1. Correctly set the bridge mode Connect the network cable: Connect the network cable of the wireless router to the Ethernet port of the laptop or desktop computer. Enter the settings interface: Open the browser and enter the IP address of the router to enter the router's settings page. Configure WAN settings: In the router's settings page, find the WAN settings option and set it to bridge mode or access point mode. Disable DHCP function: Disable the DHCP function of the wireless router and save the changes. 2. Connect the main and secondary routers Use Ethernet cable: Use an Ethernet cable from the LAN port of the wireless router to the WAN port of another router (the main router) to connect the two. Configure the main router: Turn on the DHCP function and wireless function in the settings page of the other router, and configure them to ensure that they do not conflict with the wireless router. 3. Ensure stable signal Optimize location: If the wireless network signal is unstable or the signal is not strong, try to reinstall the router and adjust the direction of the antenna. Set the maximum output power: Reset the router to adjust the signal output power to the maximum. 4. Troubleshoot and solve problems Check the connection: Make sure all devices are properly connected and check whether all cables and interfaces are secure. Restart devices: Restart all related devices, including routers, computers, and mobile devices. Update firmware: Make sure the router's firmware is the latest version, as old versions may contain errors that are incompatible with bridge mode. 5. Use specific bridge settings WDS bridge: For routers that support WDS (Wireless Distribution System), you can follow specific steps to set up bridges, including logging in to the secondary router management page, entering the WDS bridge setting interface, connecting to the main router network, setting the bridge wireless name (SSID) and password, and changing the secondary router LAN port IP address. Bind IP and MAC address: Bind the IP address and MAC address of the secondary router in the main router to ensure a stable connection. 6. DHCP service settings Turn off the secondary router DHCP service: Based on the principle that \"the same physical LAN usually has only one gateway, one DNS server, and one DHCP server\", it is recommended to turn off the DHCP service of the secondary router. 7. Reset the router Use the RESET button: If the router has been set up and you don't remember the password, you can press and hold the RESET button on the back of the router to reset the router, and wait for about a minute for the router to automatically restart before configuring it. For more details, you can follow Baudcom and E1's technical blogs
","body@stringLength":"3145","rawBody":"
You can refer to the following operations to solve your problem 1. Correctly set the bridge mode Connect the network cable: Connect the network cable of the wireless router to the Ethernet port of the laptop or desktop computer. Enter the settings interface: Open the browser and enter the IP address of the router to enter the router's settings page. Configure WAN settings: In the router's settings page, find the WAN settings option and set it to bridge mode or access point mode. Disable DHCP function: Disable the DHCP function of the wireless router and save the changes. 2. Connect the main and secondary routers Use Ethernet cable: Use an Ethernet cable from the LAN port of the wireless router to the WAN port of another router (the main router) to connect the two. Configure the main router: Turn on the DHCP function and wireless function in the settings page of the other router, and configure them to ensure that they do not conflict with the wireless router. 3. Ensure stable signal Optimize location: If the wireless network signal is unstable or the signal is not strong, try to reinstall the router and adjust the direction of the antenna. Set the maximum output power: Reset the router to adjust the signal output power to the maximum. 