Thanks!
-Marcia
","kudosSumWeight":0,"postTime":"2020-01-12T21:56:07.944-05:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjUuNHwyLjF8b3wxMHxfTlZffDE","node":{"__typename":"Tag","id":"tag:extender","text":"extender","time":"2020-01-12T22:15:15.381-05:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuNHwyLjF8b3wxMHxfTlZffDI","node":{"__typename":"Tag","id":"tag:Wi-Fi","text":"Wi-Fi","time":"2017-05-08T16:53:25.817-04:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":2,"currentRevision":{"__ref":"Revision:revision:19008_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":6151},"read":false,"visibilityScope":"PUBLIC","canonicalUrl":null,"seoTitle":null,"seoDescription":null,"isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"archivalData":null,"customFields":[],"body":"Hello,
I'm seeking some advice as my Videotron Zyxel EMG 2926 router is not assigning IP addresses through my wifi range extender D-Link DAP-1325. My apologies if it's not clear (et que c'est en anglais.)
For the last 6 months or so, I've been using the wifi extender as a repeater so that the wifi signal can reach throughout our home. All devices (extender, mobile devices, and Google Home Mini) were working as expected until the last couple of weeks. This was about the time we connected a new wired device (unrelated?) and starting noticing our wifi-devices cutting out or dropping the internet too frequently. I called Videotron and they did a factory reset of the router to try to solve that issue.
However, now the extender doesn't work to assign IP addresses. I called D-link tech support and they walked me through several troubleshooting steps. They concluded that nothing is wrong with the extender, and that the problem is with the router not allowing DHCP to pass through the extender.
Here's what I observe in three different scenarios:
PARTIAL SOLUTION:
https://forum.videotron.com/t5/Internet-et-Telephonie/Imprimante-WIFI-non-detecte-par-mon-ordinateur/td-p/18333
I followed the instructions in this thread, which basically turned the WLAN 2.4GHz into Access Point Mode. Now the devices seem to be able to access the internet through the extender, but only intermittently.
Any suggestions on settings to change in the router to make it assign IP addresses through the extender again and maintain the internet connection? I called Videotron and they said they can't help with router settings as they don't see anything wrong with internet access on my main wifi network.
Thanks!
-Marcia
"},"Conversation:conversation:19008":{"__typename":"Conversation","id":"conversation:19008","solved":true,"topic":{"__ref":"ForumTopicMessage:message:19008"},"lastPostingActivityTime":"2020-02-08T10:51:36.368-05:00","lastPostTime":"2020-02-08T10:51:36.368-05:00","unreadReplyCount":1,"isSubscribed":false},"ModerationData:moderation_data:19008":{"__typename":"ModerationData","id":"moderation_data:19008","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:19008_1":{"__typename":"Revision","id":"revision:19008_1","lastEditTime":"2020-01-12T21:56:07.944-05:00"},"AcceptedSolutionMessage:message:19462":{"__typename":"AcceptedSolutionMessage","id":"message:19462","conversation":{"__ref":"Conversation:conversation:19008"},"author":{"__ref":"User:user:12744"},"entityType":"FORUM_REPLY","eventPath":"category:en/community:ogevo67675board:Internet-Telephony/message:19008/message:19462","revisionNum":2,"uid":19462,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:Internet-Telephony"},"subject":"Re: Zyxel EMG 2926 not assigning IP addresses through wifi range extender D-Link DAP-1325","readOnly":false,"editFrozen":false,"showMoveIndicator":false,"moderationData":{"__ref":"ModerationData:moderation_data:19462"},"parent":{"__ref":"ForumTopicMessage:message:19008"},"body":"Problem solved! I got a new router when I switched to Carrytel and it solved this problem. It also solved my problem of constant loss of internet over wifi when Videotron denied it could be a problem with their router.
","body@stringLength":"225","rawBody":"Problem solved! I got a new router when I switched to Carrytel and it solved this problem. It also solved my problem of constant loss of internet over wifi when Videotron denied it could be a problem with their router.
