Technically Videotron and Rogers have the same network for Quebec and Ottawa region... so coverage should be good.
I’ve here some stories here saying that where signal is not good, your device might stick to Freedom network even though videotron doesn’t have roaming agreement with freedom... which will make tour device looks like it’s connected without being really connected. Apparently this is happening mainly with android devices that were not bought from videotron. I never experienced that with my iPhone bought at videotron or directly at the Apple store.","board":{"__ref":"Forum:board:mobilephone-english"},"conversation":{"__ref":"Conversation:conversation:15351"},"author":{"__typename":"User","login":"Anonyme"},"postTime":"2019-09-02T08:04:49.994-04:00","kudosSumWeight":0}},{"__typename":"MessageEdge","cursor":"MjUuNHwyLjF8b3w1fDE2OjAsNDE6MXwy","node":{"__typename":"ForumReplyMessage","uid":16332,"body":"
We've seen the \"Freedom\" issue on an iPhone from Videotron.
Overall, the network works great in Ottawa (should I says networks, as there are multiple network ID?). The main differences between Rogers and Videotron when in Ottawa are
- access to Rogers' band 7 is limited to certain areas (e.g. in malls)
- if you set your phone to 3G, you may end up on Videotron's limited AWS 3G coverage until the phone gives and jumps back to the shared network with Rogers
Although Rogers has added more towers in the last year within the city, the Bell/Telus network have the upper hand, specially when going East of Ottawa (Prescott-Russell) where the tower density is very different between the two of them.
Back on the topic of 3G, in most areas, Bell/Telus' 3G will have faster data.
","board":{"__ref":"Forum:board:mobilephone-english"},"conversation":{"__ref":"Conversation:conversation:15351"},"author":{"__typename":"User","login":"gmd"},"postTime":"2019-09-20T18:52:35.346-04:00","kudosSumWeight":0}},{"__typename":"MessageEdge","cursor":"MjUuNHwyLjF8b3w1fDE2OjAsNDE6MXwz","node":{"__typename":"ForumReplyMessage","uid":16793,"body":"I have experienced the Freedom issue yet on another phone (Adding a OnePlus phone to a Pixel and an iPhone).
Ended up locking the phone on Partner 1 (which for some reason had a better signal than when piggybacking as Videotron). Going back to Auto later made it switch to Telus.
Videotron, stop marking 302-490 as a partner! I'm guessing someone took the easy way out by making Rogers/Fido to be Partner 1 and making all other 302-* as Partner 2.
Is 302-370 (Fido) still used?
","board":{"__ref":"Forum:board:mobilephone-english"},"conversation":{"__ref":"Conversation:conversation:15351"},"author":{"__typename":"User","login":"gmd"},"postTime":"2019-10-04T10:14:52.365-04:00","kudosSumWeight":0}}]},"cachedAsset({\"assetId\":\"Common\",\"assetType\":\"quiltWrapper\",\"lastModified\":\"1749759678282\",\"locale\":\"fr-FR\",\"node\":null})":{"__ref":"CachedAsset:quiltWrapper:videotron.prod:Common:fr-FR-1749759678282"},"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/common/ActionFeedback\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/common/ActionFeedback-1749759678782"}],"cachedAsset({\"assetId\":\"custom.widget.Utility_Nav_FR-fr-FR\",\"assetType\":\"component\",\"lastModified\":\"1749759686875\",\"locale\":null,\"node\":null})":{"__ref":"CachedAsset:component:custom.widget.Utility_Nav_FR-fr-fr-1749759686875"},"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/community/Breadcrumb\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/community/Breadcrumb-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/MessageBanner\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/MessageBanner-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/RelatedContentWidget\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/RelatedContentWidget-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/MessageListForNodeByRecentActivityWidget\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/MessageListForNodeByRecentActivityWidget-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/community/FooterWidget\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/community/FooterWidget-1749759678782"}],"coreNode({\"id\":\"board:mobilephone-english\"})":{"__ref":"Forum:board:mobilephone-english"},"coreNodes({\"constraints\":{\"id\":{\"in\":[\"board:SuperUtilisateurs\",\"category:fr\",\"board:mobile\",\"board:internet-telephonie\",\"board:television-divertissement\",\"board:mon-videotron\",\"board:LeBlogue\"]}},\"first\":7})":{"__typename":"CoreNodeConnection","edges":[{"__typename":"CoreNodeEdge","node":{"__ref":"Category:category:fr"}},{"__typename":"CoreNodeEdge","node":{"__ref":"Forum:board:mobile"}},{"__typename":"CoreNodeEdge","node":{"__ref":"Forum:board:internet-telephonie"}},{"__typename":"CoreNodeEdge","node":{"__ref":"Forum:board:television-divertissement"}},{"__typename":"CoreNodeEdge","node":{"__ref":"Forum:board:mon-videotron"}},{"__typename":"CoreNodeEdge","node":{"__ref":"Blog:board:LeBlogue"}}]},"messages({\"constraints\":{\"boardId\":{\"eq\":\"board:mobilephone-english\"},\"conversationStyle\":{\"eq\":\"FORUM\"},\"depth\":{\"eq\":0}},\"first\":5,\"sorts\":{\"conversationLastPostingActivityTime\":{\"direction\":\"DESC\"}}})":{"__typename":"MessageConnection","edges":[{"__typename":"MessageEdge","cursor":"MjUuNHwyLjF8aXw1fDY6MHxpbnQsMTk3MDEsMTk3MDE","node":{"__ref":"ForumTopicMessage:message:19701"}},{"__typename":"MessageEdge","cursor":"MjUuNHwyLjF8aXw1fDY6MHxpbnQsMTk3MDEsNDg2Mzc","node":{"__ref":"ForumTopicMessage:message:48637"}},{"__typename":"MessageEdge","cursor":"MjUuNHwyLjF8aXw1fDY6MHxpbnQsMTk3MDEsNDgxMzI","node":{"__ref":"ForumTopicMessage:message:48132"}},{"__typename":"MessageEdge","cursor":"MjUuNHwyLjF8aXw1fDY6MHxpbnQsMTk3MDEsNDgzMTI","node":{"__ref":"ForumTopicMessage:message:48312"}},{"__typename":"MessageEdge","cursor":"MjUuNHwyLjF8aXw1fDY6MHxpbnQsMTk3MDEsNDgxNzk","node":{"__ref":"ForumTopicMessage:message:48179"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":true,"endCursor":"MjUuNHwyLjF8aXw1fDY6MHxpbnQsMTk3MDEsNDgxNzk"},"totalCount":302},"relatedContent({\"first\":5,\"post_id\":15351})":{"__typename":"RelatedContentConnection","edges":[{"__typename":"RelatedContentEdge","node":{"__ref":"RelatedContentMessage:RelatedContentMessage:39121"}},{"__typename":"RelatedContentEdge","node":{"__ref":"RelatedContentMessage:RelatedContentMessage:38209"}},{"__typename":"RelatedContentEdge","node":{"__ref":"RelatedContentMessage:RelatedContentMessage:34139"}},{"__typename":"RelatedContentEdge","node":{"__ref":"RelatedContentMessage:RelatedContentMessage:44479"}},{"__typename":"RelatedContentEdge","node":{"__ref":"RelatedContentMessage:RelatedContentMessage:45763"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":true,"endCursor":"MHw0NTc2M3w0fDU7NXx8"}},"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/community/Navbar\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/community/Navbar-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/community/NavbarHamburgerDropdown\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/community/NavbarHamburgerDropdown-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/community/BrandLogo\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/community/BrandLogo-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/community/NavbarTextLinks\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/community/NavbarTextLinks-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"shared/client/components/languages/UseLanguageText\"]})":[{"__ref":"CachedAsset:text:fr_FR-shared/client/components/languages/UseLanguageText-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/languages/LanguagePicker\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/languages/LanguagePicker-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/search/SpotlightSearchIcon\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/search/SpotlightSearchIcon-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/authentication/AuthenticationLink\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/authentication/AuthenticationLink-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/nodes/NodeLink\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/nodes/NodeLink-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/MessageView/MessageViewStandard\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/MessageView/MessageViewStandard-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/ThreadedReplyList\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/ThreadedReplyList-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/MessageReplyCallToAction\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/MessageReplyCallToAction-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"shared/client/components/common/QueryHandler\"]})":[{"__ref":"CachedAsset:text:fr_FR-shared/client/components/common/QueryHandler-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"shared/client/components/common/BuildInformation\"]})":[{"__ref":"CachedAsset:text:fr_FR-shared/client/components/common/BuildInformation-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/community/KhorosLogo\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/community/KhorosLogo-1749759678782"}],"localizedCategoriesByLocale":[{"__typename":"LocalizedCategoryByLocale","locale":"en-US","category":{"__typename":"LocalizedCategory","category":{"__ref":"Category:category:en"}}},{"__typename":"LocalizedCategoryByLocale","locale":"fr-FR","category":{"__typename":"LocalizedCategory","category":{"__ref":"Category:category:fr"}}}],"component({\"componentId\":\"custom.widget.Utility_Nav_FR\"})":{"__typename":"Component","render({\"context\":{\"component\":{\"entities\":[],\"props\":{}},\"page\":{\"entities\":[\"message:15351\"],\"name\":\"ForumMessagePage\",\"props\":{},\"url\":\"https://forum.videotron.com/discussions/mobilephone-english/how-is-videotron-mobile-in-ottawa/15351\"}}})":{"__typename":"ComponentRenderResult","html":""}},"componentScriptGroups({\"componentId\":\"custom.widget.Utility_Nav_FR\"})":{"__typename":"ComponentScriptGroups","scriptGroups":{"__typename":"ComponentScriptGroupsDefinition","afterInteractive":{"__typename":"PageScriptGroupDefinition","group":"AFTER_INTERACTIVE","scriptIds":[]},"lazyOnLoad":{"__typename":"PageScriptGroupDefinition","group":"LAZY_ON_LOAD","scriptIds":[]}},"componentScripts":[]},"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/customComponent/CustomComponent\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/customComponent/CustomComponent-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/community/NavbarDropdownToggle\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/community/NavbarDropdownToggle-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/EscalatedMessageBanner\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/EscalatedMessageBanner-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/users/UserLink\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/users/UserLink-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"shared/client/components/users/UserRank\"]})":[{"__ref":"CachedAsset:text:fr_FR-shared/client/components/users/UserRank-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/MessageTime\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/MessageTime-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/MessageSolvedBadge\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/MessageSolvedBadge-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/MessageSubject\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/MessageSubject-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/MessageBody\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/MessageBody-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/MessageCustomFields\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/MessageCustomFields-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/MessageReplyButton\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/MessageReplyButton-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/MessageListMenu\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/MessageListMenu-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/AcceptedSolutionButton\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/AcceptedSolutionButton-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"shared/client/components/common/Pager/PagerLoadMore\"]})":[{"__ref":"CachedAsset:text:fr_FR-shared/client/components/common/Pager/PagerLoadMore-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/messages/MessageView/MessageViewInline\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/messages/MessageView/MessageViewInline-1749759678782"}],"message({\"id\":\"message:15478\"})":{"__ref":"ForumReplyMessage:message:15478"},"message({\"id\":\"message:16332\"})":{"__ref":"ForumReplyMessage:message:16332"},"message({\"id\":\"message:16793\"})":{"__ref":"ForumReplyMessage:message:16793"},"coreNode({\"id\":\"community:ogevo67675\"})":{"__ref":"Community:community:ogevo67675"},"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"shared/client/components/users/UserAvatar\"]})":[{"__ref":"CachedAsset:text:fr_FR-shared/client/components/users/UserAvatar-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"shared/client/components/ranks/UserRankLabel\"]})":[{"__ref":"CachedAsset:text:fr_FR-shared/client/components/ranks/UserRankLabel-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"components/tags/TagView/TagViewChip\"]})":[{"__ref":"CachedAsset:text:fr_FR-components/tags/TagView/TagViewChip-1749759678782"}],"cachedText({\"lastModified\":\"1749759678782\",\"locale\":\"fr-FR\",\"namespaces\":[\"shared/client/components/nodes/NodeIcon\"]})":[{"__ref":"CachedAsset:text:fr_FR-shared/client/components/nodes/NodeIcon-1749759678782"}]},"Theme:customTheme1":{"__typename":"Theme","id":"customTheme1"},"User:user:-1":{"__typename":"User","id":"user:-1","entityType":"USER","eventPath":"community:ogevo67675/user:-1","uid":-1,"login":"Anonyme","email":"","avatar":null,"rank":null,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":"ANONYMOUS","registrationTime":null,"confirmEmailStatus":false,"registrationAccessLevel":"VIEW","ssoRegistrationFields":[]},"ssoId":null,"profileSettings":{"__typename":"ProfileSettings","dateDisplayStyle":{"__typename":"InheritableStringSettingWithPossibleValues","key":"layout.friendly_dates_enabled","value":"false","localValue":"true","possibleValues":["true","false"]},"dateDisplayFormat":{"__typename":"InheritableStringSetting","key":"layout.format_pattern_date","value":"dd-MM-yyyy","localValue":"MM-dd-yyyy"},"language":{"__typename":"InheritableStringSettingWithPossibleValues","key":"profile.language","value":"fr-FR","localValue":null,"possibleValues":["en-US","fr-FR"]},"repliesSortOrder":{"__typename":"InheritableStringSettingWithPossibleValues","key":"config.user_replies_sort_order","value":"DEFAULT","localValue":"DEFAULT","possibleValues":["DEFAULT","LIKES","PUBLISH_TIME","REVERSE_PUBLISH_TIME"]}},"deleted":false,"biography":null},"CachedAsset:pages-1749759874727":{"__typename":"CachedAsset","id":"pages-1749759874727","value":[{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"BlogViewAllPostsPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId/all-posts/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"CasePortalPage","type":"CASE_PORTAL","urlPath":"/caseportal","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"CreateGroupHubPage","type":"GROUP_HUB","urlPath":"/groups/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"CaseViewPage","type":"CASE_DETAILS","urlPath":"/case/:caseId/:caseNumber","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"InboxPage","type":"COMMUNITY","urlPath":"/inbox","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"HelpFAQPage","type":"COMMUNITY","urlPath":"/help","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"IdeaMessagePage","type":"IDEA_POST","urlPath":"/idea/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"IdeaViewAllIdeasPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/all-ideas/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"LoginPage","type":"USER","urlPath":"/signin","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"WorkstreamsPage","type":"COMMUNITY","urlPath":"/workstreams","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"BlogPostPage","type":"BLOG","urlPath":"/category/:categoryId/blogs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"ThemeEditorPage","type":"COMMUNITY","urlPath":"/designer/themes","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"TkbViewAllArticlesPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId/all-articles/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"OccasionEditPage","type":"EVENT","urlPath":"/event/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"OAuthAuthorizationAllowPage","type":"USER","urlPath":"/auth/authorize/allow","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"PageEditorPage","type":"COMMUNITY","urlPath":"/designer/pages","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"PostPage","type":"COMMUNITY","urlPath":"/category/:categoryId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"ForumBoardPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"TkbBoardPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"EventPostPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"UserBadgesPage","type":"COMMUNITY","urlPath":"/users/:login/:userId/badges","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"GroupHubMembershipAction","type":"GROUP_HUB","urlPath":"/membership/join/:nodeId/:membershipType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"MaintenancePage","type":"COMMUNITY","urlPath":"/maintenance","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"IdeaReplyPage","type":"IDEA_REPLY","urlPath":"/idea/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"UserSettingsPage","type":"USER","urlPath":"/mysettings/:userSettingsTab","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"GroupHubsPage","type":"GROUP_HUB","urlPath":"/groups","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"ForumPostPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"OccasionRsvpActionPage","type":"OCCASION","urlPath":"/event/:boardId/:messageSubject/:messageId/rsvp/:responseType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"VerifyUserEmailPage","type":"USER","urlPath":"/verifyemail/:userId/:verifyEmailToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"AllOccasionsPage","type":"OCCASION","urlPath":"/category/:categoryId/events/:boardId/all-events/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"EventBoardPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"TkbReplyPage","type":"TKB_REPLY","urlPath":"/kb/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"IdeaBoardPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"CommunityGuideLinesPage","type":"COMMUNITY","urlPath":"/communityguidelines","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"CaseCreatePage","type":"SALESFORCE_CASE_CREATION","urlPath":"/caseportal/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"TkbEditPage","type":"TKB","urlPath":"/kb/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"ForgotPasswordPage","type":"USER","urlPath":"/forgotpassword","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"IdeaEditPage","type":"IDEA","urlPath":"/idea/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"TagPage","type":"COMMUNITY","urlPath":"/tag/:tagName","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"BlogBoardPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"OccasionMessagePage","type":"OCCASION_TOPIC","urlPath":"/event/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"ManageContentPage","type":"COMMUNITY","urlPath":"/managecontent","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"ClosedMembershipNodeNonMembersPage","type":"GROUP_HUB","urlPath":"/closedgroup/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"CommunityPage","type":"COMMUNITY","urlPath":"/","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"ForumMessagePage","type":"FORUM_TOPIC","urlPath":"/discussions/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"IdeaPostPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"BlogMessagePage","type":"BLOG_ARTICLE","urlPath":"/blog/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"RegistrationPage","type":"USER","urlPath":"/register","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"EditGroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"ForumEditPage","type":"FORUM","urlPath":"/discussions/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"ResetPasswordPage","type":"USER","urlPath":"/resetpassword/:userId/:resetPasswordToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"TkbMessagePage","type":"TKB_ARTICLE","urlPath":"/kb/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"BlogEditPage","type":"BLOG","urlPath":"/blog/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"ManageUsersPage","type":"USER","urlPath":"/users/manage/:tab?