4. Troubleshoot and solve problems Check the connection: Make sure all devices are properly connected and check whether all cables and interfaces are secure. Restart devices: Restart all related devices, including routers, computers, and mobile devices. Update firmware: Make sure the router's firmware is the latest version, as old versions may contain errors that are incompatible with bridge mode. 5. Use specific bridge settings WDS bridge: For routers that support WDS (Wireless Distribution System), you can follow specific steps to set up bridges, including logging in to the secondary router management page, entering the WDS bridge setting interface, connecting to the main router network, setting the bridge wireless name (SSID) and password, and changing the secondary router LAN port IP address. Bind IP and MAC address: Bind the IP address and MAC address of the secondary router in the main router to ensure a stable connection. 6. DHCP service settings Turn off the secondary router DHCP service: Based on the principle that \"the same physical LAN usually has only one gateway, one DNS server, and one DHCP server\", it is recommended to turn off the DHCP service of the secondary router. 7. Reset the router Use the RESET button: If the router has been set up and you don't remember the password, you can press and hold the RESET button on the back of the router to reset the router, and wait for about a minute for the router to automatically restart before configuring it. For more details, you can follow Baudcom and E1's technical blogs
","kudosSumWeight":0,"repliesCount":0,"postTime":"2024-06-12T23:57:52.312-04:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":2,"currentRevision":{"__ref":"Revision:revision:45554_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":1626},"read":false,"visibilityScope":"PUBLIC","isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"customFields":[],"replies":{"__typename":"MessageConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"CachedAsset:theme:customTheme1-1749759679998":{"__typename":"CachedAsset","id":"theme:customTheme1-1749759679998","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"50%","collections":["default"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"Favicon-1730465696192.png","imageLastModified":"1730465698198","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"logo-videotron_header2fr-1730818064436.png","imageLastModified":"1730818067042","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1300px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_BROWSER","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"3px","borderRadius":"3px","borderRadiusLg":"5px","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"12px","paddingXLg":"16px","paddingXHero":"60px","fontStyle":"NORMAL","fontWeight":"700","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-body-bg)","primaryTextHoverColor":"var(--lia-bs-body-bg)","primaryTextActiveColor":"var(--lia-bs-body-bg)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-primary)","secondaryTextHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.9))","secondaryBgColor":"#FDD200","secondaryBgHoverColor":"hsl(49.80000000000001, 100%, 47.6%)","secondaryBgActiveColor":"hsl(49.80000000000001, 100%, 45.6%)","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-gray-900)","tertiaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-danger)","destructiveTextHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.95))","destructiveTextActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.9))","destructiveBgColor":"var(--lia-bs-gray-200)","destructiveBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","destructiveBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"LIGHT","sideContent":"NONE","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08)","sm":"0","md":"0","lg":"0","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"var(--lia-bs-link-color)","defaultMessageLinkDecoration":"underline","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","defaultMessageFontFamily":"var(--lia-bs-font-family-base)","forumColor":"#000000","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#24AD72","blogColor":"#000000","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#E06643","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#FF8000","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#D13A1F","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#FFDE45","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#000000","secondary":"#333333","bodyText":"#575754","bodyBg":"#FFFFFF","info":"#FFD200","success":"#24AD72","warning":"#DA8000","danger":"#C14D00","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