793844493":"Recent Blogs"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/FooterWidget-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/FooterWidget-1742218158000","value":{"homeLink":"Accueil de La Communauté","topOfPage":"Haut de page","buildHash":"Hash de Build :","buildNumber":"Numéro de Build :","buildTime":"Date de Build :","privacyPolicy":"Politique de confidentialité","helpLink":"Aide"},"localOverride":false},"Category:category:fr":{"__typename":"Category","id":"category:fr","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"CATEGORY","displayId":"fr","nodeType":"category","depth":1,"title":"Français","shortTitle":"Français"},"Forum:board:mobile":{"__typename":"Forum","id":"board:mobile","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"FORUM","displayId":"mobile","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"Mobilité","shortTitle":"Mobilité","parent":{"__ref":"Category:category:fr"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0xOC0xOTYyaTNDRTVEMjM2OTczMTZENjI\"}"},"description":"Trouvez toutes les réponses à vos questions concernant votre mobile : appareil, forfait, options, applications, réseau… C’est ici que ça se passe!","eventPath":"category:fr/community:ogevo67675board:mobile/"},"Forum:board:internet-telephonie":{"__typename":"Forum","id":"board:internet-telephonie","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"FORUM","displayId":"internet-telephonie","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"Internet et Téléphonie","shortTitle":"Internet et Téléphonie","parent":{"__ref":"Category:category:fr"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0xOS0xOTYzaTQ5NzlDMEQyRjZBM0E0QUM\"}"},"description":"Wi-Fi, données, routeur, sécurité, messagerie… on répond à toutes vos questions au sujet d’Internet et de la téléphonie résidentielle!","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/"},"Forum:board:television-divertissement":{"__typename":"Forum","id":"board:television-divertissement","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"FORUM","displayId":"television-divertissement","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"Télé et Divertissement","shortTitle":"Télé et Divertissement","parent":{"__ref":"Category:category:fr"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yMC0xOTY0aUFDNjI2MTlFMDE2MjE2MEE\"}"},"description":"Une question concernant votre télécommande? Une astuce pour configurer votre terminal? Une suggestion de série à regarder sur illico? Vous trouverez tout ça ici.","eventPath":"category:fr/community:ogevo67675board:television-divertissement/"},"Forum:board:mon-videotron":{"__typename":"Forum","id":"board:mon-videotron","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Blog:board:LeBlogue":{"__typename":"Blog","id":"board:LeBlogue","blogPolicies":{"__typename":"BlogPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Conversation:conversation:39692":{"__typename":"Conversation","id":"conversation:39692","topic":{"__typename":"ForumTopicMessage","uid":39692},"lastPostingActivityTime":"2025-05-21T12:49:29.177-04:00","solved":false},"ForumTopicMessage:message:39692":{"__typename":"ForumTopicMessage","subject":"Need Guidance!","conversation":{"__ref":"Conversation:conversation:39692"},"id":"message:39692","revisionNum":2,"uid":39692,"depth":0,"board":{"__ref":"Forum:board:mobilephone-english"},"author":{"__typename":"User","uid":30886,"login":"evansmith2125","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-10.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":1617},"postTime":"2023-02-03T11:54:36.709-05:00","lastPublishTime":"2023-02-03T19:45:45.433-05:00","readOnly":false},"Conversation:conversation:48637":{"__typename":"Conversation","id":"conversation:48637","topic":{"__typename":"ForumTopicMessage","uid":48637},"lastPostingActivityTime":"2025-05-14T02:33:01.163-04:00","solved":false},"ForumTopicMessage:message:48637":{"__typename":"ForumTopicMessage","subject":"Fréquences 5G NR","conversation":{"__ref":"Conversation:conversation:48637"},"id":"message:48637","revisionNum":1,"uid":48637,"depth":0,"board":{"__ref":"Forum:board:mobilephone-english"},"author":{"__typename":"User","uid":34851,"login":"Nano","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-5.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":35},"postTime":"2025-05-08T18:14:47.571-04:00","lastPublishTime":"2025-05-08T18:14:47.571-04:00","readOnly":false},"Conversation:conversation:48132":{"__typename":"Conversation","id":"conversation:48132","topic":{"__typename":"ForumTopicMessage","uid":48132},"lastPostingActivityTime":"2025-05-09T17:04:37.038-04:00","solved":false},"ForumTopicMessage:message:48132":{"__typename":"ForumTopicMessage","subject":"Forfait cellulaire USA maximum 120 jrs","conversation":{"__ref":"Conversation:conversation:48132"},"id":"message:48132","revisionNum":1,"uid":48132,"depth":0,"board":{"__ref":"Forum:board:mobilephone-english"},"author":{"__typename":"User","uid":34409,"login":"DB1","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-3.