dengagnon
25-05-2020Disciple
Comment charger une application automatiquement à l'ouverture d'un téléphone Android?
Pour belle-maman nonagénaire. Je veux lui simplifier au maximum les manipulations
- 22-04-2023
To load an application automatically when opening an Android phone, you can follow these steps:
- Open the Settings app on your Android phone.
- Scroll down and tap on "Apps & notifications."
- Select the app that you want to open automatically.
- Tap on "Advanced" or "App settings," depending on your Android version.
- Toggle on the "Auto-launch" or "Startup" option.
- Exit the Settings app, and the selected app will now automatically open when you turn on your phone.
Note that some Android phones may have slightly different options or settings, but the general steps should be similar.
Grendizer
27-05-2020Admiral
Ça dépend de l'appareil, mais en général c'est dans Réglages, Application, Permission.
Il y a un option pour démarrer automatiquement