","kudosSumWeight":0,"repliesCount":0,"postTime":"2020-02-08T10:51:36.368-05:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"solution":true,"currentRevision":{"__ref":"Revision:revision:19462_2"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":6052},"read":false,"visibilityScope":"PUBLIC","isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"body@stripHtml({\"removeProcessingText\":true,\"removeSpoilerMarkup\":true,\"removeTocMarkup\":true,\"truncateLength\":200})@stringLength":"203","lastPublishTime":"2020-02-08T11:44:59.693-05:00","videos":{"__typename":"VideoConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[],"replies":{"__typename":"MessageConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"CachedAsset:theme:customTheme1-1749759874274":{"__typename":"CachedAsset","id":"theme:customTheme1-1749759874274","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"50%","collections":["default"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"Favicon-1730465696192.png","imageLastModified":"1730465698198","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"logo-videotron_header2fr-1730818064436.png","imageLastModified":"1730818067042","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1300px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_BROWSER","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"3px","borderRadius":"3px","borderRadiusLg":"5px","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"12px","paddingXLg":"16px","paddingXHero":"60px","fontStyle":"NORMAL","fontWeight":"700","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-body-bg)","primaryTextHoverColor":"var(--lia-bs-body-bg)","primaryTextActiveColor":"var(--lia-bs-body-bg)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-primary)","secondaryTextHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.9))","secondaryBgColor":"#FDD200","secondaryBgHoverColor":"hsl(49.80000000000001, 100%, 47.6%)","secondaryBgActiveColor":"hsl(49.80000000000001, 100%, 45.6%)","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-gray-900)","tertiaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-danger)","destructiveTextHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.95))","destructiveTextActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.9))","destructiveBgColor":"var(--lia-bs-gray-200)","destructiveBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","destructiveBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"LIGHT","sideContent":"NONE","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08)","sm":"0","md":"0","lg":"0","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"var(--lia-bs-link-color)","defaultMessageLinkDecoration":"underline","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","defaultMessageFontFamily":"var(--lia-bs-font-family-base)","forumColor":"#000000","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#24AD72","blogColor":"#000000","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#E06643","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#FF8000","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#D13A1F","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#FFDE45","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#000000","secondary":"#333333","bodyText":"#575754","bodyBg":"#FFFFFF","info":"#FFD200","success":"#24AD72","warning":"#DA8000","danger":"#C14D00","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#FDD200","#C14D00"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":{"link":{"color":"#0069D4","hoverColor":"#0061c2","decoration":"none","hoverDecoration":"underline","__typename":"EmailLinkSettings"},"border":{"color":"#e4e4e4","__typename":"EmailBorderSettings"},"buttons":{"borderRadiusLg":"5px","paddingXLg":"16px","paddingYLg":"7px","fontWeight":"700","primaryTextColor":"#ffffff","primaryTextHoverColor":"#ffffff","primaryBgColor":"#0069D4","primaryBgHoverColor":"#005cb8","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","__typename":"EmailButtonsSettings"},"panel":{"borderRadius":"5px","borderColor":"#e4e4e4","__typename":"EmailPanelSettings"},"__typename":"EmailThemeSettings"},"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Blender Pro Book","fontStyle":"NORMAL","fontWeight":"500","h1FontSize":"52px","h2FontSize":"36px","h3FontSize":"24px","h4FontSize":"22px","h5FontSize":"16px","h6FontSize":"14px","lineHeight":"1.3","subHeaderFontSize":"11px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":"10px","size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"var(--lia-bs-border-radius-sm)","borderRadius":"var(--lia-bs-border-radius)","borderRadiusLg":"var(--lia-bs-border-radius-lg)","formTextMarginTop":"4px","textAreaBorderRadius":"var(--lia-bs-border-radius)","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-black)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":"","imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"40px","defaultMessageHeaderMarginBottom":"20px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"30px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"40px","specialMessageHeaderMarginBottom":"20px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"30px","tableBgColor":"transparent","tableBorderColor":"var(--lia-bs-gray-700)","tableBorderStyle":"solid","tableCellPaddingX":"5px","tableCellPaddingY":"5px","tableTextColor":"var(--lia-bs-body-color)","tableVerticalAlign":"middle","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Open Sans","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.5","fontSizeBase":"16px","fontSizeXxs":"11px","fontSizeXs":"12px","fontSizeSm":"14px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Crossten Book-V","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"},{"style":"NORMAL","weight":"500","__typename":"FontStyleData"},{"style":"NORMAL","weight":"700","__typename":"FontStyleData"},{"style":"NORMAL","weight":"300","__typename":"FontStyleData"},{"style":"NORMAL","weight":"600","__typename":"FontStyleData"}],"assetNames":["CrosstenBook-V-normal-400.woff2","CrosstenBook-V-normal-500.woff2","CrosstenBook-V-normal-700.woff2","CrosstenBook-V-normal-300.woff2","CrosstenBook-V-normal-600.