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":53},"postTime":"2025-02-05T09:15:20.115-05:00","lastPublishTime":"2025-02-05T09:15:20.115-05:00","readOnly":false},"Conversation:conversation:48312":{"__typename":"Conversation","id":"conversation:48312","topic":{"__typename":"ForumTopicMessage","uid":48312},"lastPostingActivityTime":"2025-04-24T06:38:55.113-04:00","solved":false},"ForumTopicMessage:message:48312":{"__typename":"ForumTopicMessage","subject":"5G+ ?","conversation":{"__ref":"Conversation:conversation:48312"},"id":"message:48312","revisionNum":1,"uid":48312,"depth":0,"board":{"__ref":"Forum:board:mobilephone-english"},"author":{"__typename":"User","uid":34571,"login":"Latitude57","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-10.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":67},"postTime":"2025-03-07T21:35:09.296-05:00","lastPublishTime":"2025-03-07T21:35:09.296-05:00","readOnly":false},"Conversation:conversation:48179":{"__typename":"Conversation","id":"conversation:48179","topic":{"__typename":"ForumTopicMessage","uid":48179},"lastPostingActivityTime":"2025-02-21T12:07:06.967-05:00","solved":false},"ForumTopicMessage:message:48179":{"__typename":"ForumTopicMessage","subject":"Ottawa Coverage/Data speeds","conversation":{"__ref":"Conversation:conversation:48179"},"id":"message:48179","revisionNum":1,"uid":48179,"depth":0,"board":{"__ref":"Forum:board:mobilephone-english"},"author":{"__typename":"User","uid":7789,"login":"davelewis","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-1.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":126},"postTime":"2025-02-09T21:22:10.313-05:00","lastPublishTime":"2025-02-09T21:22:10.313-05:00","readOnly":false},"User:user:33231":{"__typename":"User","id":"user:33231","uid":33231,"login":"Mtrom1962","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2024-06-19T16:11:34.961-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-11.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":1,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:33231"},"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yNy0xOTU5aUU3QzcxNjJBQkFENzAwODc\"}":{"__typename":"AssociatedImage","url":"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yNy0xOTU5aUU3QzcxNjJBQkFENzAwODc","mimeType":"image/svg+xml"},"Forum:board:TV-Entertainement":{"__typename":"Forum","id":"board:TV-Entertainement","entityType":"FORUM","displayId":"TV-Entertainement","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"TV & Entertainment","shortTitle":"TV & Entertainment","parent":{"__ref":"Category:category:en"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yNy0xOTU5aUU3QzcxNjJBQkFENzAwODc\"}"},"description":"Got a question about your remote? Need help configuring your terminal? Want to know what you should watch next on illico? You’ll find it all here.","eventPath":"category:en/community:ogevo67675board:TV-Entertainement/"},"ForumTopicMessage:message:45600":{"__typename":"ForumTopicMessage","uid":45600,"subject":"Weak wifi signal tv receiver","id":"message:45600","revisionNum":1,"repliesCount":1,"author":{"__ref":"User:user:33231"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TV-Entertainement"},"conversation":{"__ref":"Conversation:conversation:45600"},"moderationData":{"__ref":"ModerationData:moderation_data:45600"},"postTime":"2024-06-19T16:10:15.999-04:00","lastPublishTime":"2024-06-19T16:10:15.999-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":1644},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:TV-Entertainement/message:45600"},"Conversation:conversation:45600":{"__typename":"Conversation","id":"conversation:45600","solved":true,"topic":{"__ref":"ForumTopicMessage:message:45600"},"lastPostingActivityTime":"2024-06-21T09:53:44.966-04:00","lastPostTime":"2024-06-21T09:53:44.966-04:00"},"ModerationData:moderation_data:45600":{"__typename":"ModerationData","id":"moderation_data:45600","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:45600":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:45600","relatedMessage":{"__ref":"ForumTopicMessage:message:45600"}},"Rank:rank:20":{"__typename":"Rank","id":"rank:20","position":33,"name":"Chevalier","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:28286":{"__typename":"User","id":"user:28286","uid":28286,"login":"Alex47","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2022-03-08T15:07:08.761-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-11.svg?time=0"},"rank":{"__ref":"Rank:rank:20"},"messagesCount":4,"kudosGivenCount":1,"kudosReceivedCount":4,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:28286"},"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yMC0xOTY0aUFDNjI2MTlFMDE2MjE2MEE\"}":{"__typename":"AssociatedImage","url":"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yMC0xOTY0aUFDNjI2MTlFMDE2MjE2MEE","mimeType":"image/svg+xml"},"ForumTopicMessage:message:32408":{"__typename":"ForumTopicMessage","uid":32408,"subject":"Réseau local Ethernet sur borne