#FDD200","#C14D00"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":{"link":{"color":"#0069D4","hoverColor":"#0061c2","decoration":"none","hoverDecoration":"underline","__typename":"EmailLinkSettings"},"border":{"color":"#e4e4e4","__typename":"EmailBorderSettings"},"buttons":{"borderRadiusLg":"5px","paddingXLg":"16px","paddingYLg":"7px","fontWeight":"700","primaryTextColor":"#ffffff","primaryTextHoverColor":"#ffffff","primaryBgColor":"#0069D4","primaryBgHoverColor":"#005cb8","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","__typename":"EmailButtonsSettings"},"panel":{"borderRadius":"5px","borderColor":"#e4e4e4","__typename":"EmailPanelSettings"},"__typename":"EmailThemeSettings"},"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Blender Pro Book","fontStyle":"NORMAL","fontWeight":"500","h1FontSize":"52px","h2FontSize":"36px","h3FontSize":"24px","h4FontSize":"22px","h5FontSize":"16px","h6FontSize":"14px","lineHeight":"1.3","subHeaderFontSize":"11px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":"10px","size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"var(--lia-bs-border-radius-sm)","borderRadius":"var(--lia-bs-border-radius)","borderRadiusLg":"var(--lia-bs-border-radius-lg)","formTextMarginTop":"4px","textAreaBorderRadius":"var(--lia-bs-border-radius)","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-black)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":"","imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"40px","defaultMessageHeaderMarginBottom":"20px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"30px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"40px","specialMessageHeaderMarginBottom":"20px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"30px","tableBgColor":"transparent","tableBorderColor":"var(--lia-bs-gray-700)","tableBorderStyle":"solid","tableCellPaddingX":"5px","tableCellPaddingY":"5px","tableTextColor":"var(--lia-bs-body-color)","tableVerticalAlign":"middle","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Open Sans","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.5","fontSizeBase":"16px","fontSizeXxs":"11px","fontSizeXs":"12px","fontSizeSm":"14px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Crossten Book-V","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"},{"style":"NORMAL","weight":"500","__typename":"FontStyleData"},{"style":"NORMAL","weight":"700","__typename":"FontStyleData"},{"style":"NORMAL","weight":"300","__typename":"FontStyleData"},{"style":"NORMAL","weight":"600","__typename":"FontStyleData"}],"assetNames":["CrosstenBook-V-normal-400.woff2","CrosstenBook-V-normal-500.woff2","CrosstenBook-V-normal-700.woff2","CrosstenBook-V-normal-300.woff2","CrosstenBook-V-normal-600.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Blender Pro Book","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"},{"style":"NORMAL","weight":"500","__typename":"FontStyleData"},{"style":"NORMAL","weight":"700","__typename":"FontStyleData"},{"style":"ITALIC","weight":"400","__typename":"FontStyleData"}],"assetNames":["BlenderProBook-normal-400.woff2","BlenderProBook-normal-500.woff2","BlenderProBook-normal-700.woff2","BlenderProBook-italic-400.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/common/Loading/LoadingDot-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/common/Loading/LoadingDot-1749759678782","value":{"title":"Chargement..."},"localOverride":false},"CachedAsset:quilt:videotron.prod:pages/forums/ForumMessagePage:board:internet-telephonie-1749759677817":{"__typename":"CachedAsset","id":"quilt:videotron.prod:pages/forums/ForumMessagePage:board:internet-telephonie-1749759677817","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"MAIN_SIDE","bgColor":null,"showTitle":null,"showDescription":null,"textPosition":null,"textColor":null,"sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"MainSideQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"messages.widget.relatedContentWidget","className":null,"props":{"hideIfEmpty":true,"enablePagination":false,"useTitle":true,"listVariant":{"type":"unstyled","props":{"listItemSpacing":"xxl"}},"pageSize":5,"style":"compact","pagerVariant":{"type":"none"},"viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"useCompactSpacing":true,"boardIconSize":"24","useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useNodeLink":true,"useViewCount