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Blender Pro Book","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"},{"style":"NORMAL","weight":"500","__typename":"FontStyleData"},{"style":"NORMAL","weight":"700","__typename":"FontStyleData"},{"style":"ITALIC","weight":"400","__typename":"FontStyleData"}],"assetNames":["BlenderProBook-normal-400.woff2","BlenderProBook-normal-500.woff2","BlenderProBook-normal-700.woff2","BlenderProBook-italic-400.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/common/Loading/LoadingDot-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/common/Loading/LoadingDot-1749759873379","value":{"title":"Chargement..."},"localOverride":false},"CachedAsset:quilt:videotron.prod:pages/forums/ForumMessagePage:board:Internet-Telephony-1749759872434":{"__typename":"CachedAsset","id":"quilt:videotron.prod:pages/forums/ForumMessagePage:board:Internet-Telephony-1749759872434","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"MAIN_SIDE","bgColor":null,"showTitle":null,"showDescription":null,"textPosition":null,"textColor":null,"sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"MainSideQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"messages.widget.relatedContentWidget","className":null,"props":{"hideIfEmpty":true,"enablePagination":false,"useTitle":true,"listVariant":{"type":"unstyled","props":{"listItemSpacing":"xxl"}},"pageSize":5,"style":"compact","pagerVariant":{"type":"none"},"viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"useCompactSpacing":true,"boardIconSize":"24","useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useNodeLink":true,"useViewCount":false,"usePreviewMedia":true,"useBody":false,"timeStampType":"postTime","useTags":false,"clampSubjectLines":2,"useBoardIcon":true,"useMessageTimeLink":true,"useTextBody":true,"useSolvedBadge":false,"renderPostTimeBeforeAuthor":true,"useAvatar":false,"useAuthorLogin":true,"useVideoPreview":false}},"lazyLoad":false,"panelType":"standard"},"__typename":"QuiltComponent"},{"id":"messages.widget.messageListForNodeByRecentActivityWidget","className":null,"props":{"hideIfEmpty":true,"useTitle":true,"showTabs":false,"pageSize":5,"pagerVariant":{"type":"loadMore"},"style":"compact","viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","truncateBodyLength":-1,"useNodeLink":true,"usePreviewMedia":false,"timeStampType":"conversation.lastPostingActivityTime","avatarSize":"40","useTextBody":true,"useSolvedBadge":true,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":true,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":false,"useMessageTimeLink":true,"clampBodyLines":3,"useAuthorLogin":true,"useUnreadCount":false,"useNodeHoverCard":true,"useSearchSnippet":false}},"panelType":"divider","sorts":{"conversationLastPostingActivityTime":{"direction":"DESC"}}},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:fr_FR-components/common/EmailVerification-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-components/common/EmailVerification-1749759873379","value":{"email.verification.title":"Vérification de l'adresse e-mail requise","email.verification.message.update.email":"Pour participer à la communauté, vous devez d'abord vérifier votre adresse e-mail. L'e-mail de vérification a été envoyé à {email}. Pour changer votre adresse e-mail, visitez Mes paramètres .","email.verification.message.resend.email":"Pour participer à la communauté, vous devez d'abord vérifier votre adresse e-mail. L'e-mail de vérification a été envoyé à {email}. Renvoyer l'e-mail ."},"localOverride":false},"CachedAsset:text:fr_FR-pages/forums/ForumMessagePage-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-pages/forums/ForumMessagePage-1749759873379","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"Ce message est introuvable","name":"Page de message de Forum","section.message-list.title":"Discussion de forum","archivedMessageTitle":"Ce contenu a été archivé"},"localOverride":false},"CachedAsset:quiltWrapper:videotron.prod:Common:fr-FR-1749759872916":{"__typename":"CachedAsset","id":"quiltWrapper:videotron.prod:Common:fr-FR-1749759872916","value":{"id":"Common_oIbWvI","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"custom.widget.Utility_Nav_FR","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"usePageWidth":true,"backgroundColor":"var(--lia-bs-primary)","useBackground":false,"backgroundOpacity":1,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"community.widget.navbarWidget","props":{"showUserName":false,"showRegisterLink":true,"useIconLanguagePicker":true,"showLanguagePicker":true,"useLabelLanguagePicker":true,"links":{"sideLinks":[],"mainLinks":[{"children":[],"linkType":"INTERNAL","id":"super-utilisateurs-link","params":{"boardId":"SuperUtilisateurs","categoryId":"SuperUtilisateurs"},"routeName":"ForumBoardPage"},{"children":[{"linkType":"INTERNAL","id":"mobile-link","params":{"boardId":"mobile","categoryId":"fr"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"internet-telephonie-link","params":{"boardId":"internet-telephonie","categoryId":"fr"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"television-divertissement-link","params":{"boardId":"television-divertissement","categoryId":"fr"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"mon-videotron-link","params":{"boardId":"mon-videotron","categoryId":"fr"},"routeName":"ForumBoardPage"}],"linkType":"INTERNAL","id":"fr-link","params":{"categoryId":"fr"},"routeName":"CategoryPage"},{"children":[],"linkType":"INTERNAL","id":"le-blogue-link","params":{"boardId":"LeBlogue","categoryId":"fr"},"routeName":"BlogBoardPage"},{"children":[],"linkType":"EXTERNAL","id":"external-link","url":"https://forum.videotron.com/help","target":"SELF"}]},"className":"QuiltComponent_lia-component-edit-mode__0nCcm","style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"400","controllerHighlightColor":"#C14D00","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"14px","linkBoxShadowHover":"none","backgroundOpacity":0.8,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"52px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"5px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"1px