Helix","id":"message:32408","revisionNum":1,"repliesCount":5,"author":{"__ref":"User:user:28286"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:television-divertissement"},"conversation":{"__ref":"Conversation:conversation:32408"},"moderationData":{"__ref":"ModerationData:moderation_data:32408"},"postTime":"2022-03-08T15:12:00.456-05:00","lastPublishTime":"2022-03-08T15:12:00.456-05:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":10341},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:television-divertissement/message:32408"},"Conversation:conversation:32408":{"__typename":"Conversation","id":"conversation:32408","solved":true,"topic":{"__ref":"ForumTopicMessage:message:32408"},"lastPostingActivityTime":"2023-05-14T12:14:34.786-04:00","lastPostTime":"2023-05-14T12:14:34.786-04:00"},"ModerationData:moderation_data:32408":{"__typename":"ModerationData","id":"moderation_data:32408","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:32408":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:32408","relatedMessage":{"__ref":"ForumTopicMessage:message:32408"}},"Rank:rank:18":{"__typename":"Rank","id":"rank:18","position":36,"name":"Squire","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:7047":{"__typename":"User","id":"user:7047","uid":7047,"login":"tennisdetableQC","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2018-06-14T13:57:54.226-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-8.svg?time=0"},"rank":{"__ref":"Rank:rank:18"},"messagesCount":8,"kudosGivenCount":3,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:7047"},"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0xOS0xOTYzaTQ5NzlDMEQyRjZBM0E0QUM\"}":{"__typename":"AssociatedImage","url":"https://forum.videotron.com/t5/s/ogevo67675/images/bi0xOS0xOTYzaTQ5NzlDMEQyRjZBM0E0QUM","mimeType":"image/svg+xml"},"ForumTopicMessage:message:8955":{"__typename":"ForumTopicMessage","uid":8955,"subject":"EMG2926 Serveur web local","id":"message:8955","revisionNum":1,"repliesCount":11,"author":{"__ref":"User:user:7047"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:internet-telephonie"},"conversation":{"__ref":"Conversation:conversation:8955"},"moderationData":{"__ref":"ModerationData:moderation_data:8955"},"postTime":"2018-06-14T13:59:08.817-04:00","lastPublishTime":"2018-06-14T13:59:08.817-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":13000},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/message:8955"},"Conversation:conversation:8955":{"__typename":"Conversation","id":"conversation:8955","solved":true,"topic":{"__ref":"ForumTopicMessage:message:8955"},"lastPostingActivityTime":"2018-06-27T15:12:55.165-04:00","lastPostTime":"2018-06-27T15:12:55.165-04:00"},"ModerationData:moderation_data:8955":{"__typename":"ModerationData","id":"moderation_data:8955","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:8955":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:8955","relatedMessage":{"__ref":"ForumTopicMessage:message:8955"}},"User:user:14367":{"__typename":"User","id":"user:14367","uid":14367,"login":"MartinGoupil01","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2020-07-03T12:15:54.034-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-9.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":2,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:14367"},"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0xOC0xOTYyaTNDRTVEMjM2OTczMTZENjI\"}":{"__typename":"AssociatedImage","url":"https://forum.videotron.com/t5/s/ogevo67675/images/bi0xOC0xOTYyaTNDRTVEMjM2OTczMTZENjI","mimeType":"image/svg+xml"},"ForumTopicMessage:message:21563":{"__typename":"ForumTopicMessage","uid":21563,"subject":"facturation d'interrubains pour des appels locaux","id":"message:21563","revisionNum":1,"repliesCount":2,"author":{"__ref":"User:user:14367"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:mobile"},"conversation":{"__ref":"Conversation:conversation:21563"},"moderationData":{"__ref":"ModerationData:moderation_data:21563"},"postTime":"2020-07-03T12:13:20.685-04:00","lastPublishTime":"2020-07-03T12:13:20.685-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":5058},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:mobile/message:21563"},"Conversation:conversation:21563":{"__typename":"Conversation","id":"conversation:21563","solved":true,"topic":{"__ref":"ForumTopicMessage:message:21563"},"lastPostingActivityTime":"2020-08-26T07:25:17.136-04:00","lastPostTime":"2020-08-26T07:25:17.136-04:00"},"ModerationData:moderation_data:21563":{"__typename":"ModerationData","id":"moderation_data:21563","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:21563":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:21563","relatedMessage":{"__ref":"ForumTopicMessage:message:21563"}},"User:user:3321":{"__typename":"User","id":"user:3321","uid":3321,"login":"Sajap","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2017-11-22T18:25:43.972-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-7.