/:manageUsersTab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"ForumReplyPage","type":"FORUM_REPLY","urlPath":"/discussions/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"PrivacyPolicyPage","type":"COMMUNITY","urlPath":"/privacypolicy","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"NotificationPage","type":"COMMUNITY","urlPath":"/notifications","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"UserPage","type":"USER","urlPath":"/users/:login/:userId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"HealthCheckPage","type":"COMMUNITY","urlPath":"/health","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"OccasionReplyPage","type":"OCCASION_REPLY","urlPath":"/event/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"ManageMembersPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/manage/:tab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"SearchResultsPage","type":"COMMUNITY","urlPath":"/search","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"BlogReplyPage","type":"BLOG_REPLY","urlPath":"/blog/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"GroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"TermsOfServicePage","type":"COMMUNITY","urlPath":"/termsofservice","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"CategoryPage","type":"CATEGORY","urlPath":"/category/:categoryId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"ForumViewAllTopicsPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/all-topics/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"TkbPostPage","type":"TKB","urlPath":"/category/:categoryId/kbs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1749759874727,"localOverride":null,"page":{"id":"GroupHubPostPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"}],"localOverride":false},"CachedAsset:text:fr_FR-components/context/AppContext/AppContextProvider-0":{"__typename":"CachedAsset","id":"text:fr_FR-components/context/AppContext/AppContextProvider-0","value":{"noCommunity":"Impossible de trouver la communauté","noUser":"Impossible de trouver l'utilisateur actuel","noNode":"Impossible de trouver le nœud avec l'identifiant {nodeId}","noMessage":"Impossible de trouver le message avec l'identifiant {messageId}","userBanned":"Nous sommes désolés, mais vous avez été banni de l'utilisation de ce site.","userBannedReason":"Vous avez été banni pour la raison suivante : {reason}"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/common/Loading/LoadingDot-0":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/common/Loading/LoadingDot-0","value":{"title":"Chargement..."},"localOverride":false},"Rank:rank:18":{"__typename":"Rank","id":"rank:18","position":36,"name":"Squire","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:11291":{"__typename":"User","id":"user:11291","uid":11291,"login":"silence000","deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-10.svg?time=0"},"rank":{"__ref":"Rank:rank:18"},"email":"","messagesCount":3,"biography":null,"topicsCount":2,"kudosReceivedCount":0,"kudosGivenCount":0,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2019-08-30T05:24:32.794-04:00","confirmEmailStatus":null},"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:11291"},"Category:category:en":{"__typename":"Category","id":"category:en","entityType":"CATEGORY","displayId":"en","nodeType":"category","depth":1,"title":"English","shortTitle":"English","parent":{"__ref":"Category:category:top"}},"Category:category:top":{"__typename":"Category","id":"category:top","entityType":"CATEGORY","displayId":"top","nodeType":"category","depth":0,"title":"Top","shortTitle":"Top"},"Forum:board:mobilephone-english":{"__typename":"Forum","id":"board:mobilephone-english","entityType":"FORUM","displayId":"mobilephone-english","nodeType":"board","depth":2,"conversationStyle":"FORUM","repliesProperties":{"__typename":"RepliesProperties","sortOrder":"LIKES","repliesFormat":"threaded"},"tagProperties":{"__typename":"TagNodeProperties","tagsEnabled":{"__typename":"PolicyResult","failureReason":null}},"requireTags":false,"tagType":"PRESET_ONLY","description":"Find all the answers to your mobile questions: devices, networks, plans, features, apps . . . it’s all here!","title":"Mobility","shortTitle":"Mobility","parent":{"__ref":"Category:category:en"},"ancestors":{"__typename":"CoreNodeConnection","edges":[{"__typename":"CoreNodeEdge","node":{"__ref":"Community:community:ogevo67675"}},{"__typename":"CoreNodeEdge","node":{"__ref":"Category:category:en"}}]},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"theme":{"__ref":"Theme:customTheme1"},"boardPolicies":{"__typename":"BoardPolicies","canViewSpamDashBoard":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.access_spam_quarantine.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.access_spam_quarantine.allowed.accessDenied","args":[]}},"canArchiveMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.content_archivals.enable_content_archival_settings.accessDenied","key":"error.lithium.policies.content_archivals.enable_content_archival_settings.accessDenied","args":[]}},"canPublishArticleOnCreate":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","key":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","args":[]}}},"linkProperties":{"__typename":"LinkProperties","isExternalLinkWarningEnabled":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yNS0xOTU3aUZCNDQ3NkMyNzJEOUFEMEI\"}"},"eventPath":"category:en/community:ogevo67675board:mobilephone-english/"},"ForumTopicMessage:message:15351":{"__typename":"ForumTopicMessage","uid":15351,"subject":"How is Videotron mobile in Ottawa???","id":"message:15351","entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:15351","revisionNum":1,"repliesCount":3,"author":{"__ref":"User:user:11291"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:mobilephone-english"},"conversation":{"__ref":"Conversation:conversation:15351"},"readOnly":false,"editFrozen":false,"showMoveIndicator":false,"moderationData":{"__ref":"ModerationData:moderation_data:15351"},"body":"I have had it with Bell mobile. Lately I noticed their customer service (or lack there of) has been declining quickly. The only reason why I stayed this long with them was because I had an awesome plan that was grandfathered in and I had 2 other lines (mom and her sister) that I would have had to move over too. In the past two week I had a lot of BS that made me want to take a look at competitors and see what I can get.
Videotron has a great deal if I bring my own phone and is only $5 more a month but I'm not sure how their reception or services is in Ontario since its a Quebec company. They also give an additional discount if I have 3 lines which is even better!
Does anyone have any insights on how Videotron is overall?
","body@stringLength":"845","rawBody":"I have had it with Bell mobile. Lately I noticed their customer service (or lack there of) has been declining quickly. The only reason why I stayed this long with them was because I had an awesome plan that was grandfathered in and I had 2 other lines (mom and her sister) that I would have had to move over too. In the past two week I had a lot of BS that made me want to take a look at competitors and see what I can get.
","kudosSumWeight":0,"postTime":"2019-08-30T05:26:07.224-04:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjUuNHwyLjF8b3wxMHxfTlZffDE","node":{"__typename":"Tag","id":"tag:Roaming","text":"Roaming","time":"2018-04-27T13:32:57.577-04:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuNHwyLjF8b3wxMHxfTlZffDI","node":{"__typename":"Tag","id":"tag:Update","text":"Update","time":"2018-11-06T14:31:38.525-05:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:15351_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":5797},"read":false,"visibilityScope":"PUBLIC","canonicalUrl":null,"seoTitle":null,"seoDescription":null,"isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"archivalData":null,"searchSnippet":"I have had it with Bell mobile. Lately I noticed their customer service (or lack there of) has been declining quickly. The only reason why I stayed this long with them was because I had an awesome pl...","replies":{"__typename":"MessageConnection","edges":[{"__typename":"MessageEdge","cursor":"MjUuNHwyLjF8aXwxMHw0MTowfGludCwxNTQ3OCwxNTQ3OA","node":{"__ref":"ForumReplyMessage:message:15478"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[]},"Conversation:conversation:15351":{"__typename":"Conversation","id":"conversation:15351","solved":false,"topic":{"__ref":"ForumTopicMessage:message:15351"},"lastPostingActivityTime":"2019-10-04T10:14:52.365-04:00","lastPostTime":"2019-10-04T10:14:52.365-04:00","unreadReplyCount":3,"isSubscribed":false},"ModerationData:moderation_data:15351":{"__typename":"ModerationData","id":"moderation_data:15351","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:15351_1":{"__typename":"Revision","id":"revision:15351_1","lastEditTime":"2019-08-30T05:26:07.224-04:00"},"CachedAsset:theme:customTheme1-1749759679998":{"__typename":"CachedAsset","id":"theme:customTheme1-1749759679998","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"50%","collections":["default"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"Favicon-1730465696192.png","imageLastModified":"1730465698198","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"logo-videotron_header2fr-1730818064436.png","imageLastModified":"1730818067042","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1300px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_BROWSER","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"3px","borderRadius":"3px","borderRadiusLg":"5px","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"12px","paddingXLg":"16px","paddingXHero":"60px","fontStyle":"NORMAL","fontWeight":"700","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-body-bg)","primaryTextHoverColor":"var(--lia-bs-body-bg)","primaryTextActiveColor":"var(--lia-bs-body-bg)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-primary)","secondaryTextHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.9))","secondaryBgColor":"#FDD200","secondaryBgHoverColor":"hsl(49.80000000000001, 