INPUT button on my remote does not work, new service only 2 weeks new and
this button never worked... can I just replace it at any videotron outlet ?
Solved! Go to Solution.
Has the remote aver been paired with your television?
Hi,
did the technicien showed you how they worked? If they did worked and stopped, you should speak to technical support or go to a store.
Hi cuba1957. If your remote doesn't respond normally, even after you've programmed it, please reach our technical department by chat or by phone and they will make a few verifications with you: < http://bit.ly/FB_Contact_Us >. Thank you!
never-displayed