":false,"usePreviewMedia":true,"useBody":false,"timeStampType":"postTime","useTags":false,"clampSubjectLines":2,"useBoardIcon":true,"useMessageTimeLink":true,"useTextBody":true,"useSolvedBadge":false,"renderPostTimeBeforeAuthor":true,"useAvatar":false,"useAuthorLogin":true,"useVideoPreview":false}},"lazyLoad":false,"panelType":"standard"},"__typename":"QuiltComponent"},{"id":"messages.widget.messageListForNodeByRecentActivityWidget","className":null,"props":{"hideIfEmpty":true,"useTitle":true,"showTabs":false,"pageSize":5,"pagerVariant":{"type":"loadMore"},"style":"compact","viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","truncateBodyLength":-1,"useNodeLink":true,"usePreviewMedia":false,"timeStampType":"conversation.lastPostingActivityTime","avatarSize":"40","useTextBody":true,"useSolvedBadge":true,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":true,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":false,"useMessageTimeLink":true,"clampBodyLines":3,"useAuthorLogin":true,"useUnreadCount":false,"useNodeHoverCard":true,"useSearchSnippet":false}},"panelType":"divider","sorts":{"conversationLastPostingActivityTime":{"direction":"DESC"}}},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:fr_FR-components/common/EmailVerification-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/common/EmailVerification-1749759678782","value":{"email.verification.title":"Vérification de l'adresse e-mail requise","email.verification.message.update.email":"Pour participer à la communauté, vous devez d'abord vérifier votre adresse e-mail. L'e-mail de vérification a été envoyé à {email}. Pour changer votre adresse e-mail, visitez Mes paramètres .","email.verification.message.resend.email":"Pour participer à la communauté, vous devez d'abord vérifier votre adresse e-mail. L'e-mail de vérification a été envoyé à {email}. Renvoyer l'e-mail ."},"localOverride":false},"CachedAsset:text:fr_FR-pages/forums/ForumMessagePage-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-pages/forums/ForumMessagePage-1749759678782","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"Ce message est introuvable","name":"Page de message de Forum","section.message-list.title":"Discussion de forum","archivedMessageTitle":"Ce contenu a été archivé"},"localOverride":false},"CachedAsset:quiltWrapper:videotron.prod:Common:fr-FR-1749759678282":{"__typename":"CachedAsset","id":"quiltWrapper:videotron.prod:Common:fr-FR-1749759678282","value":{"id":"Common_oIbWvI","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"custom.widget.Utility_Nav_FR","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"usePageWidth":true,"backgroundColor":"var(--lia-bs-primary)","useBackground":false,"backgroundOpacity":1,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"community.widget.navbarWidget","props":{"showUserName":false,"showRegisterLink":true,"useIconLanguagePicker":true,"showLanguagePicker":true,"useLabelLanguagePicker":true,"links":{"sideLinks":[],"mainLinks":[{"children":[],"linkType":"INTERNAL","id":"super-utilisateurs-link","params":{"boardId":"SuperUtilisateurs","categoryId":"SuperUtilisateurs"},"routeName":"ForumBoardPage"},{"children":[{"linkType":"INTERNAL","id":"mobile-link","params":{"boardId":"mobile","categoryId":"fr"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"internet-telephonie-link","params":{"boardId":"internet-telephonie","categoryId":"fr"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"television-divertissement-link","params":{"boardId":"television-divertissement","categoryId":"fr"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"mon-videotron-link","params":{"boardId":"mon-videotron","categoryId":"fr"},"routeName":"ForumBoardPage"}],"linkType":"INTERNAL","id":"fr-link","params":{"categoryId":"fr"},"routeName":"CategoryPage"},{"children":[],"linkType":"INTERNAL","id":"le-blogue-link","params":{"boardId":"LeBlogue","categoryId":"fr"},"routeName":"BlogBoardPage"},{"children":[],"linkType":"EXTERNAL","id":"external-link","url":"https://forum.videotron.com/help","target":"SELF"}]},"className":"QuiltComponent_lia-component-edit-mode__0nCcm","style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"400","controllerHighlightColor":"#C14D00","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"14px","linkBoxShadowHover":"none","backgroundOpacity":0.8,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"52px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"5px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"1px