mcrootay
11-10-2018Chevalier
- Anonymous11-10-2018
mcrootay
12-10-2018Chevalier
Interesting development....I tried one of Videotron's Fizz sims in the ZTE adapter...and it worked
Anonymous
13-10-2018Not applicable
Maybe you got one of the newer sim with Fizz... those compatible with VoLTE.
older LTE sim from Vidéotron are not necessarily compatible with VoLTE thus might not support the same fallback to Rogers frequencies/bands.
