Avatar de davidr
davidr
29-04-2022
How to configure a Helix Fi gateway 2 as a wireless access point (WAP) to extend an existing WiFi?
Hello everyone,
I'd like to know if it's possible to configure a white Helix Fi gateway 2 router as a wireless access point (WAP) to extend an existing WiFi network? If so, then how?
Thanks,
David
1 Réponse
  • Avatar de PatrickM
    PatrickM
    Modérateur - Expert solutions
    Hi David!
    Unfortunately, this is not a configurable option for the Helix gateway. However, we take note of this suggestion.
    If you are already using a Helix  gateway as the first access point, the best solution to extend your network would be to use Helix Wi-Fi pods. That said, nothing prevents you from also using another router that would allow this type of configuration or any other Wi-Fi signal extender. The downside is that you will have to manually configure these outside of the Helix Fi app.