solid var(--lia-bs-border-color)","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"flex-start","linkColor":"var(--lia-bs-body-color)","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerHighlightTextColor":"var(--lia-yiq-light)","background":{"imageAssetName":"","color":"var(--lia-bs-white)","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"var(--lia-bs-primary)","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"0","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"5px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-body-color)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-body-color)"},"showSearchIcon":true,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":{"backgroundColor":"#FDD200","visualEffects":{"showBottomBorder":true},"backgroundOpacity":100,"backgroundImageProps":{"assetName":"community-widget-bannerWidget-1733422118937.png","backgroundSize":"COVER","lastModified":"1733422120000","backgroundPosition":"CENTER_CENTER","backgroundRepeat":"NO_REPEAT"},"fontColor":"var(--lia-bs-primary)"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"transparent","linkHighlightColor":"var(--lia-bs-primary)","visualEffects":{"showBottomBorder":true},"linkTextColor":"var(--lia-bs-gray-700)"},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"var(--lia-bs-primary)","items":[{"id":"community.widget.footerWidget","props":null,"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:text:fr_FR-components/common/ActionFeedback-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-components/common/ActionFeedback-1749759873379","value":{"joinedGroupHub.title":"Bienvenue","joinedGroupHub.message":"Vous êtes maintenant membre de ce groupe et abonné aux mises à jour.","groupHubInviteNotFound.title":"Invitation non trouvée","groupHubInviteNotFound.message":"Désolé, nous n'avons pas trouvé votre invitation au groupe. Le propriétaire a peut-être annulé l'invitation.","groupHubNotFound.title":"Groupe introuvable","groupHubNotFound.message":"Le grouphub que vous avez essayé de rejoindre n'existe pas. Il a peut-être été supprimé.","existingGroupHubMember.title":"Déjà membre","existingGroupHubMember.message":"Vous êtes déjà membre de ce groupe.","accountLocked.title":"Compte verrouillé","accountLocked.message":"Votre compte a été verrouillé en raison de plusieurs tentatives infructueuses. Réessayez dans {lockoutTime} minutes.","editedGroupHub.title":"Modifications enregistrées","editedGroupHub.message":"Votre groupe a été mis à jour.","leftGroupHub.title":"Au revoir","leftGroupHub.message":"Vous n'êtes plus membre de ce groupe et ne recevrez plus de mises à jour à l'avenir.","deletedGroupHub.title":"Supprimé","deletedGroupHub.message":"Le groupe a été supprimé.","groupHubCreated.title":"Groupe créé","groupHubCreated.message":"{groupHubName} est prêt à être utilisé","accountClosed.title":"Compte fermé","accountClosed.message":"Le compte a été fermé et vous serez maintenant redirigé vers la page d'accueil.","resetTokenExpired.title":"Le lien de réinitialisation du mot de passe a expiré","resetTokenExpired.message":"Essayez de réinitialiser votre mot de passe à nouveau","invalidUrl.title":"URL invalide","invalidUrl.message":"L'URL que vous utilisez n'est pas reconnue. Vérifiez votre URL et réessayez.","accountClosedForUser.title":"Compte fermé","accountClosedForUser.message":"Le compte de {userName} est fermé","inviteTokenInvalid.title":"Invitation invalide","inviteTokenInvalid.message":"Votre invitation à la communauté a été annulée ou a expiré.","inviteTokenError.title":"Erreur de vérification de l'invitation","inviteTokenError.message":"L'URL que vous utilisez n'est pas reconnue. Vérifiez votre URL et réessayez.","pageNotFound.title":"Accès refusé","pageNotFound.message":"Vous n'avez pas accès à cette zone de la communauté ou elle n'existe pas","eventAttending.title":"Répondu comme participant","eventAttending.message":"Vous serez notifié en cas d'activité et rappelé à l'approche de l'événement","eventInterested.title":"Répondu comme intéressé","eventInterested.message":"Vous serez notifié en cas d'activité et rappelé à l'approche de l'événement","eventNotFound.title":"Événement introuvable","eventNotFound.message":"L'événement auquel vous avez essayé de répondre n'existe pas.","redirectToRelatedPage.title":"Affichage du Contenu Connexe","redirectToRelatedPageForBaseUsers.title":"Affichage du Contenu Connexe","redirectToRelatedPageForBaseUsers.message":"Le contenu que vous essayez d'accéder est archivé","redirectToRelatedPage.message":"Le contenu que vous essayez d'accéder est archivé","relatedUrl.archivalLink.flyoutMessage":"Le contenu que vous essayez d'accéder est archivé Voir le Contenu Archivé"},"localOverride":false},"CachedAsset:component:custom.widget.Utility_Nav_FR-fr-fr-1749759881067":{"__typename":"CachedAsset","id":"component:custom.widget.Utility_Nav_FR-fr-fr-1749759881067","value":{"component":{"id":"custom.widget.Utility_Nav_FR","template":{"id":"Utility_Nav_FR","markupLanguage":"HTML","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Utility_Nav_FR","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:text:fr_FR-components/community/Breadcrumb-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/Breadcrumb-1749759873379","value":{"navLabel":"Fil d'Ariane","dropdown":"Navigation supplémentaire des parents de la page"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageBanner-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageBanner-1749759873379","value":{"messageMarkedAsSpam":"Ce post a été marqué comme pourriel","messageMarkedAsSpam@board:TKB":"Cet article a été marqué comme pourriel","messageMarkedAsSpam@board:BLOG":"Ce post a été marqué comme pourriel","messageMarkedAsSpam@board:FORUM":"Cette discussion a été marquée comme pourriel","messageMarkedAsSpam@board:OCCASION":"Cet événement a été marqué comme pourriel","messageMarkedAsSpam@board:IDEA":"Cette idée a été marquée comme pourriel","manageSpam":"Gérer le pourriel","messageMarkedAsAbuse":"Ce message a été marqué comme