Solved! Go to Solution.
If you don't have the VoLTE (voice over LTE) option activated in the account then yes, it is normal.
@macadacious wrote:How do i activate that?
First you need a compatible device and a compatible sim.
if you have both, you can call customer service to get the option added to your line.
never-displayed