solid var(--lia-bs-border-color)","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"flex-start","linkColor":"var(--lia-bs-body-color)","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerHighlightTextColor":"var(--lia-yiq-light)","background":{"imageAssetName":"","color":"var(--lia-bs-white)","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"var(--lia-bs-primary)","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"0","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"5px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-body-color)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-body-color)"},"showSearchIcon":true,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":{"backgroundColor":"#FDD200","visualEffects":{"showBottomBorder":true},"backgroundOpacity":100,"backgroundImageProps":{"assetName":"community-widget-bannerWidget-1733422118937.png","backgroundSize":"COVER","lastModified":"1733422120000","backgroundPosition":"CENTER_CENTER","backgroundRepeat":"NO_REPEAT"},"fontColor":"var(--lia-bs-primary)"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"transparent","linkHighlightColor":"var(--lia-bs-primary)","visualEffects":{"showBottomBorder":true},"linkTextColor":"var(--lia-bs-gray-700)"},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"var(--lia-bs-primary)","items":[{"id":"community.widget.footerWidget","props":null,"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:text:fr_FR-components/common/ActionFeedback-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/common/ActionFeedback-1749759678782","value":{"joinedGroupHub.title":"Bienvenue","joinedGroupHub.message":"Vous êtes maintenant membre de ce groupe et abonné aux mises à jour.","groupHubInviteNotFound.title":"Invitation non trouvée","groupHubInviteNotFound.message":"Désolé, nous n'avons pas trouvé votre invitation au groupe. Le propriétaire a peut-être annulé l'invitation.","groupHubNotFound.title":"Groupe introuvable","groupHubNotFound.message":"Le grouphub que vous avez essayé de rejoindre n'existe pas. Il a peut-être été supprimé.","existingGroupHubMember.title":"Déjà membre","existingGroupHubMember.message":"Vous êtes déjà membre de ce groupe.","accountLocked.title":"Compte verrouillé","accountLocked.message":"Votre compte a été verrouillé en raison de plusieurs tentatives infructueuses. Réessayez dans {lockoutTime} minutes.","editedGroupHub.title":"Modifications enregistrées","editedGroupHub.message":"Votre groupe a été mis à jour.","leftGroupHub.title":"Au revoir","leftGroupHub.message":"Vous n'êtes plus membre de ce groupe et ne recevrez plus de mises à jour à l'avenir.","deletedGroupHub.title":"Supprimé","deletedGroupHub.message":"Le groupe a été supprimé.","groupHubCreated.title":"Groupe créé","groupHubCreated.message":"{groupHubName} est prêt à être utilisé","accountClosed.title":"Compte fermé","accountClosed.message":"Le compte a été fermé et vous serez maintenant redirigé vers la page d'accueil.","resetTokenExpired.title":"Le lien de réinitialisation du mot de passe a expiré","resetTokenExpired.message":"Essayez de réinitialiser votre mot de passe à nouveau","invalidUrl.title":"URL invalide","invalidUrl.message":"L'URL que vous utilisez n'est pas reconnue. Vérifiez votre URL et réessayez.","accountClosedForUser.title":"Compte fermé","accountClosedForUser.message":"Le compte de {userName} est fermé","inviteTokenInvalid.title":"Invitation invalide","inviteTokenInvalid.message":"Votre invitation à la communauté a été annulée ou a expiré.","inviteTokenError.title":"Erreur de vérification de l'invitation","inviteTokenError.message":"L'URL que vous utilisez n'est pas reconnue. Vérifiez votre URL et réessayez.","pageNotFound.title":"Accès refusé","pageNotFound.message":"Vous n'avez pas accès à cette zone de la communauté ou elle n'existe pas","eventAttending.title":"Répondu comme participant","eventAttending.message":"Vous serez notifié en cas d'activité et rappelé à l'approche de l'événement","eventInterested.title":"Répondu comme intéressé","eventInterested.message":"Vous serez notifié en cas d'activité et rappelé à l'approche de l'événement","eventNotFound.title":"Événement introuvable","eventNotFound.message":"L'événement auquel vous avez essayé de répondre