abus","messageMarkedAsAbuse@board:TKB":"Cet article a été marqué comme abus","messageMarkedAsAbuse@board:BLOG":"Ce poste a été marqué comme abus","messageMarkedAsAbuse@board:FORUM":"Cette discussion a été marquée comme abus","messageMarkedAsAbuse@board:OCCASION":"Cet événement a été marqué comme abus","messageMarkedAsAbuse@board:IDEA":"Cette idée a été marquée comme abus","preModCommentAuthorText":"Ce commentaire sera publié dès qu'il aura été approuvé","preModCommentModeratorText":"Ce commentaire est en attente de modération","messageMarkedAsOther":"Ce message a été rejeté pour d'autres raisons","messageMarkedAsOther@board:TKB":"Cet article a été rejeté pour d'autres raisons","messageMarkedAsOther@board:BLOG":"Ce poste a été rejeté pour d'autres raisons","messageMarkedAsOther@board:FORUM":"Cette discussion a été rejetée pour d'autres raisons","messageMarkedAsOther@board:OCCASION":"Cet événement a été rejeté pour d'autres raisons","messageMarkedAsOther@board:IDEA":"Cette idée a été rejetée pour d'autres raisons","messageArchived":"Ce poste a été archivé le {date}","relatedUrl":"Voir le contenu associé","relatedContentText":"Affichage du contenu associé","archivedContentLink":"Voir le contenu archivé"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/RelatedContentWidget-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/RelatedContentWidget-1749759873379","value":{"title":"Contenu connexe","emptyDescription":"Aucun contenu à afficher"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageListForNodeByRecentActivityWidget-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageListForNodeByRecentActivityWidget-1749759873379","value":{"title@userScope:other":"Contenu récent","title@userScope:self":"Contributions","title@board:FORUM@userScope:other":"Discussions récentes","title@board:BLOG@userScope:other":"Blogs récents","emptyDescription":"Pas de contenu à afficher","MessageListForNodeByRecentActivityWidgetEditor.nodeScope.label":"Portée","title@instance:1729793844493":"Recent Blogs"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/FooterWidget-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/FooterWidget-1749759873379","value":{"homeLink":"Accueil de La Communauté","topOfPage":"Haut de page","buildHash":"Hash de Build :","buildNumber":"Numéro de Build :","buildTime":"Date de Build :","privacyPolicy":"Politique de confidentialité","helpLink":"Aide"},"localOverride":false},"Category:category:fr":{"__typename":"Category","id":"category:fr","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"CATEGORY","displayId":"fr","nodeType":"category","depth":1,"title":"Français","shortTitle":"Français"},"Forum:board:mobile":{"__typename":"Forum","id":"board:mobile","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:internet-telephonie":{"__typename":"Forum","id":"board:internet-telephonie","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"FORUM","displayId":"internet-telephonie","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"Internet et Téléphonie","shortTitle":"Internet et Téléphonie","parent":{"__ref":"Category:category:fr"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0xOS0xOTYzaTQ5NzlDMEQyRjZBM0E0QUM\"}"},"description":"Wi-Fi, données, routeur, sécurité, messagerie… on répond à toutes vos questions au sujet d’Internet et de la téléphonie résidentielle!","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/"},"Forum:board:television-divertissement":{"__typename":"Forum","id":"board:television-divertissement","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:mon-videotron":{"__typename":"Forum","id":"board:mon-videotron","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Blog:board:LeBlogue":{"__typename":"Blog","id":"board:LeBlogue","blogPolicies":{"__typename":"BlogPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Conversation:conversation:49078":{"__typename":"Conversation","id":"conversation:49078","topic":{"__typename":"ForumTopicMessage","uid":49078},"lastPostingActivityTime":"2025-08-13T02:10:34.774-04:00","solved":false},"ForumTopicMessage:message:49078":{"__typename":"ForumTopicMessage","subject":"Kids can bypass helix wifi lockout by forgetting then reconnecting to network.","conversation":{"__ref":"Conversation:conversation:49078"},"id":"message:49078","entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:Internet-Telephony/message:49078","revisionNum":1,"uid":49078,"depth":0,"board":{"__ref":"Forum:board:Internet-Telephony"},"author":{"__typename":"User","uid":35264,"login":"DannyITR","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-5.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":26},"postTime":"2025-08-03T09:11:42.128-04:00","lastPublishTime":"2025-08-03T09:11:42.128-04:00","readOnly":false},"Conversation:conversation:47140":{"__typename":"Conversation","id":"conversation:47140","topic":{"__typename":"ForumTopicMessage","uid":47140},"lastPostingActivityTime":"2025-08-08T06:29:08.776-04:00","solved":false},"ForumTopicMessage:message:47140":{"__typename":"ForumTopicMessage","subject":"Port Fowarding via Helix FI App","conversation":{"__ref":"Conversation:conversation:47140"},"id":"message:47140","entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:Internet-Telephony/message:47140","revisionNum":1,"uid":47140,"depth":0,"board":{"__ref":"Forum:board:Internet-Telephony"},"author":{"__typename":"User","uid":33824,"login":"Cleuseau","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-4.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":558},"postTime":"2024-10-20T12:51:21.375-04:00","lastPublishTime":"2024-10-20T12:51:21.375-04:00","readOnly":false},"Conversation:conversation:20742":{"__typename":"Conversation","id":"conversation:20742","topic":{"__typename":"ForumTopicMessage","uid":20742},"lastPostingActivityTime":"2025-07-31T04:26:45.892-04:00","solved":true},"ForumTopicMessage:message:20742":{"__typename":"ForumTopicMessage","subject":"What is my router login information?","conversation":{"__ref":"Conversation:conversation:20742"},"id":"message:20742","entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:Internet-Telephony/message:20742","revisionNum":2,"uid":20742,"depth":0,"board":{"__ref":"Forum:board:Internet-Telephony"},"author":{"__typename":"User","uid":13787,"login":"Aynoose","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-5.