100%, 47.6%)","secondaryBgActiveColor":"hsl(49.80000000000001, 100%, 45.6%)","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-gray-900)","tertiaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-danger)","destructiveTextHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.95))","destructiveTextActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.9))","destructiveBgColor":"var(--lia-bs-gray-200)","destructiveBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","destructiveBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"LIGHT","sideContent":"NONE","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08)","sm":"0","md":"0","lg":"0","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"var(--lia-bs-link-color)","defaultMessageLinkDecoration":"underline","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","defaultMessageFontFamily":"var(--lia-bs-font-family-base)","forumColor":"#000000","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#24AD72","blogColor":"#000000","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#E06643","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#FF8000","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#D13A1F","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#FFDE45","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#000000","secondary":"#333333","bodyText":"#575754","bodyBg":"#FFFFFF","info":"#FFD200","success":"#24AD72","warning":"#DA8000","danger":"#C14D00","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#FDD200","#C14D00"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":{"link":{"color":"#0069D4","hoverColor":"#0061c2","decoration":"none","hoverDecoration":"underline","__typename":"EmailLinkSettings"},"border":{"color":"#e4e4e4","__typename":"EmailBorderSettings"},"buttons":{"borderRadiusLg":"5px","paddingXLg":"16px","paddingYLg":"7px","fontWeight":"700","primaryTextColor":"#ffffff","primaryTextHoverColor":"#ffffff","primaryBgColor":"#0069D4","primaryBgHoverColor":"#005cb8","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","__typename":"EmailButtonsSettings"},"panel":{"borderRadius":"5px","borderColor":"#e4e4e4","__typename":"EmailPanelSettings"},"__typename":"EmailThemeSettings"},"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Blender Pro Book","fontStyle":"NORMAL","fontWeight":"500","h1FontSize":"52px","h2FontSize":"36px","h3FontSize":"24px","h4FontSize":"22px","h5FontSize":"16px","h6FontSize":"14px","lineHeight":"1.3","subHeaderFontSize":"11px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":"10px","size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"var(--lia-bs-border-radius-sm)","borderRadius":"var(--lia-bs-border-radius)","borderRadiusLg":"var(--lia-bs-border-radius-lg)","formTextMarginTop":"4px","textAreaBorderRadius":"var(--lia-bs-border-radius)","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-black)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":"","imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"40px","defaultMessageHeaderMarginBottom":"20px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"30px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"40px","specialMessageHeaderMarginBottom":"20px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"30px","tableBgColor":"transparent","tableBorderColor":"var(--lia-bs-gray-700)","tableBorderStyle":"solid","tableCellPaddingX":"5px","tableCellPaddingY":"5px","tableTextColor":"var(--lia-bs-body-color)","tableVerticalAlign":"middle","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Open Sans","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.5","fontSizeBase":"16px","fontSizeXxs":"11px","fontSizeXs":"12px","fontSizeSm":"14px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Crossten Book-V","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"},{"style":"NORMAL","weight":"500","__typename":"FontStyleData"},{"style":"NORMAL","weight":"700","__typename":"FontStyleData"},{"style":"NORMAL","weight":"300","__typename":"FontStyleData"},{"style":"NORMAL","weight":"600","__typename":"FontStyleData"}],"assetNames":["CrosstenBook-V-normal-400.woff2","CrosstenBook-V-normal-500.woff2","CrosstenBook-V-normal-700.woff2","CrosstenBook-V-normal-300.woff2","CrosstenBook-V-normal-600.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Blender Pro Book","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"},{"style":"NORMAL","weight":"500","__typename":"FontStyleData"},{"style":"NORMAL","weight":"700","__typename":"FontStyleData"},{"style":"ITALIC","weight":"400","__typename":"FontStyleData"}],"assetNames":["BlenderProBook-normal-400.woff2","BlenderProBook-normal-500.woff2","BlenderProBook-normal-700.woff2","BlenderProBook-italic-400.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/common/Loading/LoadingDot-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/common/Loading/LoadingDot-1749759678782","value":{"title":"Chargement..."},"localOverride":false},"CachedAsset:quilt:videotron.prod:pages/forums/ForumMessagePage:board:mobilephone-english-1749759677817":{"__typename":"CachedAsset","id":"quilt:videotron.prod:pages/forums/ForumMessagePage:board:mobilephone-english-1749759677817","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"MAIN_SIDE","bgColor":null,"showTitle":null,"showDescription":null,"textPosition":null,"textColor":null,"sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"MainSideQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"messages.widget.relatedContentWidget","className":null,"props":{"hideIfEmpty":true,"enablePagination":false,"useTitle":true,"listVariant":{"type":"unstyled","props":{"listItemSpacing":"xxl"}},"pageSize":5,"style":"compact","pagerVariant":{"type":"none"},"viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"useCompactSpacing":true,"boardIconSize":"24","useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useNodeLink":true,"useViewCount":false,"usePreviewMedia":true,"useBody":false,"timeStampType":"postTime","useTags":false,"clampSubjectLines":2,"useBoardIcon":true,"useMessageTimeLink":true,"useTextBody":true,"useSolvedBadge":false,"renderPostTimeBeforeAuthor":true,"useAvatar":false,"useAuthorLogin":true,"useVideoPreview":false}},"lazyLoad":false,"panelType":"standard"},"__typename":"QuiltComponent"},{"id":"messages.widget.messageListForNodeByRecentActivityWidget","className":null,"props":{"hideIfEmpty":true,"useTitle":true,"showTabs":false,"pageSize":5,"pagerVariant":{"type":"loadMore"},"style":"compact","viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","truncateBodyLength":-1,"useNodeLink":true,"usePreviewMedia":false,"timeStampType":"conversation.lastPostingActivityTime","avatarSize":"40","useTextBody":true,"useSolvedBadge":true,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":true,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":false,"useMessageTimeLink":true,"clampBodyLines":3,"useAuthorLogin":true,"useUnreadCount":false,"useNodeHoverCard":true,"useSearchSnippet":false}},"panelType":"divider","sorts":{"conversationLastPostingActivityTime":{"direction":"DESC"}}},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:fr_FR-components/common/EmailVerification-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/common/EmailVerification-1749759678782","value":{"email.verification.title":"Vérification de l'adresse e-mail requise","email.verification.message.update.email":"Pour participer à la communauté, vous devez d'abord vérifier votre adresse e-mail. L'e-mail de vérification a été envoyé à {email}. Pour changer votre adresse e-mail, visitez Mes paramètres .","email.verification.message.resend.email":"Pour participer à la communauté, vous devez d'abord vérifier votre adresse e-mail. L'e-mail de vérification a été envoyé à {email}. Renvoyer l'e-mail ."},"localOverride":false},"CachedAsset:text:fr_FR-pages/forums/ForumMessagePage-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-pages/forums/ForumMessagePage-1749759678782","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"Ce message est introuvable","name":"Page de message de Forum","section.message-list.title":"Discussion de forum","archivedMessageTitle":"Ce contenu a été archivé"},"localOverride":false},"CachedAsset:quiltWrapper:videotron.prod:Common:fr-FR-1749759678282":{"__typename":"CachedAsset","id":"quiltWrapper:videotron.prod:Common:fr-FR-1749759678282","value":{"id":"Common_oIbWvI","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"custom.widget.Utility_Nav_FR","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"usePageWidth":true,"backgroundColor":"var(--lia-bs-primary)","useBackground":false,"backgroundOpacity":1,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"community.widget.navbarWidget","props":{"showUserName":false,"showRegisterLink":true,"useIconLanguagePicker":true,"showLanguagePicker":true,"useLabelLanguagePicker":true,"links":{"sideLinks":[],"mainLinks":[{"children":[],"linkType":"INTERNAL","id":"super-utilisateurs-link","params":{"boardId":"SuperUtilisateurs","categoryId":"SuperUtilisateurs"},"routeName":"ForumBoardPage"},{"children":[{"linkType":"INTERNAL","id":"mobile-link","params":{"boardId":"mobile","categoryId":"fr"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"internet-telephonie-link","params":{"boardId":"internet-telephonie","categoryId":"fr"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"television-divertissement-link","params":{"boardId":"television-divertissement","categoryId":"fr"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"mon-videotron-link","params":{"boardId":"mon-videotron","categoryId":"fr"},"routeName":"ForumBoardPage"}],"linkType":"INTERNAL","id":"fr-link","params":{"categoryId":"fr"},"routeName":"CategoryPage"},{"children":[],"linkType":"INTERNAL","id":"le-blogue-link","params":{"boardId":"LeBlogue","categoryId":"fr"},"routeName":"BlogBoardPage"},{"children":[],"linkType":"EXTERNAL","id":"external-link","url":"https://forum.videotron.com/help","target":"SELF"}]},"className":"QuiltComponent_lia-component-edit-mode__0nCcm","style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"400","controllerHighlightColor":"#C14D00","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"14px","linkBoxShadowHover":"none","backgroundOpacity":0.8,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"52px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"5px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"1px