Allardjm
25-06-2020Initiate
JMRoy
19-06-2021Initiate
Hi,
Is it possible to deactivate the helix wifi without using the bridge fonction and would it be a good way to use a Velop system without loosing the helix voice functions?
CedrikS
29-06-2021Moderator - Solution Expert
Hi JMRoy,
The reason to get the Helix gateway is to have WiFi and also a wired connection with the ethernet ports. The only way to override this would be the bridge mode with another router.