n'existe pas.","redirectToRelatedPage.title":"Affichage du Contenu Connexe","redirectToRelatedPageForBaseUsers.title":"Affichage du Contenu Connexe","redirectToRelatedPageForBaseUsers.message":"Le contenu que vous essayez d'accéder est archivé","redirectToRelatedPage.message":"Le contenu que vous essayez d'accéder est archivé","relatedUrl.archivalLink.flyoutMessage":"Le contenu que vous essayez d'accéder est archivé Voir le Contenu Archivé"},"localOverride":false},"CachedAsset:component:custom.widget.Utility_Nav_FR-fr-fr-1749759686875":{"__typename":"CachedAsset","id":"component:custom.widget.Utility_Nav_FR-fr-fr-1749759686875","value":{"component":{"id":"custom.widget.Utility_Nav_FR","template":{"id":"Utility_Nav_FR","markupLanguage":"HTML","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Utility_Nav_FR","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:text:fr_FR-components/community/Breadcrumb-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/Breadcrumb-1749759678782","value":{"navLabel":"Fil d'Ariane","dropdown":"Navigation supplémentaire des parents de la page"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageBanner-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageBanner-1749759678782","value":{"messageMarkedAsSpam":"Ce post a été marqué comme pourriel","messageMarkedAsSpam@board:TKB":"Cet article a été marqué comme pourriel","messageMarkedAsSpam@board:BLOG":"Ce post a été marqué comme pourriel","messageMarkedAsSpam@board:FORUM":"Cette discussion a été marquée comme pourriel","messageMarkedAsSpam@board:OCCASION":"Cet événement a été marqué comme pourriel","messageMarkedAsSpam@board:IDEA":"Cette idée a été marquée comme pourriel","manageSpam":"Gérer le pourriel","messageMarkedAsAbuse":"Ce message a été marqué comme abus","messageMarkedAsAbuse@board:TKB":"Cet article a été marqué comme abus","messageMarkedAsAbuse@board:BLOG":"Ce poste a été marqué comme abus","messageMarkedAsAbuse@board:FORUM":"Cette discussion a été marquée comme abus","messageMarkedAsAbuse@board:OCCASION":"Cet événement a été marqué comme abus","messageMarkedAsAbuse@board:IDEA":"Cette idée a été marquée comme abus","preModCommentAuthorText":"Ce commentaire sera publié dès qu'il aura été approuvé","preModCommentModeratorText":"Ce commentaire est en attente de modération","messageMarkedAsOther":"Ce message a été rejeté pour d'autres raisons","messageMarkedAsOther@board:TKB":"Cet article a été rejeté pour d'autres raisons","messageMarkedAsOther@board:BLOG":"Ce poste a été rejeté pour d'autres raisons","messageMarkedAsOther@board:FORUM":"Cette discussion a été rejetée pour d'autres raisons","messageMarkedAsOther@board:OCCASION":"Cet événement a été rejeté pour d'autres raisons","messageMarkedAsOther@board:IDEA":"Cette idée a été rejetée pour d'autres raisons","messageArchived":"Ce poste a été archivé le {date}","relatedUrl":"Voir le contenu associé","relatedContentText":"Affichage du contenu associé","archivedContentLink":"Voir le contenu archivé"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/RelatedContentWidget-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/RelatedContentWidget-1749759678782","value":{"title":"Contenu connexe","emptyDescription":"Aucun contenu à afficher"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageListForNodeByRecentActivityWidget-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageListForNodeByRecentActivityWidget-1749759678782","value":{"title@userScope:other":"Contenu récent","title@userScope:self":"Contributions","title@board:FORUM@userScope:other":"Discussions récentes","title@board:BLOG@userScope:other":"Blogs récents","emptyDescription":"Pas de contenu à afficher","MessageListForNodeByRecentActivityWidgetEditor.nodeScope.label":"Portée","title@instance:1729793844493":"Recent Blogs"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/FooterWidget-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/FooterWidget-1749759678782","value":{"homeLink":"Accueil de La Communauté","topOfPage":"Haut de page","buildHash":"Hash de Build :","buildNumber":"Numéro de Build :","buildTime":"Date de Build :","privacyPolicy":"Politique de confidentialité","helpLink":"Aide"},"localOverride":false},"Forum:board:mobile":{"__typename":"Forum","id":"board:mobile","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:television-divertissement":{"__typename":"Forum","id":"board:television-divertissement","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"FORUM","displayId":"television-divertissement","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"Télé