Allardjm
25-06-2020Initiate
- 29-06-2020
Hi Allardjm, if you use your own router, you could use it with our Helix gateway but, with the bridge mode activated in our gateway. Your WiFi connection will work but let's say you decide to also take our Helix TV service, the remote voice commands won't work with bridge mode. Hope this answers your question.
CedrikS
29-06-2020Modérateur - Expert solutions
- Michelarseno29-06-2020InitiateHello,
Just to add on the previous question, if you are using a Mesh system in your house and connect it to Helix, you are losing the voice capabilities of HELIX TV, is that it? I am about to sign up with Helix but I do not want to loose access to my Mesh system that cover my entire house. Thanks for clarifying.- VinhN01-07-2020Modérateur - Expert solutions
Hi,
Below, all the disadvantages to have bridge mode ON:
1- The advanced features of the Helix terminal are disabled (Parental control, Band Steering, etc.)
2- Helix Fi application is not functional
3- Our Wi-Fi relays cannot be used
4- No support during a problem with the Helix TV channels and / or the Wi-Fi network
Hope it clarifies.
- mcicc05-08-2020Initiate
Hi !
I have an Orbi mesh.
If I put the Helix Gateway to Bridge Mode, will the Helix TV Terminal still access the Gateway?
What if I connect the Helix TV Terminal to my Orbi Mesh instead...that would work?
And how would I go about changing the network on my Helix TV Terminal to my Orbi Mesh?
