Avatar de Technonaive
Technonaive
22-02-2022
Using an LG android chip on an iPhone 6
Hello, Do I need a new chip or can I just swab the LG chip onto an iPhone 6 without changing my cell number ?
Thanks.
1 Réponse
  • Avatar de VickyLL
    VickyLL
    Modérateur - Expert solutions
    Hi Technonaive,
    The iPhone 6 requires a Nano SIM card. If your LG device have the same type of SIM card, you can simply insert it in your iPhone 6. Otherwise, a new SIM card is required. Don't worry, you can keep the same phone number with your new SIM card.
    Thank you!
