Avatar de jpadgett5
jpadgett5
08-03-2020
Can I wire a Helix WiFi pod using a CAT 5 Ethernet cable?
Can I wire a Helix WiFi pod using a CAT 5 Ethernet cable to extend range? The place where I want to put it (my garage) barely gets a signal so I'd like to run cat 5 to that location so that my car, W...
  • Avatar de PatrickM
    PatrickM
    12-15-2020
    Hi! Although it is technically possible to operate a Helix Fi pod in this way, the maneuver is neither recommended nor supported. The use of the ethernet jack on the Pods should be limited to connect devices that have no Wi-Fi capability.
    A cable connection from the Helix Fi gateway to the Pods can cause unexpected behavior in the Helix ecosystem and thus you would be exposed to unknown and unsupported bugs that are not documented on our side nor our partners.
    In case of a poor Wi-Fi signal, it would be best contact the technical support team who will be able to make the appropriate troubleshooting more easily with you.