solid var(--lia-bs-border-color)","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"flex-start","linkColor":"var(--lia-bs-body-color)","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerHighlightTextColor":"var(--lia-yiq-light)","background":{"imageAssetName":"","color":"var(--lia-bs-white)","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"var(--lia-bs-primary)","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"0","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"5px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-body-color)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-body-color)"},"showSearchIcon":true,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":{"backgroundColor":"#FDD200","visualEffects":{"showBottomBorder":true},"backgroundOpacity":100,"backgroundImageProps":{"assetName":"community-widget-bannerWidget-1733422118937.png","backgroundSize":"COVER","lastModified":"1733422120000","backgroundPosition":"CENTER_CENTER","backgroundRepeat":"NO_REPEAT"},"fontColor":"var(--lia-bs-primary)"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"transparent","linkHighlightColor":"var(--lia-bs-primary)","visualEffects":{"showBottomBorder":true},"linkTextColor":"var(--lia-bs-gray-700)"},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"var(--lia-bs-primary)","items":[{"id":"community.widget.footerWidget","props":null,"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:text:fr_FR-components/common/ActionFeedback-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/common/ActionFeedback-1749759678782","value":{"joinedGroupHub.title":"Bienvenue","joinedGroupHub.message":"Vous êtes maintenant membre de ce groupe et abonné aux mises à jour.","groupHubInviteNotFound.title":"Invitation non trouvée","groupHubInviteNotFound.message":"Désolé, nous n'avons pas trouvé votre invitation au groupe. Le propriétaire a peut-être annulé l'invitation.","groupHubNotFound.title":"Groupe introuvable","groupHubNotFound.message":"Le grouphub que vous avez essayé de rejoindre n'existe pas. Il a peut-être été supprimé.","existingGroupHubMember.title":"Déjà membre","existingGroupHubMember.message":"Vous êtes déjà membre de ce groupe.","accountLocked.title":"Compte verrouillé","accountLocked.message":"Votre compte a été verrouillé en raison de plusieurs tentatives infructueuses. Réessayez dans {lockoutTime} minutes.","editedGroupHub.title":"Modifications enregistrées","editedGroupHub.message":"Votre groupe a été mis à jour.","leftGroupHub.title":"Au revoir","leftGroupHub.message":"Vous n'êtes plus membre de ce groupe et ne recevrez plus de mises à jour à l'avenir.","deletedGroupHub.title":"Supprimé","deletedGroupHub.message":"Le groupe a été supprimé.","groupHubCreated.title":"Groupe créé","groupHubCreated.message":"{groupHubName} est prêt à être utilisé","accountClosed.title":"Compte fermé","accountClosed.message":"Le compte a été fermé et vous serez maintenant redirigé vers la page d'accueil.","resetTokenExpired.title":"Le lien de réinitialisation du mot de passe a expiré","resetTokenExpired.message":"Essayez de réinitialiser votre mot de passe à nouveau","invalidUrl.title":"URL invalide","invalidUrl.message":"L'URL que vous utilisez n'est pas reconnue. Vérifiez votre URL et réessayez.","accountClosedForUser.title":"Compte fermé","accountClosedForUser.message":"Le compte de {userName} est fermé","inviteTokenInvalid.title":"Invitation invalide","inviteTokenInvalid.message":"Votre invitation à la communauté a été annulée ou a expiré.","inviteTokenError.title":"Erreur de vérification de l'invitation","inviteTokenError.message":"L'URL que vous utilisez n'est pas reconnue. Vérifiez votre URL et réessayez.","pageNotFound.title":"Accès refusé","pageNotFound.message":"Vous n'avez pas accès à cette zone de la communauté ou elle n'existe pas","eventAttending.title":"Répondu comme participant","eventAttending.message":"Vous serez notifié en cas d'activité et rappelé à l'approche de l'événement","eventInterested.title":"Répondu comme intéressé","eventInterested.message":"Vous serez notifié en cas d'activité et rappelé à l'approche de l'événement","eventNotFound.title":"Événement introuvable","eventNotFound.message":"L'événement auquel vous avez essayé de répondre n'existe pas.","redirectToRelatedPage.title":"Affichage du Contenu Connexe","redirectToRelatedPageForBaseUsers.title":"Affichage du Contenu Connexe","redirectToRelatedPageForBaseUsers.message":"Le contenu que vous essayez d'accéder est archivé","redirectToRelatedPage.message":"Le contenu que vous essayez d'accéder est archivé","relatedUrl.archivalLink.flyoutMessage":"Le contenu que vous essayez d'accéder est archivé Voir le Contenu Archivé"},"localOverride":false},"CachedAsset:component:custom.widget.Utility_Nav_FR-fr-fr-1749759686875":{"__typename":"CachedAsset","id":"component:custom.widget.Utility_Nav_FR-fr-fr-1749759686875","value":{"component":{"id":"custom.widget.Utility_Nav_FR","template":{"id":"Utility_Nav_FR","markupLanguage":"HTML","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Utility_Nav_FR","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:text:fr_FR-components/community/Breadcrumb-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/Breadcrumb-1749759678782","value":{"navLabel":"Fil d'Ariane","dropdown":"Navigation supplémentaire des parents de la page"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageBanner-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageBanner-1749759678782","value":{"messageMarkedAsSpam":"Ce post a été marqué comme pourriel","messageMarkedAsSpam@board:TKB":"Cet article a été marqué comme pourriel","messageMarkedAsSpam@board:BLOG":"Ce post a été marqué comme pourriel","messageMarkedAsSpam@board:FORUM":"Cette discussion a été marquée comme pourriel","messageMarkedAsSpam@board:OCCASION":"Cet événement a été marqué comme pourriel","messageMarkedAsSpam@board:IDEA":"Cette idée a été marquée comme pourriel","manageSpam":"Gérer le pourriel","messageMarkedAsAbuse":"Ce message a été marqué comme abus","messageMarkedAsAbuse@board:TKB":"Cet article a été marqué comme abus","messageMarkedAsAbuse@board:BLOG":"Ce poste a été marqué comme abus","messageMarkedAsAbuse@board:FORUM":"Cette discussion a été marquée comme abus","messageMarkedAsAbuse@board:OCCASION":"Cet événement a été marqué comme abus","messageMarkedAsAbuse@board:IDEA":"Cette idée a été marquée comme abus","preModCommentAuthorText":"Ce commentaire sera publié dès qu'il aura été approuvé","preModCommentModeratorText":"Ce commentaire est en attente de modération","messageMarkedAsOther":"Ce message a été rejeté pour d'autres raisons","messageMarkedAsOther@board:TKB":"Cet article a été rejeté pour d'autres raisons","messageMarkedAsOther@board:BLOG":"Ce poste a été rejeté pour d'autres raisons","messageMarkedAsOther@board:FORUM":"Cette discussion a été rejetée pour d'autres raisons","messageMarkedAsOther@board:OCCASION":"Cet événement a été rejeté pour d'autres raisons","messageMarkedAsOther@board:IDEA":"Cette idée a été rejetée pour d'autres raisons","messageArchived":"Ce poste a été archivé le {date}","relatedUrl":"Voir le contenu associé","relatedContentText":"Affichage du contenu associé","archivedContentLink":"Voir le contenu archivé"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/RelatedContentWidget-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/RelatedContentWidget-1749759678782","value":{"title":"Contenu connexe","emptyDescription":"Aucun contenu à afficher"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageListForNodeByRecentActivityWidget-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageListForNodeByRecentActivityWidget-1749759678782","value":{"title@userScope:other":"Contenu récent","title@userScope:self":"Contributions","title@board:FORUM@userScope:other":"Discussions récentes","title@board:BLOG@userScope:other":"Blogs récents","emptyDescription":"Pas de contenu à afficher","MessageListForNodeByRecentActivityWidgetEditor.nodeScope.label":"Portée","title@instance:1729793844493":"Recent Blogs"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/FooterWidget-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/FooterWidget-1749759678782","value":{"homeLink":"Accueil de La Communauté","topOfPage":"Haut de page","buildHash":"Hash de Build :","buildNumber":"Numéro de Build :","buildTime":"Date de Build :","privacyPolicy":"Politique de confidentialité","helpLink":"Aide"},"localOverride":false},"Category:category:fr":{"__typename":"Category","id":"category:fr","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"CATEGORY","displayId":"fr","nodeType":"category","depth":1,"title":"Français","shortTitle":"Français"},"Forum:board:mobile":{"__typename":"Forum","id":"board:mobile","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"FORUM","displayId":"mobile","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"Mobilité","shortTitle":"Mobilité","parent":{"__ref":"Category:category:fr"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0xOC0xOTYyaTNDRTVEMjM2OTczMTZENjI\"}"},"description":"Trouvez toutes les réponses à vos questions concernant votre mobile : appareil, forfait, options, applications, réseau… C’est ici que ça se passe!","eventPath":"category:fr/community:ogevo67675board:mobile/"},"Forum:board:internet-telephonie":{"__typename":"Forum","id":"board:internet-telephonie","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:television-divertissement":{"__typename":"Forum","id":"board:television-divertissement","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:mon-videotron":{"__typename":"Forum","id":"board:mon-videotron","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Blog:board:LeBlogue":{"__typename":"Blog","id":"board:LeBlogue","blogPolicies":{"__typename":"BlogPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Conversation:conversation:19701":{"__typename":"Conversation","id":"conversation:19701","topic":{"__typename":"ForumTopicMessage","uid":19701},"lastPostingActivityTime":"2025-06-02T06:38:02.062-04:00","solved":false},"ForumTopicMessage:message:19701":{"__typename":"ForumTopicMessage","subject":"The Worst Company","conversation":{"__ref":"Conversation:conversation:19701"},"id":"message:19701","entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:19701","revisionNum":1,"uid":19701,"depth":0,"board":{"__ref":"Forum:board:mobilephone-english"},"author":{"__typename":"User","uid":13149,"login":"zaidk","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-11.