Allardjm
25-06-2020Initiate
- 29-06-2020
Hi Allardjm, if you use your own router, you could use it with our Helix gateway but, with the bridge mode activated in our gateway. Your WiFi connection will work but let's say you decide to also take our Helix TV service, the remote voice commands won't work with bridge mode. Hope this answers your question.
VinhN
01-07-2020Moderator - Solution Expert
Hi,
Below, all the disadvantages to have bridge mode ON:
1- The advanced features of the Helix terminal are disabled (Parental control, Band Steering, etc.)
2- Helix Fi application is not functional
3- Our Wi-Fi relays cannot be used
4- No support during a problem with the Helix TV channels and / or the Wi-Fi network
Hope it clarifies.
JMRoy
19-06-2021Initiate
Hi,
Is it possible to deactivate the helix wifi without using the bridge fonction and would it be a good way to use a Velop system without loosing the helix voice functions?