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":1,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:3321"},"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yOC0xOTYwaTI0RjlDNUVGQUI2MEIzRDU\"}":{"__typename":"AssociatedImage","url":"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yOC0xOTYwaTI0RjlDNUVGQUI2MEIzRDU","mimeType":"image/svg+xml"},"Forum:board:my-videotron":{"__typename":"Forum","id":"board:my-videotron","entityType":"FORUM","displayId":"my-videotron","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"My Videotron","shortTitle":"My Videotron","parent":{"__ref":"Category:category:en"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yOC0xOTYwaTI0RjlDNUVGQUI2MEIzRDU\"}"},"description":"Everything you need to know about your Videotron customer account.","eventPath":"category:en/community:ogevo67675board:my-videotron/"},"ForumTopicMessage:message:3909":{"__typename":"ForumTopicMessage","uid":3909,"subject":"frauduant email received","id":"message:3909","revisionNum":1,"repliesCount":1,"author":{"__ref":"User:user:3321"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:my-videotron"},"conversation":{"__ref":"Conversation:conversation:3909"},"moderationData":{"__ref":"ModerationData:moderation_data:3909"},"postTime":"2017-11-22T18:23:47.358-05:00","lastPublishTime":"2017-11-22T18:23:47.358-05:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":7197},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:my-videotron/message:3909"},"Conversation:conversation:3909":{"__typename":"Conversation","id":"conversation:3909","solved":true,"topic":{"__ref":"ForumTopicMessage:message:3909"},"lastPostingActivityTime":"2017-11-23T09:55:39.523-05:00","lastPostTime":"2017-11-23T09:55:39.523-05:00"},"ModerationData:moderation_data:3909":{"__typename":"ModerationData","id":"moderation_data:3909","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:3909":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:3909","relatedMessage":{"__ref":"ForumTopicMessage:message:3909"}},"Rank:rank:2":{"__typename":"Rank","id":"rank:2","position":1,"name":"Moderator - Solution Expert","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:29315":{"__typename":"User","id":"user:29315","uid":29315,"login":"JoéCL","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2022-06-17T22:33:45.319-04:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/images/dS0yOTMxNS0xOTk0aUQxMkEzNjg4OEZFRkYyMjg"},"rank":{"__ref":"Rank:rank:2"},"entityType":"USER","eventPath":"community:ogevo67675/user:29315"},"ModerationData:moderation_data:40997":{"__typename":"ModerationData","id":"moderation_data:40997","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:40997":{"__typename":"ForumReplyMessage","uid":40997,"id":"message:40997","revisionNum":1,"author":{"__ref":"User:user:29315"},"readOnly":false,"repliesCount":1,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:mobilephone-english"},"parent":{"__ref":"ForumTopicMessage:message:40995"},"conversation":{"__ref":"Conversation:conversation:40995"},"subject":"Re: Can not make or receive phone calls from an specific locale in United States","moderationData":{"__ref":"ModerationData:moderation_data:40997"},"body":"
Hello rpcanam,
This sounds like an issue with the VoLTE option. For the Voice-over-LTE option to work , you need not only to have your cellphone compatible and certified with the VoLTE option, but for your SIM card to be compatible and have the option provisionned onto your SIM card.
Because the 3G network is still available for a little over a year in Québec or in the rest of Canada, you wouldn't notice any problem until you are unable to reach Canadian cellphone towers. Similarly, if it was a problem with service reception in general, your text services and mobile data wouldn't work.
While unlikely, it is possible that your SIM card is not compatible with the VoLTE option, it is very unlikely. The most probable answer to this problem is that it might not be provisioned to your SIM card. A quick callor chat with our technical support can help shed some light on the situation. If the SIM card isn't provisioned with the correct options, we'll be happy to rectify that mistake.
Hope to see you soon! 😸
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"213","kudosSumWeight":0,"postTime":"2023-05-04T23:01:32.217-04:00","lastPublishTime":"2023-05-04T23:01:32.217-04:00","metrics":{"__typename":"MessageMetrics","views":4776},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:40995/message:40997","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8b3wzfDE2OjAsNDE6MXwx","node":{"__ref":"ForumReplyMessage:message:41372"}}]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:41372":{"__typename":"ModerationData","id":"moderation_data:41372","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:41372":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:31331"},"id":"message:41372","revisionNum":1,"uid":41372,"depth":2,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:mobilephone-english"},"parent":{"__ref":"ForumReplyMessage:message:40997"},"conversation":{"__ref":"Conversation:conversation:40995"},"subject":"Re: Can not make or receive phone calls from an specific locale in United States","moderationData":{"__ref":"ModerationData:moderation_data:41372"},"body":"
I had a chat in early May with support. That concluded that I needed to have my SIM card upgraded once I returned to Ottawa. Supposedly I had received emails notifying my that I needed to upgrade with the changes to 5G in the states....but could not find any record of that.
Anyway, I did go to a kiosk in Ottawa upon my return and the clerk remarked that yes indeed my SIM card was \"old\". That was in early May.
I am now visiting again in New Jersey and travelling in the same region. Besides one halting phone call I was able to make upon landing at the airport my phone is behaving exactly as described in my original post.
