raminolta
13-05-2020Squire
Helix Modem/Router Making a Constant Humming Noise
I have just switched to Helix Internet service since last week. I have notriced the Helix modem/router makes a constant humming sound. It isn't loud but since the room is always quiet, it is easil...
- 24-06-2020
Good evening everyone.
A noisy Helix gateway is definately not normal. There's a fan to cool down the gateway, that said, it has been observed to be noisier on some units. It is a known problem.We also seen gateways that were noisier when installed into a close area like an enclosure, a shelve or a corner that can resonate. We invite you to contact our tech support so we can handle the case and propose a remplacement unit that will be more silent.
You can reach us by chat, by phone or through facebook, we will be glad to assist you with that.
Thanks for asking. It is a very good question.
-Alex D
MikeB
30-09-2020Initiate
Ya, this constant hum is terribly annoying! I had the Gateway replaced because of the noise but the second one is just as loud. When the Videotron technician was here setting up the replacement, I overheard him talking to someone at Videotron about "...another one of these that's really loud…", so it's clearly a common problem. His only suggestion was to move the gateway to another room, which does not work in my case.
So, the Helix gateway is excellent at providing a strong signal throughout my condo but it sounds like a neighbour left their vacuum cleaner on and went on vacation.
I may request another replacement.
