richardbuffet
05-09-2017Initiate
When I roam on to a partner network (usually partner1), i sometimes get a "x" on my signal bar. it works for text and phone calls, but not for data. I have to restart my phone 5-6 times before the "x...
choptliva
17-07-2018Initiate
I have enabled data roaming, yes.
CedrikS
28-07-2018Moderator - Solution Expert
Hi choptliva and MJS613! Like mentioned by zadigre, you can verify if your phone is well configured but in any case, we strongly suggest you reach our technical department for further investigation: < http://bit.ly/FB_Contact_Us >. Thank you.
