Allardjm
25-06-2020Initiate
VinhN
01-07-2020Moderator - Solution Expert
Hi,
Below, all the disadvantages to have bridge mode ON:
1- The advanced features of the Helix terminal are disabled (Parental control, Band Steering, etc.)
2- Helix Fi application is not functional
3- Our Wi-Fi relays cannot be used
4- No support during a problem with the Helix TV channels and / or the Wi-Fi network
Hope it clarifies.
JMRoy
19-06-2021Initiate
Hi,
Is it possible to deactivate the helix wifi without using the bridge fonction and would it be a good way to use a Velop system without loosing the helix voice functions?