This is beyond frustrating. Despite my plan covering unlimited calling in Canada/US, out of desperation today I thought maybe there was a billing/account issue and if I just paid for a daily travel pass I'd be able to call out. That did not work either, so probably bought that for nothing.
Below are two maps from CellMapper.net. I am located in the middle of this area. The first map is LTE-ATT towers, signal. The second is LTE-T-Mobile. When using automatic network selection my phone always selects AT&T. When I manually select a nearby T-Mobile it does not help.
AT&T
T-Mobile
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2023-06-03T10:59:59.702-04:00","lastPublishTime":"2023-06-03T10:59:59.702-04:00","metrics":{"__typename":"MessageMetrics","views":4481},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:40995/message:41372","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:41374":{"__typename":"ModerationData","id":"moderation_data:41374","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"User:user:6037":{"__typename":"User","id":"user:6037","uid":6037,"login":"JulieL","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2018-03-26T16:53:44.253-04:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/images/dS02MDM3LTU1MGk2MDY0NzM2QTE2QThERUZE"},"rank":{"__ref":"Rank:rank:2"},"entityType":"USER","eventPath":"community:ogevo67675/user:6037"},"ForumReplyMessage:message:41374":{"__typename":"ForumReplyMessage","uid":41374,"id":"message:41374","revisionNum":1,"author":{"__ref":"User:user:31331"},"readOnly":false,"repliesCount":4,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:mobilephone-english"},"parent":{"__ref":"ForumTopicMessage:message:40995"},"conversation":{"__ref":"Conversation:conversation:40995"},"subject":"Re: Can not make or receive phone calls from an specific locale in United States","moderationData":{"__ref":"ModerationData:moderation_data:41374"},"body":"This is \"Carrier Settings version\" : videotron_ca-43000000050.58 2022-12-08
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"80","kudosSumWeight":0,"postTime":"2023-06-03T13:02:13.015-04:00","lastPublishTime":"2023-06-03T13:02:13.015-04:00","metrics":{"__typename":"MessageMetrics","views":4489},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:40995/message:41374","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8b3wzfDE2OjAsNDE6MXwx","node":{"__ref":"ForumReplyMessage:message:41482"}}]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:41482":{"__typename":"ModerationData","id":"moderation_data:41482","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"User:user:31956":{"__typename":"User","id":"user:31956","uid":31956,"login":"Arasarn","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2023-09-07T07:33:31.439-04:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-8.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"entityType":"USER","eventPath":"community:ogevo67675/user:31956"},"ForumReplyMessage:message:41482":{"__typename":"ForumReplyMessage","uid":41482,"id":"message:41482","revisionNum":1,"author":{"__ref":"User:user:6037"},"readOnly":false,"repliesCount":3,"depth":2,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:mobilephone-english"},"parent":{"__ref":"ForumReplyMessage:message:41374"},"conversation":{"__ref":"Conversation:conversation:40995"},"subject":"Re: Can not make or receive phone calls from an specific locale in United States","moderationData":{"__ref":"ModerationData:moderation_data:41482"},"body":"
Hi! It might still be an issue with the VoLTE option which is now necessary for travelling to the United-States. We invite you to contact our technical support directly for this; https://videotron.com/en/contact-us Thank you
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"postTime":"2023-06-11T13:30:06.076-04:00","lastPublishTime":"2023-06-11T13:30:06.076-04:00","metrics":{"__typename":"MessageMetrics","views":4361},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:40995/message:41482","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":true,"endCursor":"MjUuM3wyLjF8b3wxfDE2OjAsNDE6MXwx","hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"MessageEdge","cursor":"MjUuM3wyLjF8b3wxfDE2OjAsNDE6MXwx","node":{"__ref":"ForumReplyMessage:message:42584"}}]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:42584":{"__typename":"ModerationData","id":"moderation_data:42584","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:42584":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:31956"},"id":"message:42584","revisionNum":1,"uid":42584,"depth":3,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:mobilephone-english"},"parent":{"__ref":"ForumReplyMessage:message:41482"},"conversation":{"__ref":"Conversation:conversation:40995"},"subject":"Re: Can not make or receive phone calls from an specific locale in United States","moderationData":{"__ref":"ModerationData:moderation_data:42584"},"body":"I drove back to Granby from Vermont on a two week road **blip** vacation to a videotron store to get a new SIM card, I have a compatible device (iPhone SE 2nd Gen) and have it fully updated with Volte turned on, and have power cycled multiple times and still cannot make calls. Wasted half a day of my vacation and still doesn't fix the issue.