iosman123
22-07-2019Officer
Hello, I was wondering: is there a way to turn on/off call forwarding using the * + number combo ? thanks iosman
- Anonyme22-07-2019
you have to use GSM code to manage the call forwarding...
more info here http://www.geckobeach.com/cellular/secrets/gsmcodes.php
Most of them will work on videotron.
that said, if you want to completely desactivate your voicemail, you should call videotron to do it.
22-07-2019Not applicable
guylogan
18-03-2020Initiate
Anonyme wrote:you have to use GSM code to manage the call forwarding...
Thanks for the information. It really helped me!