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":4705},"postTime":"2020-02-26T10:22:44.033-05:00","lastPublishTime":"2020-02-26T10:22:44.033-05:00","readOnly":false},"Conversation:conversation:48637":{"__typename":"Conversation","id":"conversation:48637","topic":{"__typename":"ForumTopicMessage","uid":48637},"lastPostingActivityTime":"2025-05-14T02:33:01.163-04:00","solved":false},"ForumTopicMessage:message:48637":{"__typename":"ForumTopicMessage","subject":"Fréquences 5G NR","conversation":{"__ref":"Conversation:conversation:48637"},"id":"message:48637","entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:48637","revisionNum":1,"uid":48637,"depth":0,"board":{"__ref":"Forum:board:mobilephone-english"},"author":{"__typename":"User","uid":34851,"login":"Nano","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-5.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":48},"postTime":"2025-05-08T18:14:47.571-04:00","lastPublishTime":"2025-05-08T18:14:47.571-04:00","readOnly":false},"Conversation:conversation:48132":{"__typename":"Conversation","id":"conversation:48132","topic":{"__typename":"ForumTopicMessage","uid":48132},"lastPostingActivityTime":"2025-05-09T17:04:37.038-04:00","solved":false},"ForumTopicMessage:message:48132":{"__typename":"ForumTopicMessage","subject":"Forfait cellulaire USA maximum 120 jrs","conversation":{"__ref":"Conversation:conversation:48132"},"id":"message:48132","entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:48132","revisionNum":1,"uid":48132,"depth":0,"board":{"__ref":"Forum:board:mobilephone-english"},"author":{"__typename":"User","uid":34409,"login":"DB1","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-3.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":63},"postTime":"2025-02-05T09:15:20.115-05:00","lastPublishTime":"2025-02-05T09:15:20.115-05:00","readOnly":false},"Conversation:conversation:48312":{"__typename":"Conversation","id":"conversation:48312","topic":{"__typename":"ForumTopicMessage","uid":48312},"lastPostingActivityTime":"2025-04-24T06:38:55.113-04:00","solved":false},"ForumTopicMessage:message:48312":{"__typename":"ForumTopicMessage","subject":"5G+ ?","conversation":{"__ref":"Conversation:conversation:48312"},"id":"message:48312","entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:48312","revisionNum":1,"uid":48312,"depth":0,"board":{"__ref":"Forum:board:mobilephone-english"},"author":{"__typename":"User","uid":34571,"login":"Latitude57","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-10.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":88},"postTime":"2025-03-07T21:35:09.296-05:00","lastPublishTime":"2025-03-07T21:35:09.296-05:00","readOnly":false},"Conversation:conversation:48179":{"__typename":"Conversation","id":"conversation:48179","topic":{"__typename":"ForumTopicMessage","uid":48179},"lastPostingActivityTime":"2025-02-21T12:07:06.967-05:00","solved":false},"ForumTopicMessage:message:48179":{"__typename":"ForumTopicMessage","subject":"Ottawa Coverage/Data speeds","conversation":{"__ref":"Conversation:conversation:48179"},"id":"message:48179","entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:48179","revisionNum":1,"uid":48179,"depth":0,"board":{"__ref":"Forum:board:mobilephone-english"},"author":{"__typename":"User","uid":7789,"login":"davelewis","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-1.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":132},"postTime":"2025-02-09T21:22:10.313-05:00","lastPublishTime":"2025-02-09T21:22:10.313-05:00","readOnly":false},"Rank:rank:19":{"__typename":"Rank","id":"rank:19","position":37,"name":"Initiate","color":null,"icon":null,"rankStyle":"TEXT"},"User:user:30716":{"__typename":"User","id":"user:30716","uid":30716,"login":"teddo","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2022-12-29T12:43:18.013-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-11.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":1,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:30716"},"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yNS0xOTU3aUZCNDQ3NkMyNzJEOUFEMEI\"}":{"__typename":"AssociatedImage","url":"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yNS0xOTU3aUZCNDQ3NkMyNzJEOUFEMEI","mimeType":"image/svg+xml"},"ForumTopicMessage:message:39121":{"__typename":"ForumTopicMessage","uid":39121,"subject":"5G coverage in Ottawa?","id":"message:39121","entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:39121","revisionNum":1,"repliesCount":10,"author":{"__ref":"User:user:30716"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:mobilephone-english"},"conversation":{"__ref":"Conversation:conversation:39121"},"moderationData":{"__ref":"ModerationData:moderation_data:39121"},"postTime":"2022-12-29T12:41:57.106-05:00","lastPublishTime":"2022-12-29T12:41:57.106-05:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":11693},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:39121":{"__typename":"Conversation","id":"conversation:39121","solved":true,"topic":{"__ref":"ForumTopicMessage:message:39121"},"lastPostingActivityTime":"2024-03-26T07:17:45.904-04:00","lastPostTime":"2024-03-26T07:17:45.904-04:00","isSubscribed":false},"ModerationData:moderation_data:39121":{"__typename":"ModerationData","id":"moderation_data:39121","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:39121":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:39121","relatedMessage":{"__ref":"ForumTopicMessage:message:39121"}},"Rank:rank:17":{"__typename":"Rank","id":"rank:17","position":35,"name":"Disciple","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:30431":{"__typename":"User","id":"user:30431","uid":30431,"login":"homer1959","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2022-09-22T18:26:38.800-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-10.svg?time=0"},"rank":{"__ref":"Rank:rank:17"},"messagesCount":16,"kudosGivenCount":4,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:30431"},"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0xOC0xOTYyaTNDRTVEMjM2OTczMTZENjI\"}":{"__typename":"AssociatedImage","url":"https://forum.videotron.com/t5/s/ogevo67675/images/bi0xOC0xOTYyaTNDRTVEMjM2OTczMTZENjI","mimeType":"image/svg+xml"},"ForumTopicMessage:message:38209":{"__typename":"ForumTopicMessage","uid":38209,"subject":"Me joindre a Videotron mobile","id":"message:38209","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:mobile/message:38209","revisionNum":1,"repliesCount":1,"author":{"__ref":"User:user:30431"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:mobile"},"conversation":{"__ref":"Conversation:conversation:38209"},"moderationData":{"__ref":"ModerationData:moderation_data:38209"},"postTime":"2022-10-01T07:18:21.198-04:00","lastPublishTime":"2022-10-01T07:18:21.198-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":4402},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:38209":{"__typename":"Conversation","id":"conversation:38209","solved":true,"topic":{"__ref":"ForumTopicMessage:message:38209"},"lastPostingActivityTime":"2022-10-03T10:40:23.989-04:00","lastPostTime":"2022-10-03T10:40:23.989-04:00","isSubscribed":false},"ModerationData:moderation_data:38209":{"__typename":"ModerationData","id":"moderation_data:38209","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:38209":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:38209","relatedMessage":{"__ref":"ForumTopicMessage:message:38209"}},"Rank:rank:12":{"__typename":"Rank","id":"rank:12","position":30,"name":"Spartan","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:14283":{"__typename":"User","id":"user:14283","uid":14283,"login":"j-p1988","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2020-06-20T19:39:14.622-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-3.svg?time=0"},"rank":{"__ref":"Rank:rank:12"},"messagesCount":12,"kudosGivenCount":0,"kudosReceivedCount":2,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:14283"},"ForumTopicMessage:message:34139":{"__typename":"ForumTopicMessage","uid":34139,"subject":"Questions avant de passer à Vidéotron Mobile","id":"message:34139","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:mobile/message:34139","revisionNum":1,"repliesCount":1,"author":{"__ref":"User:user:14283"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:mobile"},"conversation":{"__ref":"Conversation:conversation:34139"},"moderationData":{"__ref":"ModerationData:moderation_data:34139"},"postTime":"2022-06-02T16:00:43.137-04:00","lastPublishTime":"2022-06-02T16:00:43.137-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":4629},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:34139":{"__typename":"Conversation","id":"conversation:34139","solved":true,"topic":{"__ref":"ForumTopicMessage:message:34139"},"lastPostingActivityTime":"2022-06-02T17:08:45.007-04:00","lastPostTime":"2022-06-02T17:08:45.007-04:00","isSubscribed":false},"ModerationData:moderation_data:34139":{"__typename":"ModerationData","id":"moderation_data:34139","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:34139":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:34139","relatedMessage":{"__ref":"ForumTopicMessage:message:34139"}},"User:user:32784":{"__typename":"User","id":"user:32784","uid":32784,"login":"vlfmoiaj","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2024-02-17T11:57:22.185-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-1.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":1,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:32784"},"ForumTopicMessage:message:44479":{"__typename":"ForumTopicMessage","uid":44479,"subject":"Données mobiles","id":"message:44479","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:mobile/message:44479","revisionNum":1,"repliesCount":1,"author":{"__ref":"User:user:32784"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:mobile"},"conversation":{"__ref":"Conversation:conversation:44479"},"moderationData":{"__ref":"ModerationData:moderation_data:44479"},"postTime":"2024-02-17T11:54:20.499-05:00","lastPublishTime":"2024-02-17T11:54:20.499-05:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":2271},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:44479":{"__typename":"Conversation","id":"conversation:44479","solved":true,"topic":{"__ref":"ForumTopicMessage:message:44479"},"lastPostingActivityTime":"2024-02-17T12:56:14.137-05:00","lastPostTime":"2024-02-17T12:56:14.137-05:00","isSubscribed":false},"ModerationData:moderation_data:44479":{"__typename":"ModerationData","id":"moderation_data:44479","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:44479":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:44479","relatedMessage":{"__ref":"ForumTopicMessage:message:44479"}},"User:user:33345":{"__typename":"User","id":"user:33345","uid":33345,"login":"Elyse","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2024-07-11T19:28:54.587-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-8.