McFly
31-05-2017Samurai
Hi, I was wondering: is there a way to turn on/off call forwarding using the * + number combo ?
- 02-06-2017
Hi McFly,
For an unconditional call forwarding, this is *21# to turn it on and #21# to turn it off. You have to dial **21*(destination number)# to program the number you want your calls forwarded to.
For a conditional call forwarding:
Call forward busy: *67# to turn it on, #67# to turn it off. To program the number, this is **67*(destination number)#
Call forward no reply: *61# to turn it on, #61# to turn it off. To program the number, this is **61*(destination number)#
Call forward not reachable (device turned off): *62# to turn it on, #62# to turn it off. To program the number, this is **62*(destination number)#Thank you!
JenniferM
02-06-2017Moderator - Solution Expert
Hi McFly,
Thank you!
WindGhost
21-10-2019Initiate
Hello,
I heard that we need a tech to remove voicemail prior to get Conditional forwarding enabled and working as expected.
Is it true ?
If NOT;
Can I have voicemail activated only when I'm on the phone (busy)
and
get call forwarding to work when I'm not able to answer the call within 20 seconds timeline ?
Please, let me know.
- MayaP29-10-2019Admiral
Tech support can't remove voicemail, nor any services for that matter. But you don't have to remove voicemail to configure conditional forwarding. This can usually be set directly inside the phone. If you give us your device brand and model, we can give you the steps to get it set up!
