Thanks for your reply zadigre, that was very helpful and I think testing I did last night confirmed what you wrote....I unlocked the device and it worked with a Telus sim, but did not want to work with my Videotron sim.
do you have one of the newer LTE videotron sim or it's one that has access to 3G only?
if 3G only, I believe you absolutely need a device that has support for the AWS band.
If LTE, again technically, it should connect to 850/1900MHz Rogers frequencies on 3G since essentially this is need for a fallback from the LTE network (for calls non VoLTE device or when outside of LTE coverage).
But again, this is just a guess... this is the way that it's supposed to work with a \"real\" cellphone...
Hi sorry for my english but yes i have a zte wf721 and it works with a videotron sim card but the sim card in the device is big so i bought a nano-sim adapter turns any nano sim card to fit anny device look for sim card adapter on amazon and my zte came from rogers and i unlocked it with a very simple way but yours is allready unlocked.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2018-10-19T23:41:05.938-04:00","lastPublishTime":"2018-10-19T23:41:05.938-04:00","metrics":{"__typename":"MessageMetrics","views":14590},"visibilityScope":"PUBLIC","placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"ModerationData:moderation_data:11099":{"__typename":"ModerationData","id":"moderation_data:11099","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:11099":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:8388"},"id":"message:11099","entityType":"FORUM_REPLY","eventPath":"category:en/community:ogevo67675board:mobilephone-english/message:10984/message:11099","revisionNum":1,"uid":11099,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:mobilephone-english"},"parent":{"__ref":"ForumTopicMessage:message:10984"},"conversation":{"__ref":"Conversation:conversation:10984"},"subject":"Re: Use ZTE (Fido) cellular home home phone unit with Videotron mobile plan?","moderationData":{"__ref":"ModerationData:moderation_data:11099"},"body":"Hi sorry for my english i have a zte wf721 and it works with a nano sim card from videotron by a nano sim card adapter at your local store or amazon and fit it in the device as shown and it will work if your device is unlocked
and if your device is locked here is how to unlock it pay a third party to get the unlock code for the imei its a 16 digits code and do this
Please connect WF721 with a landline, plug a cordless telephone the the number jack 1 in the back of your zte then pick up the receiver and put on speaker essyer to dial and be quick about it if you are to long to type restart and try again if you pause to long when you dial it wont work be sure to not have the sims card in the device turn on the device and have the batterie in the device dial with your unlock code witch is the new imei 16 digits instead of the xxxxxxxxxxxxxxxx you must dial as shown asterix and titacto simbol * 9 8 3 * 8 6 * xxxxxxxxxxxxxxxx # once you have done this turn off the device and put your sim card in and be sure to put it in the right way as the diagram shows where the sim card goes put back the baterry and restatr your device if it works great if not dont panic just redoo the sequence * 9 8 3 * 8 6 * xxxxxxxxxxxxxxxx #and it will be unlocked.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2018-10-20T00:02:24.265-04:00","lastPublishTime":"2018-10-20T00:02:24.265-04:00","metrics":{"__typename":"MessageMetrics","views":9181},"visibilityScope":"PUBLIC","placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"QueryVariables:MessageSolutions":{"__typename":"QueryVariables","id":"MessageSolutions","value":{"first":10,"constraints":{"topicId":{"eq":"message:10984"},"solution":{"eq":true}},"sorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":false,"useBody":true,"useKudosCount":false,"useTimeToRead":false,"useMedia":true,"useRepliesCount":false,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":true,"useTags":false,"useUserHoverCard":false,"useNodeHoverCard":false,"usePreviewSubjectModal":false,"useMessageStatus":false}},"CachedAsset:text:fr_FR-components/customComponent/CustomComponent-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/customComponent/CustomComponent-1749759678782","value":{"errorMessage":"Erreur lors du rendu de l'ID du composant : {customComponentId}","bannerTitle":"Le fournisseur de vidéos nécessite des cookies pour lire la vidéo. Acceptez pour continuer ou {url} directement sur le site du fournisseur.","buttonTitle":"Accepter","urlText":"regarder"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/NavbarDropdownToggle-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/NavbarDropdownToggle-1749759678782","value":{"ariaLabelClosed":"Appuyez sur la flèche vers le bas pour ouvrir le menu"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/EscalatedMessageBanner-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/EscalatedMessageBanner-1749759678782","value":{"escalationMessage":"Escalation vers Salesforce par {username} le {date}","viewDetails":"Voir les détails","modalTitle":"Détails de l'affaire","escalatedBy":"Escaladé par :","escalatedOn":"Escaladé le :","caseNumber":"Numéro d'affaire :","status":"Statut :","lastUpdateDate":"Dernière mise à jour :","automaticEscalation":"escalade automatique","anonymous":"Anonyme"},"localOverride":false},"CachedAsset:text:fr_FR-components/users/UserLink-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/users/UserLink-1749759678782","value":{"authorName":"Voir le profil : {author}","anonymous":"Anonyme"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/users/UserRank-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/users/UserRank-1749759678782","value":{"rankName":"{rankName}","userRank":"Rang d'auteur {rankName}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageTime-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageTime-1749759678782","value":{"postTime":"Publié : {time}","lastPublishTime":"Dernière mise à jour : {time}","conversation.lastPostingActivityTime":"Heure de la dernière activité de publication : {time}","conversation.lastPostTime":"Heure du dernier poste : {time}","moderationData.rejectTime":"Heure de rejet : {time}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageSolvedBadge-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageSolvedBadge-1749759678782","value":{"solved":"Résolu"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageSubject-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageSubject-1749759678782","value":{"noSubject":"(sans objet)"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageBody-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageBody-1749759678782","value":{"showMessageBody":"Afficher plus","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} n'est plus disponible","mentionsErrorMessage":"Le {mentionsType} que vous essayez de consulter a été supprimé de la communauté.","videoProcessing":"La vidéo est en cours de traitement. Veuillez réessayer dans quelques minutes.","bannerTitle":"Le fournisseur de vidéos nécessite des cookies pour lire la vidéo. Acceptez pour continuer ou {url} la regarder directement sur le site du fournisseur.","buttonTitle":"Accepter","urlText":"visionner"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageCustomFields-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageCustomFields-1749759678782","value":{"CustomField.default.label":"Valeur de {name}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageReplyButton-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageReplyButton-1749759678782","value":{"repliesCount":"{count}","title":"Répondre","title@board:BLOG@message:root":"Commentaire","title@board:TKB@message:root":"Commentaire","title@board:IDEA@message:root":"Commentaire","title@board:OCCASION@message:root":"Commentaire"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageSolutionList-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageSolutionList-1749759678782","value":{"emptyDescription":"Aucune solution de message n'a encore été trouvée"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageListMenu-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageListMenu-1749759678782","value":{"postTimeAsc":"Plus ancien","postTimeDesc":"Plus récent","kudosSumWeightAsc":"Le moins aimé","kudosSumWeightDesc":"Le plus aimé","sortTitle":"Trier par","sortedBy.item":" {itemName, select, postTimeAsc {Plus ancien} postTimeDesc {Plus récent} kudosSumWeightAsc {Le moins aimé} kudosSumWeightDesc {Le plus aimé} other {}}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/AcceptedSolutionButton-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/AcceptedSolutionButton-1749759678782","value":{"accept":"Marquer comme résolu","accepted":"Marqué comme résolu","errorHeader":"Erreur !","errorAdd":"Une erreur est survenue en marquant comme résolu.","errorRemove":"Une erreur est survenue en révoquant le marquage comme résolu.","solved":"Résolu","topicAlreadySolvedErrorTitle":"La solution existe déjà","topicAlreadySolvedErrorDesc":"Rafraîchissez le navigateur pour voir la solution existante"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/common/Pager/PagerLoadMore-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/common/Pager/PagerLoadMore-1749759678782","value":{"loadMore":"Afficher plus"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageView/MessageViewInline-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageView/MessageViewInline-1749759678782","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonyme","place":"Endroit {bylineBoard}","gotoParent":"Aller au parent {name}"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/users/UserAvatar-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/users/UserAvatar-1749759678782","value":{"altText":"Avatar de {login}","altTextGeneric":"Avatar de l'utilisateur"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/ranks/UserRankLabel-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/ranks/UserRankLabel-1749759678782","value":{"altTitle":"Icône pour le rang {rankName}"},"localOverride":false},"CachedAsset:text:fr_FR-components/tags/TagView/TagViewChip-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/tags/TagView/TagViewChip-1749759678782","value":{"tagLabelName":"Nom de la étiquette {tagName}"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/nodes/NodeIcon-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/nodes/NodeIcon-1749759678782","value":{"contentType":"Type de contenu {style, select, FORUM {Forum} BLOG {Blog} TKB {Base de connaissances} IDEA {Idées} OCCASION {Événements} other {}} icône"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"boardId":"mobilephone-english","messageSubject":"use-zte-fido-cellular-home-home-phone-unit-with-videotron-mobile-plan","messageId":"10984"},"buildId":"3XH0qYWYCnEYycuN5W4S8","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","surveysEnabled":true,"openTelemetry":{"clientEnabled":false,"configName":"videotron","serviceVersion":"25.4.0","universe":"prod","collector":"http://localhost:4318","logLevel":"error","routeChangeAllowedTime":"5000","headers":"","enableDiagnostic":"false","maxAttributeValueLength":"4095"},"apolloDevToolsEnabled":false,"quiltLazyLoadThreshold":"3"},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["components_seo_QAPageSchema","components_customComponent_CustomComponent","components_community_Navbar_NavbarWidget","components_community_Breadcrumb_BreadcrumbWidget","components_messages_TopicWithThreadedReplyListWidget","components_messages_RelatedContentWidget","components_messages_MessageListForNodeByRecentActivityWidget","components_community_FooterWidget","components_languages_LanguagePicker","components_messages_MessageView_MessageViewStandard","components_messages_ThreadedReplyList","components_community_FooterWidgetHelpLink","components_community_KhorosLogo","components_customComponent_CustomComponentContent_HtmlContent","components_messages_EscalatedMessageBanner","shared_client_components_common_List_UnstyledList","components_messages_MessageView","shared_client_components_common_Pager_PagerLoadMore","components_messages_MessageView_MessageViewInline","shared_client_components_common_List_ListGroup","components_customComponent_CustomComponentContent_CustomComponentScripts","shared_client_components_common_List_UnwrappedList","components_tags_TagView","components_tags_TagView_TagViewChip"],"appGip":true,"scriptLoader":[]}