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":3167},"postTime":"2020-04-20T20:38:19.706-04:00","lastPublishTime":"2020-04-20T23:10:33.415-04:00","readOnly":false},"Conversation:conversation:48765":{"__typename":"Conversation","id":"conversation:48765","topic":{"__typename":"ForumTopicMessage","uid":48765},"lastPostingActivityTime":"2025-07-28T00:24:02.324-04:00","solved":false},"ForumTopicMessage:message:48765":{"__typename":"ForumTopicMessage","subject":"Pourquoi il faut appeler le service a la clientèle une fois par année pour les payment préautorisés?","conversation":{"__ref":"Conversation:conversation:48765"},"id":"message:48765","entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:Internet-Telephony/message:48765","revisionNum":1,"uid":48765,"depth":0,"board":{"__ref":"Forum:board:Internet-Telephony"},"author":{"__typename":"User","uid":34969,"login":"hamelmathieu1","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-12.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":81},"postTime":"2025-05-30T13:14:49.497-04:00","lastPublishTime":"2025-05-30T13:14:49.497-04:00","readOnly":false},"Conversation:conversation:49032":{"__typename":"Conversation","id":"conversation:49032","topic":{"__typename":"ForumTopicMessage","uid":49032},"lastPostingActivityTime":"2025-07-21T08:10:35.657-04:00","solved":false},"ForumTopicMessage:message:49032":{"__typename":"ForumTopicMessage","subject":"Improving VoIP Stability While Traveling – Stag VPN Experience","conversation":{"__ref":"Conversation:conversation:49032"},"id":"message:49032","entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:Internet-Telephony/message:49032","revisionNum":1,"uid":49032,"depth":0,"board":{"__ref":"Forum:board:Internet-Telephony"},"author":{"__typename":"User","uid":35084,"login":"auroralane7754","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-3.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":19},"postTime":"2025-07-21T08:10:35.657-04:00","lastPublishTime":"2025-07-21T08:10:35.657-04:00","readOnly":false},"User:user:28595":{"__typename":"User","id":"user:28595","uid":28595,"login":"turta345","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2022-04-14T11:30:30.215-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-12.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":2,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:28595"},"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yNi0xOTU4aTFDNjU5NkM4QzEyRDdGQ0U\"}":{"__typename":"AssociatedImage","url":"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yNi0xOTU4aTFDNjU5NkM4QzEyRDdGQ0U","mimeType":"image/svg+xml"},"ForumTopicMessage:message:32858":{"__typename":"ForumTopicMessage","uid":32858,"subject":"How to assign static local IP address to a device in Helix router?","id":"message:32858","entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:Internet-Telephony/message:32858","revisionNum":1,"repliesCount":6,"author":{"__ref":"User:user:28595"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:Internet-Telephony"},"conversation":{"__ref":"Conversation:conversation:32858"},"moderationData":{"__ref":"ModerationData:moderation_data:32858"},"postTime":"2022-04-14T11:33:36.965-04:00","lastPublishTime":"2022-04-14T11:33:36.965-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":12710},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:32858":{"__typename":"Conversation","id":"conversation:32858","solved":true,"topic":{"__ref":"ForumTopicMessage:message:32858"},"lastPostingActivityTime":"2024-11-04T12:17:40.281-05:00","lastPostTime":"2024-11-04T12:17:40.281-05:00","isSubscribed":false},"ModerationData:moderation_data:32858":{"__typename":"ModerationData","id":"moderation_data:32858","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:32858":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:32858","relatedMessage":{"__ref":"ForumTopicMessage:message:32858"}},"User:user:31821":{"__typename":"User","id":"user:31821","uid":31821,"login":"mike96","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2023-08-14T14:14:53.808-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-5.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":2,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:31821"},"ForumTopicMessage:message:42256":{"__typename":"ForumTopicMessage","uid":42256,"subject":"New ipv4 address","id":"message:42256","entityType":"FORUM_TOPIC","eventPath":"category:en/community:ogevo67675board:Internet-Telephony/message:42256","revisionNum":1,"repliesCount":2,"author":{"__ref":"User:user:31821"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:Internet-Telephony"},"conversation":{"__ref":"Conversation:conversation:42256"},"moderationData":{"__ref":"ModerationData:moderation_data:42256"},"postTime":"2023-08-14T14:13:43.151-04:00","lastPublishTime":"2023-08-14T14:13:43.151-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":4091},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:42256":{"__typename":"Conversation","id":"conversation:42256","solved":true,"topic":{"__ref":"ForumTopicMessage:message:42256"},"lastPostingActivityTime":"2023-08-27T07:20:09.831-04:00","lastPostTime":"2023-08-27T07:20:09.831-04:00","isSubscribed":false},"ModerationData:moderation_data:42256":{"__typename":"ModerationData","id":"moderation_data:42256","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:42256":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:42256","relatedMessage":{"__ref":"ForumTopicMessage:message:42256"}},"Rank:rank:17":{"__typename":"Rank","id":"rank:17","position":35,"name":"Disciple","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:32240":{"__typename":"User","id":"user:32240","uid":32240,"login":"megel","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2023-11-17T21:30:22.394-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-8.svg?time=0"},"rank":{"__ref":"Rank:rank:17"},"messagesCount":3,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":1,"entityType":"USER","eventPath":"community:ogevo67675/user:32240"},"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0xOS0xOTYzaTQ5NzlDMEQyRjZBM0E0QUM\"}":{"__typename":"AssociatedImage","url":"https://forum.videotron.com/t5/s/ogevo67675/images/bi0xOS0xOTYzaTQ5NzlDMEQyRjZBM0E0QUM","mimeType":"image/svg+xml"},"ForumTopicMessage:message:43325":{"__typename":"ForumTopicMessage","uid":43325,"subject":"Adresse