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2023-09-07T07:32:14.025-04:00","lastPublishTime":"2023-09-07T07:32:14.025-04:00","metrics":{"__typename":"MessageMetrics","views":3218},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:40995/message:42584","customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"User:user:31793":{"__typename":"User","id":"user:31793","uid":31793,"login":"dominiquebroder","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2023-08-09T15:37:10.202-04:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-10.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"entityType":"USER","eventPath":"community:ogevo67675/user:31793"},"ModerationData:moderation_data:42191":{"__typename":"ModerationData","id":"moderation_data:42191","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:42191":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:31793"},"id":"message:42191","revisionNum":1,"uid":42191,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:mobilephone-english"},"parent":{"__ref":"ForumTopicMessage:message:40995"},"conversation":{"__ref":"Conversation:conversation:40995"},"subject":"Re: Can not make or receive phone calls from an specific locale in United States","moderationData":{"__ref":"ModerationData:moderation_data:42191"},"body":"
It seems like you're facing calling-related issues in Ocean County, New Jersey, despite having a mobile plan with unlimited voice/data in the US. While your phone image resize works well in other regions, you're experiencing difficulties with calls when visiting family there. Despite previous attempts to manually select networks, the issue persists. You've already taken several troubleshooting steps, including updates and resets.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2023-08-09T15:48:42.497-04:00","lastPublishTime":"2023-08-09T15:48:42.497-04:00","metrics":{"__typename":"MessageMetrics","views":3754},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:40995/message:42191","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"CachedAsset:text:fr_FR-components/community/Navbar-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/Navbar-1742218158000","value":{"community":"Accueil de la communauté","inbox":"Boîte de réception","manageContent":"Gérer le contenu","tos":"Conditions d'utilisation","forgotPassword":"Mot de passe oublié","themeEditor":"Éditeur de thème","edit":"Modifier la barre de navigation","skipContent":"Passer au contenu","mon-videotron-link":"Mon Vidéotron","le-blogue-link":"Blogue","mobile-link":"Mobilité","super-utilisateurs-link":"Super Utilisateurs","mobilephone-english-link":"Mobility","television-divertissement-link":"Télé et Divertissement","en-link":"Forum","t-v-entertainement-link":"TV & Entertainment","fr-link":"Forum","the-blog-link":"Blog","internet-telephony-link":"Internet & Telephony","blog-link":"Blog","my-videotron-link":"My Videotron","internet-telephonie-link":"Internet et Téléphonie","forum-television-entertainment-link":"TV & Entertainment","forum-mobility-link":"Mobility","external-link":"Aide","forum-internet-telephony-link":"Internet & Telephony","forum-news-link":"My Videotron"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/NavbarHamburgerDropdown-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/NavbarHamburgerDropdown-1742218158000","value":{"hamburgerLabel":"Menu Latéral"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/BrandLogo-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/BrandLogo-1742218158000","value":{"logoAlt":"Khoros","themeLogoAlt":"Logo de la marque"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/NavbarTextLinks-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/NavbarTextLinks-1742218158000","value":{"more":"Plus"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/languages/UseLanguageText-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/languages/UseLanguageText-1742218158000","value":{"UseLanguageText.language.ar-AE.label":"Arabe","UseLanguageText.language.bg-BG.label":"Bulgare","UseLanguageText.language.ca-AD.label":"Catalan","UseLanguageText.language.cs-CZ.label":"Tchèque","UseLanguageText.language.da-DK.label":"Danois","UseLanguageText.language.de-DE.label":"Allemand","UseLanguageText.language.el-GR.label":"Grec","UseLanguageText.language.en-GB.label":"Anglais (Royaume-Uni)","UseLanguageText.language.en-US.label":"Anglais","UseLanguageText.language.es-ES.label":"Espagnol","UseLanguageText.language.es-MX.label":"Espagnol (Amérique latine)","UseLanguageText.language.et-EE.label":"Estonien","UseLanguageText.language.fa-IR.label":"Persan (Farsi)","UseLanguageText.language.fi-FI.label":"Finnois","UseLanguageText.language.fr-FR.label":"Français","UseLanguageText.language.he-IL.label":"Hébreu","UseLanguageText.language.hr-HR.label":"Croate","UseLanguageText.language.hu-HU.label":"Hongrois","UseLanguageText.language.in-ID.label":"Indonésien","UseLanguageText.language.it-IT.label":"Italien","UseLanguageText.language.ja-JP.label":"Japonais","UseLanguageText.language.ko-KR.label":"Coréen","UseLanguageText.language.lt-LT.label":"Lituanien","UseLanguageText.language.lv-LV.label":"Letton","UseLanguageText.language.ms-MY.label":"Malais","UseLanguageText.language.nl-NL.label":"Néerlandais","UseLanguageText.language.no-NO.label":"Norvégien","UseLanguageText.language.pl-PL.label":"Polonais","UseLanguageText.language.pt-BR.label":"Portugais (Brésilien)","UseLanguageText.language.pt-PT.label":"Portugais","UseLanguageText.language.ro-RO.label":"Roumain","UseLanguageText.language.ru-RU.label":"Russe","UseLanguageText.language.sk-SK.label":"Slovaque","UseLanguageText.language.sq-AL.label":"Albanais","UseLanguageText.language.sv-SE.label":"Suédois","UseLanguageText.language.th-TH.label":"Thaï","UseLanguageText.language.tr-TR.label":"Turc","UseLanguageText.language.uk-UA.label":"Ukrainien","UseLanguageText.language.vi-VN.label":"Vietnamien","UseLanguageText.language.zh-CN.label":"Chinois (simplifié)","UseLanguageText.language.zh-TW.label":"Chinois (traditionnel)"},"localOverride":false},"CachedAsset:text:fr_FR-components/languages/LanguagePicker-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/languages/LanguagePicker-1742218158000","value":{"dropdown.title":"Sélecteur de langue","selected.language":"Langue sélectionnée actuellement","toast.successMessage":"Aller à la communauté {newLanguage}Revenir à {oldLanguage}","toast.successTitle":"Langue changée en {language}","toast.failureTitle":"Erreur - Action échouée","toast.failureMessage":"Un problème non identifié s'est produit lors de l'action que vous avez entreprise. Veuillez réessayer plus tard."},"localOverride":false},"CachedAsset:text:fr_FR-components/search/SpotlightSearchIcon-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/search/SpotlightSearchIcon-1742218158000","value":{"search":"Rechercher"},"localOverride":false},"CachedAsset:text:fr_FR-components/authentication/AuthenticationLink-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/authentication/AuthenticationLink-1742218158000","value":{"title.login":"Connexion","title.registration":"S'inscrire","title.forgotPassword":"Mot de passe oublié","title.multiAuthLogin":"Connexion"},"localOverride":false},"CachedAsset:text:fr_FR-components/nodes/NodeLink-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/nodes/NodeLink-1742218158000","value":{"place":"Lieu {name}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/EscalatedMessageBanner-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/EscalatedMessageBanner-1742218158000","value":{"escalationMessage":"Escalation vers Salesforce par {username} le {date}","viewDetails":"Voir les détails","modalTitle":"Détails de l'affaire","escalatedBy":"Escaladé par :","escalatedOn":"Escaladé le :","caseNumber":"Numéro d'affaire :","status":"Statut :","lastUpdateDate":"Dernière mise à jour :","automaticEscalation":"escalade automatique","anonymous":"Anonyme"},"localOverride":false},"CachedAsset:text:fr_FR-components/users/UserLink-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/users/UserLink-1742218158000","value":{"authorName":"Voir le profil : {author}","anonymous":"Anonyme"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/users/UserRank-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/users/UserRank-1742218158000","value":{"rankName":"{rankName}","userRank":"Rang d'auteur {rankName}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageTime-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageTime-1742218158000","value":{"postTime":"Publié : {time}","lastPublishTime":"Dernière mise à jour : {time}","conversation.lastPostingActivityTime":"Heure de la dernière activité de publication : {time}","conversation.lastPostTime":"Heure du dernier poste : {time}","moderationData.rejectTime":"Heure de rejet : {time}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageSolvedBadge-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageSolvedBadge-1742218158000","value":{"solved":"Résolu"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageSubject-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageSubject-1742218158000","value":{"noSubject":"(sans objet)"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageBody-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageBody-1742218158000","value":{"showMessageBody":"Afficher plus","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} n'est plus disponible","mentionsErrorMessage":"Le {mentionsType} que vous essayez de consulter a été supprimé de la communauté.","videoProcessing":"La vidéo est en cours de traitement. Veuillez réessayer dans quelques minutes.","bannerTitle":"Le fournisseur de vidéos nécessite des cookies pour lire la vidéo. Acceptez pour continuer ou {url} la regarder directement sur le site du fournisseur.","buttonTitle":"Accepter","urlText":"visionner"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageCustomFields-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageCustomFields-1742218158000","value":{"CustomField.default.label":"Valeur de {name}"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/common/QueryHandler-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/common/QueryHandler-1742218158000","value":{"title":"Gestionnaire de requêtes"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageReplyButton-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageReplyButton-1742218158000","value":{"repliesCount":"{count}","title":"Répondre","title@board:BLOG@message:root":"Commentaire","title@board:TKB@message:root":"Commentaire","title@board:IDEA@message:root":"Commentaire","title@board:OCCASION@message:root":"Commentaire"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/common/BuildInformation-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/common/BuildInformation-1742218158000","value":{"buildHash":"Build