Avatar de Mikedidomenico
19-11-2018
4k PVR not recording as per schedule
Hello,
I have been with Videotron for only a few months now and i am getting a little frustrated with the PVR. There are shows programmed to record daily/weekly and the PVR seems to have a mind of its own. For example, a show prorammed to record daily at 2pm from Monday to Friday will record only 4 out of the 5 days.  Another example is a show programmed to record "Every Monday at 9pm" on a specific channel will record EVERY time it airs on that channel.  Before anyone asks me if i programmed them properly, yes i did, i double checked before posting this.  But honestly, i am more concerned about missed recordings that too many recordings.  These issues have been going on for months now and it happens with different shows, not always the same one. I'm not sure why this is happening but coming from Bell where this was NEVER an issue makes it a little more frustrating and it is making me doubt my decision to switch to Videotron.  Hopefully someone here can help me.
  • Hi!
    We actually suggest deleting the offending planned recordings (press on 'list' twice to see the future recordings), and reprogram them. This usually fixes the issue. But if it persists, tech support will be able to investigate in the box's configuration.
10 Réponses
  • Hi!
  • Avatar de Anonyme
    Not applicable
    did you chose what to record in the guide or manually add a recording?
    I'm asking the queston because most of the time this is caused by bad entries in the TV guide... if you maually enter a channel and time, it should work fine.
    • Avatar de Mikedidomenico
      Mikedidomenico
      I have done it both ways but i always modify to make sure it is scheduled the way i want it to be.  Normally i will program through the guide and do the modification. Why would that be different from manually?
      I also have the opposite problem. Recently i programmed a show to record every monday night at 9 pm. It has been doing so without issue since day one, despite there being many replays during the week of this show.  Then there was a "marathon" of the show on a saturday and the PVR recorded 12 episodes....it just seems very unreliable
      • Avatar de mjcnyg
        mjcnyg
        welcome to Videotron world !  I have had the same issues many times and I gave up trying to figure out the problem. why would it work fine for a while-not touch anything and all of a sudden, it does something that makes your head spin ? who the hell knows and all you'll get from the tech support is -reboot- 9 out of 10 times you call. Mine records for only seconds sometimes ! example, was recording the series My Brilliant Friend on HBO. recorded episodes 1-6 and 8 all for 1 hour just like it's supposed to but ep 7, recorded only 26 minutes-WTH ? should have stayed with Bell, I know they aren't much better and more expensive, wait for the 6$mth increase (major ripoff) on tv coming up in March- Bell will suddenly start to look good again !