IP non conventionelle","id":"message:43325","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/message:43325","revisionNum":2,"repliesCount":3,"author":{"__ref":"User:user:32240"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:internet-telephonie"},"conversation":{"__ref":"Conversation:conversation:43325"},"moderationData":{"__ref":"ModerationData:moderation_data:43325"},"postTime":"2023-11-17T21:41:19.326-05:00","lastPublishTime":"2023-11-17T21:43:15.633-05:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":2688},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:43325":{"__typename":"Conversation","id":"conversation:43325","solved":true,"topic":{"__ref":"ForumTopicMessage:message:43325"},"lastPostingActivityTime":"2023-11-25T08:16:58.447-05:00","lastPostTime":"2023-11-25T08:16:58.447-05:00","isSubscribed":false},"ModerationData:moderation_data:43325":{"__typename":"ModerationData","id":"moderation_data:43325","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:43325":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:43325","relatedMessage":{"__ref":"ForumTopicMessage:message:43325"}},"User:user:33910":{"__typename":"User","id":"user:33910","uid":33910,"login":"DenysT","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2024-11-15T12:32:41.515-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-8.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":1,"kudosGivenCount":1,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:33910"},"ForumTopicMessage:message:47371":{"__typename":"ForumTopicMessage","uid":47371,"subject":"Libérer une adresse IP","id":"message:47371","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/message:47371","revisionNum":1,"repliesCount":1,"author":{"__ref":"User:user:33910"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:internet-telephonie"},"conversation":{"__ref":"Conversation:conversation:47371"},"moderationData":{"__ref":"ModerationData:moderation_data:47371"},"postTime":"2024-11-15T12:28:41.687-05:00","lastPublishTime":"2024-11-15T12:28:41.687-05:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":466},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:47371":{"__typename":"Conversation","id":"conversation:47371","solved":true,"topic":{"__ref":"ForumTopicMessage:message:47371"},"lastPostingActivityTime":"2024-11-19T19:21:26.107-05:00","lastPostTime":"2024-11-19T19:21:26.107-05:00","isSubscribed":false},"ModerationData:moderation_data:47371":{"__typename":"ModerationData","id":"moderation_data:47371","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:47371":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:47371","relatedMessage":{"__ref":"ForumTopicMessage:message:47371"}},"ForumTopicMessage:message:2707":{"__typename":"ForumTopicMessage","uid":2707,"subject":"Adresse IP","id":"message:2707","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/message:2707","revisionNum":1,"repliesCount":9,"author":{"__ref":"User:user:-1"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:internet-telephonie"},"conversation":{"__ref":"Conversation:conversation:2707"},"moderationData":{"__ref":"ModerationData:moderation_data:2707"},"postTime":"2017-09-23T16:15:32.807-04:00","lastPublishTime":"2017-09-23T16:15:32.807-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":16573},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:2707":{"__typename":"Conversation","id":"conversation:2707","solved":true,"topic":{"__ref":"ForumTopicMessage:message:2707"},"lastPostingActivityTime":"2019-03-15T18:40:54.773-04:00","lastPostTime":"2019-03-15T18:40:54.773-04:00","isSubscribed":false},"ModerationData:moderation_data:2707":{"__typename":"ModerationData","id":"moderation_data:2707","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:2707":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:2707","relatedMessage":{"__ref":"ForumTopicMessage:message:2707"}},"CachedAsset:text:fr_FR-components/community/Navbar-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/Navbar-1749759873379","value":{"community":"Accueil de la communauté","inbox":"Boîte de réception","manageContent":"Gérer le contenu","tos":"Conditions d'utilisation","forgotPassword":"Mot de passe oublié","themeEditor":"Éditeur de thème","edit":"Modifier la barre de navigation","skipContent":"Passer au contenu","mon-videotron-link":"Mon Vidéotron","le-blogue-link":"Blogue","mobile-link":"Mobilité","super-utilisateurs-link":"Super Utilisateurs","mobilephone-english-link":"Mobility","television-divertissement-link":"Télé et Divertissement","en-link":"Forum","t-v-entertainement-link":"TV & Entertainment","fr-link":"Forum","the-blog-link":"Blog","internet-telephony-link":"Internet & Telephony","blog-link":"Blog","my-videotron-link":"My Videotron","internet-telephonie-link":"Internet et Téléphonie","forum-television-entertainment-link":"TV & Entertainment","forum-mobility-link":"Mobility","external-link":"Aide","forum-internet-telephony-link":"Internet & Telephony","forum-news-link":"My Videotron"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/NavbarHamburgerDropdown-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/NavbarHamburgerDropdown-1749759873379","value":{"hamburgerLabel":"Menu Latéral"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/BrandLogo-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/BrandLogo-1749759873379","value":{"logoAlt":"Khoros","themeLogoAlt":"Logo de la marque"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/NavbarTextLinks-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/NavbarTextLinks-1749759873379","value":{"more":"Plus"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/languages/UseLanguageText-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/languages/UseLanguageText-1749759873379","value":{"language.browserLanguage.label":"Par