Hash : {buildHash}","buildNumber":"Numéro de build : {buildNumber}","buildTime":"Date de build : {buildTime}"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/KhorosLogo-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/KhorosLogo-1742218158000","value":{"alt":"Propulsé par Khoros"},"localOverride":false},"CachedAsset:text:fr_FR-components/customComponent/CustomComponent-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/customComponent/CustomComponent-1742218158000","value":{"errorMessage":"Erreur lors du rendu de l'ID du composant : {customComponentId}","bannerTitle":"Le fournisseur de vidéos nécessite des cookies pour lire la vidéo. Acceptez pour continuer ou {url} directement sur le site du fournisseur.","buttonTitle":"Accepter","urlText":"regarder"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/NavbarDropdownToggle-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/NavbarDropdownToggle-1742218158000","value":{"ariaLabelClosed":"Appuyez sur la flèche vers le bas pour ouvrir le menu"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/users/UserAvatar-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/users/UserAvatar-1742218158000","value":{"altText":"Avatar de {login}","altTextGeneric":"Avatar de l'utilisateur"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/ranks/UserRankLabel-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/ranks/UserRankLabel-1742218158000","value":{"altTitle":"Icône pour le rang {rankName}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageListMenu-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageListMenu-1742218158000","value":{"postTimeAsc":"Plus ancien","postTimeDesc":"Plus récent","kudosSumWeightAsc":"Le moins aimé","kudosSumWeightDesc":"Le plus aimé","sortTitle":"Trier par","sortedBy.item":" {itemName, select, postTimeAsc {Plus ancien} postTimeDesc {Plus récent} kudosSumWeightAsc {Le moins aimé} kudosSumWeightDesc {Le plus aimé} other {}}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/AcceptedSolutionButton-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/AcceptedSolutionButton-1742218158000","value":{"accept":"Marquer comme résolu","accepted":"Marqué comme résolu","errorHeader":"Erreur !","errorAdd":"Une erreur est survenue en marquant comme résolu.","errorRemove":"Une erreur est survenue en révoquant le marquage comme résolu.","solved":"Résolu","topicAlreadySolvedErrorTitle":"La solution existe déjà","topicAlreadySolvedErrorDesc":"Rafraîchissez le navigateur pour voir la solution existante"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/common/Pager/PagerLoadMore-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/common/Pager/PagerLoadMore-1742218158000","value":{"loadMore":"Afficher plus"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageView/MessageViewInline-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageView/MessageViewInline-1742218158000","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonyme","place":"Endroit {bylineBoard}","gotoParent":"Aller au parent {name}"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/nodes/NodeIcon-1742218158000":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/nodes/NodeIcon-1742218158000","value":{"contentType":"Type de contenu {style, select, FORUM {Forum} BLOG {Blog} TKB {Base de connaissances} IDEA {Idées} OCCASION {Événements} other {}} icône"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"boardId":"mobilephone-english","messageSubject":"can-not-make-or-receive-phone-calls-from-an-specific-locale-in-united-states","messageId":"40995"},"buildId":"-gVUpXaWnPcjlrLJZ92B7","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","openTelemetryClientEnabled":false,"openTelemetryConfigName":"videotron","openTelemetryServiceVersion":"25.3.0","openTelemetryUniverse":"prod","openTelemetryCollector":"http://localhost:4318","openTelemetryRouteChangeAllowedTime":"5000","apolloDevToolsEnabled":false,"inboxMuteWipFeatureEnabled":false},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["./components/seo/QAPageSchema/QAPageSchema.tsx","./components/customComponent/CustomComponent/CustomComponent.tsx","./components/community/Navbar/NavbarWidget.tsx","./components/community/Breadcrumb/BreadcrumbWidget.tsx","./components/messages/TopicWithThreadedReplyListWidget/TopicWithThreadedReplyListWidget.tsx","./components/messages/MessageView/MessageViewStandard/MessageViewStandard.tsx","./components/messages/ThreadedReplyList/ThreadedReplyList.tsx","./components/messages/RelatedContentWidget/RelatedContentWidget.tsx","./components/messages/MessageListForNodeByRecentActivityWidget/MessageListForNodeByRecentActivityWidget.tsx","./components/community/FooterWidget/FooterWidget.tsx","./components/community/FooterWidgetHelpLink/FooterWidgetHelpLink.tsx","./components/community/KhorosLogo/KhorosLogo.tsx","./components/customComponent/CustomComponentContent/HtmlContent.tsx","../shared/client/components/common/List/UnstyledList/UnstyledList.tsx","./components/messages/MessageView/MessageView.tsx","../shared/client/components/common/Pager/PagerLoadMore/PagerLoadMore.tsx","./components/messages/MessageView/MessageViewInline/MessageViewInline.tsx","../shared/client/components/common/List/ListGroup/ListGroup.tsx","./components/customComponent/CustomComponentContent/CustomComponentScripts.tsx"],"appGip":true,"scriptLoader":[]}