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":1,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:33345"},"ForumTopicMessage:message:45763":{"__typename":"ForumTopicMessage","uid":45763,"subject":"Échange de telephone mobile","id":"message:45763","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:mobile/message:45763","revisionNum":1,"repliesCount":1,"author":{"__ref":"User:user:33345"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:mobile"},"conversation":{"__ref":"Conversation:conversation:45763"},"moderationData":{"__ref":"ModerationData:moderation_data:45763"},"postTime":"2024-07-11T19:27:36.115-04:00","lastPublishTime":"2024-07-11T19:27:36.115-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":2447},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:45763":{"__typename":"Conversation","id":"conversation:45763","solved":true,"topic":{"__ref":"ForumTopicMessage:message:45763"},"lastPostingActivityTime":"2024-07-11T22:29:42.119-04:00","lastPostTime":"2024-07-11T22:29:42.119-04:00","isSubscribed":false},"ModerationData:moderation_data:45763":{"__typename":"ModerationData","id":"moderation_data:45763","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:45763":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:45763","relatedMessage":{"__ref":"ForumTopicMessage:message:45763"}},"QueryVariables:TopicReplyList:message:15351:1":{"__typename":"QueryVariables","id":"TopicReplyList:message:15351:1","value":{"id":"message:15351","first":10,"sorts":{"postTime":{"direction":"DESC"}},"repliesFirst":3,"repliesFirstDepthThree":1,"repliesSorts":{"postTime":{"direction":"DESC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":true,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":true,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:text:fr_FR-components/community/Navbar-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/Navbar-1749759678782","value":{"community":"Accueil de la communauté","inbox":"Boîte de réception","manageContent":"Gérer le contenu","tos":"Conditions d'utilisation","forgotPassword":"Mot de passe oublié","themeEditor":"Éditeur de thème","edit":"Modifier la barre de navigation","skipContent":"Passer au contenu","mon-videotron-link":"Mon Vidéotron","le-blogue-link":"Blogue","mobile-link":"Mobilité","super-utilisateurs-link":"Super Utilisateurs","mobilephone-english-link":"Mobility","television-divertissement-link":"Télé et Divertissement","en-link":"Forum","t-v-entertainement-link":"TV & Entertainment","fr-link":"Forum","the-blog-link":"Blog","internet-telephony-link":"Internet & Telephony","blog-link":"Blog","my-videotron-link":"My Videotron","internet-telephonie-link":"Internet et Téléphonie","forum-television-entertainment-link":"TV & Entertainment","forum-mobility-link":"Mobility","external-link":"Aide","forum-internet-telephony-link":"Internet & Telephony","forum-news-link":"My Videotron"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/NavbarHamburgerDropdown-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/NavbarHamburgerDropdown-1749759678782","value":{"hamburgerLabel":"Menu Latéral"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/BrandLogo-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/BrandLogo-1749759678782","value":{"logoAlt":"Khoros","themeLogoAlt":"Logo de la marque"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/NavbarTextLinks-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/NavbarTextLinks-1749759678782","value":{"more":"Plus"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/languages/UseLanguageText-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/languages/UseLanguageText-1749759678782","value":{"language.browserLanguage.label":"Par défaut du navigateur","language.ar-AE.label":"Arabe","language.bg-BG.label":"Bulgare","language.ca-AD.label":"Catalan","language.cs-CZ.label":"Tchèque","language.da-DK.label":"Danois","language.de-DE.label":"Allemand","language.el-GR.label":"Grec","language.en-GB.label":"Anglais (Royaume-Uni)","language.en-US.label":"Anglais (États-Unis)","language.es-ES.label":"Espagnol","language.es-MX.label":"Espagnol (Amérique latine)","language.et-EE.label":"Estonien","language.fa-IR.label":"Persan (Farsi)","language.fi-FI.label":"Finnois","language.fr-FR.label":"Français","language.he-IL.label":"Hébreu","language.hr-HR.label":"Croate","language.hu-HU.label":"Hongrois","language.in-ID.label":"Indonésien","language.it-IT.label":"Italien","language.ja-JP.label":"Japonais","language.ko-KR.label":"Coréen","language.lt-LT.label":"Lituanien","language.lv-LV.label":"Letton","language.ms-MY.label":"Malais","language.nl-NL.label":"Néerlandais","language.no-NO.label":"Norvégien","language.pl-PL.label":"Polonais","language.pt-BR.label":"Portugais (Brésilien)","language.pt-PT.label":"Portugais","language.ro-RO.label":"Roumain","language.ru-RU.label":"Russe","language.sk-SK.label":"Slovaque","language.sq-AL.label":"Albanais","language.sv-SE.label":"Suédois","language.th-TH.label":"Thaï","language.tr-TR.label":"Turc","language.uk-UA.label":"Ukrainien","language.vi-VN.label":"Vietnamien","language.zh-CN.label":"Chinois (simplifié)","language.zh-TW.label":"Chinois (traditionnel)","timezone.fieldLabel.label":"Fuseau horaire","timezone.delimiter.label":"------------------------------","timezone.Etc-GMT+12.label":"GMT -12:00 Dateline","timezone.Pacific-Samoa.label":"GMT -11:00 Samoa","timezone.US-Hawaii.label":"GMT -10:00 Heure hawaïenne des États-Unis","timezone.US-Aleutian.label":"GMT -10:00 Îles Aléoutiennes","timezone.Pacific-Marquesas.label":"GMT -09:30 Marquises","timezone.Pacific-Gambier.label":"GMT -09:00 Îles Gambier","timezone.US-Alaska.label":"GMT -09:00 Heure de l'Alaska, États-Unis","timezone.US-Pacific.label":"GMT -08:00 Heure du Pacifique, États-Unis","timezone.Pacific-Pitcairn.label":"GMT -08:00 Îles Pitcairn","timezone.US-Mountain.label":"GMT -07:00 Heure des montagnes, États-Unis","timezone.US-Arizona.label":"GMT -07:00 Heure des montagnes, États-Unis (Arizona)","timezone.US-Central.label":"GMT -06:00 Heure centrale, États-Unis","timezone.Mexico-General.label":"GMT -06:00 Mexique","timezone.America-Costa_Rica.label":"GMT -06:00 Costa Rica","timezone.US-Eastern.label":"GMT -05:00 Heure de l'Est, États-Unis","timezone.America-Bogota.label":"GMT -05:00 Colombie, Pérou, Amérique du Sud","timezone.Canada-Atlantic.label":"GMT -04:00 Heure de l'Atlantique","timezone.America-Puerto_Rico.label":"GMT -04:00 Porto Rico","timezone.Canada-Newfoundland.label":"GMT -03:30 Terre-Neuve, Canada","timezone.America-Buenos_Aires.label":"GMT -03:00 Argentine","timezone.Brazil-East.label":"GMT -03:00 Brésil","timezone.Atlantic-South_Georgia.label":"GMT -02:00 Atlantique central","timezone.Atlantic-Cape_Verde.label":"GMT -01:00 Cap Vert","timezone.Atlantic-Azores.label":"GMT -01:00 Açores","timezone.Europe-London.label":"GMT ------ Royaume-Uni","timezone.Iceland.label":"GMT ------ Islande","timezone.Europe-Madrid.label":"GMT +01:00 Espagne","timezone.Africa-Algiers.label":"GMT +01:00 Alger, Afrique","timezone.Europe-Amsterdam.label":"GMT +01:00 Europe centrale","timezone.Europe-Athens.label":"GMT +02:00 Europe de l'Est","timezone.Africa-Tripoli.label":"GMT +02:00 Tripoli, Afrique","timezone.Egypt.label":"GMT +02:00 Égypte","timezone.Israel.label":"GMT +02:00 Israël","timezone.Asia-Riyadh.label":"GMT +03:00 Arabie Saoudite","timezone.Iran.label":"GMT +03:30 Iran","timezone.Europe-Moscow.label":"GMT +03:00 Russie","timezone.Europe-Samara.label":"GMT +04:00 Samara, Europe","timezone.Asia-Dubai.label":"GMT +04:00 Arabie","timezone.Asia-Kabul.label":"GMT +04:30 Afghanistan","timezone.Asia-Karachi.label":"GMT +05:00 Pakistan, Asie de l'Ouest","timezone.Asia-Yekaterinburg.label":"GMT +05:00 Yekaterinbourg, Asie","timezone.Asia-Calcutta.label":"GMT +05:30 Inde","timezone.Asia-Thimphu.label":"GMT +06:00 Bangladesh, Asie centrale","timezone.Asia-Novosibirsk.label":"GMT +06:00 Novossibirsk, Asie","timezone.Asia-Rangoon.label":"GMT +06:30 Birmanie","timezone.Asia-Bangkok.label":"GMT +07:00 Bangkok, Hanoï, Jakarta","timezone.Asia-Krasnoyarsk.label":"GMT +07:00 Krasnoïarsk, Asie","timezone.PRC.label":"GMT +08:00 Chine","timezone.Singapore.label":"GMT +08:00 Singapour","timezone.Asia-Taipei.label":"GMT +08:00 Taïwan","timezone.Australia-West.label":"GMT +08:00 Australie (WT)","timezone.Asia-Irkutsk.label":"GMT +08:00 Irkoutsk, Asie","timezone.Japan.label":"GMT +09:00 Japon","timezone.Asia-Seoul.label":"GMT +09:00 Corée","timezone.Asia-Yakutsk.label":"GMT +09:00 Iakoutsk, Russie","timezone.Australia-North.label":"GMT +09:30 Australie (NT)","timezone.Australia-Adelaide.label":"GMT +09:30 Australie (ST)","timezone.Australia-Sydney.label":"GMT +10:00 Australie (ET)","timezone.Australia-Queensland.label":"GMT +10:00 Australie (Queensland)","timezone.Asia-Magadan.label":"GMT +10:00 Magadan, Asie","timezone.Australia-Lord_Howe.label":"GMT +10:30 Australie (Lord Howe)","timezone.Pacific-Guadalcanal.label":"GMT +11:00 Pacifique central","timezone.Pacific-Norfolk.label":"GMT +11:30 Îles Norfolk","timezone.Pacific-Auckland.label":"GMT +12:00 Nouvelle-Zélande","timezone.Pacific-Fiji.label":"GMT +12:00 Fidji","timezone.Antarctica-South_Pole.label":"GMT +12:00 Pôle Sud, Antarctique","UseLanguageText.language.en-US.label":"Anglais","UseLanguageText.language.fr-FR.label":"Français"},"localOverride":false},"CachedAsset:text:fr_FR-components/languages/LanguagePicker-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/languages/LanguagePicker-1749759678782","value":{"dropdown.title":"Sélecteur de langue","selected.language":"Langue sélectionnée actuellement","toast.successMessage":"Aller à la communauté {newLanguage}We've seen the \"Freedom\" issue on an iPhone from Videotron.