défaut du navigateur","language.ar-AE.label":"Arabe","language.bg-BG.label":"Bulgare","language.ca-AD.label":"Catalan","language.cs-CZ.label":"Tchèque","language.da-DK.label":"Danois","language.de-DE.label":"Allemand","language.el-GR.label":"Grec","language.en-GB.label":"Anglais (Royaume-Uni)","language.en-US.label":"Anglais (États-Unis)","language.es-ES.label":"Espagnol","language.es-MX.label":"Espagnol (Amérique latine)","language.et-EE.label":"Estonien","language.fa-IR.label":"Persan (Farsi)","language.fi-FI.label":"Finnois","language.fr-FR.label":"Français","language.he-IL.label":"Hébreu","language.hr-HR.label":"Croate","language.hu-HU.label":"Hongrois","language.in-ID.label":"Indonésien","language.it-IT.label":"Italien","language.ja-JP.label":"Japonais","language.ko-KR.label":"Coréen","language.lt-LT.label":"Lituanien","language.lv-LV.label":"Letton","language.ms-MY.label":"Malais","language.nl-NL.label":"Néerlandais","language.no-NO.label":"Norvégien","language.pl-PL.label":"Polonais","language.pt-BR.label":"Portugais (Brésilien)","language.pt-PT.label":"Portugais","language.ro-RO.label":"Roumain","language.ru-RU.label":"Russe","language.sk-SK.label":"Slovaque","language.sq-AL.label":"Albanais","language.sv-SE.label":"Suédois","language.th-TH.label":"Thaï","language.tr-TR.label":"Turc","language.uk-UA.label":"Ukrainien","language.vi-VN.label":"Vietnamien","language.zh-CN.label":"Chinois (simplifié)","language.zh-TW.label":"Chinois (traditionnel)","timezone.fieldLabel.label":"Fuseau horaire","timezone.delimiter.label":"------------------------------","timezone.Etc-GMT+12.label":"GMT -12:00 Dateline","timezone.Pacific-Samoa.label":"GMT -11:00 Samoa","timezone.US-Hawaii.label":"GMT -10:00 Heure hawaïenne des États-Unis","timezone.US-Aleutian.label":"GMT -10:00 Îles Aléoutiennes","timezone.Pacific-Marquesas.label":"GMT -09:30 Marquises","timezone.Pacific-Gambier.label":"GMT -09:00 Îles Gambier","timezone.US-Alaska.label":"GMT -09:00 Heure de l'Alaska, États-Unis","timezone.US-Pacific.label":"GMT -08:00 Heure du Pacifique, États-Unis","timezone.Pacific-Pitcairn.label":"GMT -08:00 Îles Pitcairn","timezone.US-Mountain.label":"GMT -07:00 Heure des montagnes, États-Unis","timezone.US-Arizona.label":"GMT -07:00 Heure des montagnes, États-Unis (Arizona)","timezone.US-Central.label":"GMT -06:00 Heure centrale, États-Unis","timezone.Mexico-General.label":"GMT -06:00 Mexique","timezone.America-Costa_Rica.label":"GMT -06:00 Costa Rica","timezone.US-Eastern.label":"GMT -05:00 Heure de l'Est, États-Unis","timezone.America-Bogota.label":"GMT -05:00 Colombie, Pérou, Amérique du Sud","timezone.Canada-Atlantic.label":"GMT -04:00 Heure de l'Atlantique","timezone.America-Puerto_Rico.label":"GMT -04:00 Porto Rico","timezone.Canada-Newfoundland.label":"GMT -03:30 Terre-Neuve, Canada","timezone.America-Buenos_Aires.label":"GMT -03:00 Argentine","timezone.Brazil-East.label":"GMT -03:00 Brésil","timezone.Atlantic-South_Georgia.label":"GMT -02:00 Atlantique central","timezone.Atlantic-Cape_Verde.label":"GMT -01:00 Cap Vert","timezone.Atlantic-Azores.label":"GMT -01:00 Açores","timezone.Europe-London.label":"GMT ------ Royaume-Uni","timezone.Iceland.label":"GMT ------ Islande","timezone.Europe-Madrid.label":"GMT +01:00 Espagne","timezone.Africa-Algiers.label":"GMT +01:00 Alger, Afrique","timezone.Europe-Amsterdam.label":"GMT +01:00 Europe centrale","timezone.Europe-Athens.label":"GMT +02:00 Europe de l'Est","timezone.Africa-Tripoli.label":"GMT +02:00 Tripoli, Afrique","timezone.Egypt.label":"GMT +02:00 Égypte","timezone.Israel.label":"GMT +02:00 Israël","timezone.Asia-Riyadh.label":"GMT +03:00 Arabie Saoudite","timezone.Iran.label":"GMT +03:30 Iran","timezone.Europe-Moscow.label":"GMT +03:00 Russie","timezone.Europe-Samara.label":"GMT +04:00 Samara, Europe","timezone.Asia-Dubai.label":"GMT +04:00 Arabie","timezone.Asia-Kabul.label":"GMT +04:30 Afghanistan","timezone.Asia-Karachi.label":"GMT +05:00 Pakistan, Asie de l'Ouest","timezone.Asia-Yekaterinburg.label":"GMT +05:00 Yekaterinbourg, Asie","timezone.Asia-Calcutta.label":"GMT +05:30 Inde","timezone.Asia-Thimphu.label":"GMT +06:00 Bangladesh, Asie centrale","timezone.Asia-Novosibirsk.label":"GMT +06:00 Novossibirsk, Asie","timezone.Asia-Rangoon.label":"GMT +06:30 Birmanie","timezone.Asia-Bangkok.label":"GMT +07:00 Bangkok, Hanoï, Jakarta","timezone.Asia-Krasnoyarsk.label":"GMT +07:00 Krasnoïarsk, Asie","timezone.PRC.label":"GMT +08:00 Chine","timezone.Singapore.label":"GMT +08:00 Singapour","timezone.Asia-Taipei.label":"GMT +08:00 Taïwan","timezone.Australia-West.label":"GMT +08:00 Australie (WT)","timezone.Asia-Irkutsk.label":"GMT +08:00 Irkoutsk, Asie","timezone.Japan.label":"GMT +09:00 Japon","timezone.Asia-Seoul.label":"GMT +09:00 Corée","timezone.Asia-Yakutsk.label":"GMT +09:00 Iakoutsk, Russie","timezone.Australia-North.label":"GMT +09:30 Australie (NT)","timezone.Australia-Adelaide.label":"GMT +09:30 Australie (ST)","timezone.Australia-Sydney.label":"GMT +10:00 Australie (ET)","timezone.Australia-Queensland.label":"GMT +10:00 Australie (Queensland)","timezone.Asia-Magadan.label":"GMT +10:00 Magadan, Asie","timezone.Australia-Lord_Howe.label":"GMT +10:30 Australie (Lord Howe)","timezone.Pacific-Guadalcanal.label":"GMT +11:00 Pacifique central","timezone.Pacific-Norfolk.label":"GMT +11:30 Îles Norfolk","timezone.Pacific-Auckland.label":"GMT +12:00 Nouvelle-Zélande","timezone.Pacific-Fiji.label":"GMT +12:00 Fidji","timezone.Antarctica-South_Pole.label":"GMT +12:00 Pôle Sud, Antarctique","UseLanguageText.language.en-US.label":"Anglais","UseLanguageText.language.fr-FR.label":"Français"},"localOverride":false},"CachedAsset:text:fr_FR-components/languages/LanguagePicker-1749759873379":{"__typename":"CachedAsset","id":"text:fr_FR-components/languages/LanguagePicker-1749759873379","value":{"dropdown.title":"Sélecteur de langue","selected.language":"Langue sélectionnée actuellement","toast.successMessage":"Aller à la communauté {newLanguage}