Overall, the network works great in Ottawa (should I says networks, as there are multiple network ID?). The main differences between Rogers and Videotron when in Ottawa are
- access to Rogers' band 7 is limited to certain areas (e.g. in malls)
- if you set your phone to 3G, you may end up on Videotron's limited AWS 3G coverage until the phone gives and jumps back to the shared network with Rogers
Although Rogers has added more towers in the last year within the city, the Bell/Telus network have the upper hand, specially when going East of Ottawa (Prescott-Russell) where the tower density is very different between the two of them.
Back on the topic of 3G, in most areas, Bell/Telus' 3G will have faster data.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"208","kudosSumWeight":0,"postTime":"2019-09-20T18:52:35.346-04:00","lastPublishTime":"2019-09-20T18:52:35.346-04:00","metrics":{"__typename":"MessageMetrics","views":5651},"visibilityScope":"PUBLIC","placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"MessageEdge","cursor":"MjUuNHwyLjF8aXwxfDQxOjB8aW50LDE2NzkzLDE2Nzkz","node":{"__ref":"ForumReplyMessage:message:16793"}}]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:16793":{"__typename":"ModerationData","id":"moderation_data:16793","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:16793":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:7324"},"id":"message:16793","entityType":"FORUM_REPLY","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:15351/message:16793","revisionNum":2,"uid":16793,"depth":3,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:mobilephone-english"},"parent":{"__ref":"ForumReplyMessage:message:16332"},"conversation":{"__ref":"Conversation:conversation:15351"},"subject":"Re: How is Videotron mobile in Ottawa???","moderationData":{"__ref":"ModerationData:moderation_data:16793"},"body":"I have experienced the Freedom issue yet on another phone (Adding a OnePlus phone to a Pixel and an iPhone).
Ended up locking the phone on Partner 1 (which for some reason had a better signal than when piggybacking as Videotron). Going back to Auto later made it switch to Telus.
Videotron, stop marking 302-490 as a partner! I'm guessing someone took the easy way out by making Rogers/Fido to be Partner 1 and making all other 302-* as Partner 2.
Is 302-370 (Fido) still used?
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"208","kudosSumWeight":0,"repliesCount":0,"postTime":"2019-10-04T10:14:52.365-04:00","lastPublishTime":"2019-10-04T10:17:12.675-04:00","metrics":{"__typename":"MessageMetrics","views":5628},"visibilityScope":"PUBLIC","placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"CachedAsset:text:fr_FR-components/customComponent/CustomComponent-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/customComponent/CustomComponent-1749759678782","value":{"errorMessage":"Erreur lors du rendu de l'ID du composant : {customComponentId}","bannerTitle":"Le fournisseur de vidéos nécessite des cookies pour lire la vidéo. Acceptez pour continuer ou {url} directement sur le site du fournisseur.","buttonTitle":"Accepter","urlText":"regarder"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/NavbarDropdownToggle-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/NavbarDropdownToggle-1749759678782","value":{"ariaLabelClosed":"Appuyez sur la flèche vers le bas pour ouvrir le menu"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/EscalatedMessageBanner-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/EscalatedMessageBanner-1749759678782","value":{"escalationMessage":"Escalation vers Salesforce par {username} le {date}","viewDetails":"Voir les détails","modalTitle":"Détails de l'affaire","escalatedBy":"Escaladé par :","escalatedOn":"Escaladé le :","caseNumber":"Numéro d'affaire :","status":"Statut :","lastUpdateDate":"Dernière mise à jour :","automaticEscalation":"escalade automatique","anonymous":"Anonyme"},"localOverride":false},"CachedAsset:text:fr_FR-components/users/UserLink-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/users/UserLink-1749759678782","value":{"authorName":"Voir le profil : {author}","anonymous":"Anonyme"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/users/UserRank-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/users/UserRank-1749759678782","value":{"rankName":"{rankName}","userRank":"Rang d'auteur {rankName}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageTime-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageTime-1749759678782","value":{"postTime":"Publié : {time}","lastPublishTime":"Dernière mise à jour : {time}","conversation.lastPostingActivityTime":"Heure de la dernière activité de publication : {time}","conversation.lastPostTime":"Heure du dernier poste : {time}","moderationData.rejectTime":"Heure de rejet : {time}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageSolvedBadge-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageSolvedBadge-1749759678782","value":{"solved":"Résolu"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageSubject-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageSubject-1749759678782","value":{"noSubject":"(sans objet)"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageBody-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageBody-1749759678782","value":{"showMessageBody":"Afficher plus","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} n'est plus disponible","mentionsErrorMessage":"Le {mentionsType} que vous essayez de consulter a été supprimé de la communauté.","videoProcessing":"La vidéo est en cours de traitement. Veuillez réessayer dans quelques minutes.","bannerTitle":"Le fournisseur de vidéos nécessite des cookies pour lire la vidéo. Acceptez pour continuer ou {url} la regarder directement sur le site du fournisseur.","buttonTitle":"Accepter","urlText":"visionner"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageCustomFields-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageCustomFields-1749759678782","value":{"CustomField.default.label":"Valeur de {name}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageReplyButton-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageReplyButton-1749759678782","value":{"repliesCount":"{count}","title":"Répondre","title@board:BLOG@message:root":"Commentaire","title@board:TKB@message:root":"Commentaire","title@board:IDEA@message:root":"Commentaire","title@board:OCCASION@message:root":"Commentaire"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageListMenu-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageListMenu-1749759678782","value":{"postTimeAsc":"Plus ancien","postTimeDesc":"Plus récent","kudosSumWeightAsc":"Le moins aimé","kudosSumWeightDesc":"Le plus aimé","sortTitle":"Trier par","sortedBy.item":" {itemName, select, postTimeAsc {Plus ancien} postTimeDesc {Plus récent} kudosSumWeightAsc {Le moins aimé} kudosSumWeightDesc {Le plus aimé} other {}}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/AcceptedSolutionButton-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/AcceptedSolutionButton-1749759678782","value":{"accept":"Marquer comme résolu","accepted":"Marqué comme résolu","errorHeader":"Erreur !","errorAdd":"Une erreur est survenue en marquant comme résolu.","errorRemove":"Une erreur est survenue en révoquant le marquage comme résolu.","solved":"Résolu","topicAlreadySolvedErrorTitle":"La solution existe déjà","topicAlreadySolvedErrorDesc":"Rafraîchissez le navigateur pour voir la solution existante"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/common/Pager/PagerLoadMore-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/common/Pager/PagerLoadMore-1749759678782","value":{"loadMore":"Afficher plus"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageView/MessageViewInline-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageView/MessageViewInline-1749759678782","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonyme","place":"Endroit {bylineBoard}","gotoParent":"Aller au parent {name}"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/users/UserAvatar-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/users/UserAvatar-1749759678782","value":{"altText":"Avatar de {login}","altTextGeneric":"Avatar de l'utilisateur"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/ranks/UserRankLabel-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/ranks/UserRankLabel-1749759678782","value":{"altTitle":"Icône pour le rang {rankName}"},"localOverride":false},"CachedAsset:text:fr_FR-components/tags/TagView/TagViewChip-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/tags/TagView/TagViewChip-1749759678782","value":{"tagLabelName":"Nom de la étiquette {tagName}"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/nodes/NodeIcon-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/nodes/NodeIcon-1749759678782","value":{"contentType":"Type de contenu {style, select, FORUM {Forum} BLOG {Blog} TKB {Base de connaissances} IDEA {Idées} OCCASION {Événements} other {}} icône"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"autoScroll":"true","topicRepliesSort":"postTimeDesc","boardId":"mobilephone-english","messageSubject":"how-is-videotron-mobile-in-ottawa","messageId":"15351"},"buildId":"3XH0qYWYCnEYycuN5W4S8","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","surveysEnabled":true,"openTelemetry":{"clientEnabled":false,"configName":"videotron","serviceVersion":"25.4.0","universe":"prod","collector":"http://localhost:4318","logLevel":"error","routeChangeAllowedTime":"5000","headers":"","enableDiagnostic":"false","maxAttributeValueLength":"4095"},"apolloDevToolsEnabled":false,"quiltLazyLoadThreshold":"3"},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["components_seo_QAPageSchema","components_customComponent_CustomComponent","components_community_Navbar_NavbarWidget","components_community_Breadcrumb_BreadcrumbWidget","components_messages_TopicWithThreadedReplyListWidget","components_messages_RelatedContentWidget","components_messages_MessageListForNodeByRecentActivityWidget","components_community_FooterWidget","components_languages_LanguagePicker","components_messages_MessageView_MessageViewStandard","components_messages_ThreadedReplyList","components_community_FooterWidgetHelpLink","components_community_KhorosLogo","components_customComponent_CustomComponentContent_HtmlContent","components_messages_EscalatedMessageBanner","shared_client_components_common_List_UnstyledList","components_messages_MessageView","shared_client_components_common_Pager_PagerLoadMore","components_messages_MessageView_MessageViewInline","shared_client_components_common_List_ListGroup","components_customComponent_CustomComponentContent_CustomComponentScripts","shared_client_components_common_List_UnwrappedList","components_tags_TagView","components_tags_TagView_TagViewChip"],"appGip":true,"scriptLoader":[]}