et Divertissement","shortTitle":"Télé et Divertissement","parent":{"__ref":"Category:category:fr"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yMC0xOTY0aUFDNjI2MTlFMDE2MjE2MEE\"}"},"description":"Une question concernant votre télécommande? Une astuce pour configurer votre terminal? Une suggestion de série à regarder sur illico? Vous trouverez tout ça ici.","eventPath":"category:fr/community:ogevo67675board:television-divertissement/"},"Forum:board:mon-videotron":{"__typename":"Forum","id":"board:mon-videotron","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Blog:board:LeBlogue":{"__typename":"Blog","id":"board:LeBlogue","blogPolicies":{"__typename":"BlogPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Conversation:conversation:47860":{"__typename":"Conversation","id":"conversation:47860","topic":{"__typename":"ForumTopicMessage","uid":47860},"lastPostingActivityTime":"2025-08-15T00:22:04.101-04:00","solved":false},"ForumTopicMessage:message:47860":{"__typename":"ForumTopicMessage","subject":"Télécharger sonnerie téléphone","conversation":{"__ref":"Conversation:conversation:47860"},"id":"message:47860","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/message:47860","revisionNum":1,"uid":47860,"depth":0,"board":{"__ref":"Forum:board:internet-telephonie"},"author":{"__typename":"User","uid":34205,"login":"EudoraEudora","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-12.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":78},"postTime":"2025-01-07T03:05:05.517-05:00","lastPublishTime":"2025-01-07T03:05:05.517-05:00","readOnly":false},"Conversation:conversation:49114":{"__typename":"Conversation","id":"conversation:49114","topic":{"__typename":"ForumTopicMessage","uid":49114},"lastPostingActivityTime":"2025-08-11T17:19:55.759-04:00","solved":true},"ForumTopicMessage:message:49114":{"__typename":"ForumTopicMessage","subject":"Borne Helix avec le voyant orange qui clignote orange","conversation":{"__ref":"Conversation:conversation:49114"},"id":"message:49114","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/message:49114","revisionNum":1,"uid":49114,"depth":0,"board":{"__ref":"Forum:board:internet-telephonie"},"author":{"__typename":"User","uid":35293,"login":"anick2710","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-11.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":108},"postTime":"2025-08-11T16:00:53.328-04:00","lastPublishTime":"2025-08-11T16:00:53.328-04:00","readOnly":false},"Conversation:conversation:49108":{"__typename":"Conversation","id":"conversation:49108","topic":{"__typename":"ForumTopicMessage","uid":49108},"lastPostingActivityTime":"2025-08-08T20:35:01.496-04:00","solved":false},"ForumTopicMessage:message:49108":{"__typename":"ForumTopicMessage","subject":"Aide","conversation":{"__ref":"Conversation:conversation:49108"},"id":"message:49108","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/message:49108","revisionNum":1,"uid":49108,"depth":0,"board":{"__ref":"Forum:board:internet-telephonie"},"author":{"__typename":"User","uid":35286,"login":"Herns-Diomette","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-9.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":32},"postTime":"2025-08-08T18:39:11.864-04:00","lastPublishTime":"2025-08-08T18:39:11.864-04:00","readOnly":false},"Conversation:conversation:47869":{"__typename":"Conversation","id":"conversation:47869","topic":{"__typename":"ForumTopicMessage","uid":47869},"lastPostingActivityTime":"2025-08-08T12:07:58.860-04:00","solved":true},"ForumTopicMessage:message:47869":{"__typename":"ForumTopicMessage","subject":"Garantie de la borne Helix","conversation":{"__ref":"Conversation:conversation:47869"},"id":"message:47869","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/message:47869","revisionNum":2,"uid":47869,"depth":0,"board":{"__ref":"Forum:board:internet-telephonie"},"author":{"__typename":"User","uid":31634,"login":"g225","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-6.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":129},"postTime":"2025-01-08T02:51:46.585-05:00","lastPublishTime":"2025-01-08T02:52:11.550-05:00","readOnly":false},"Conversation:conversation:47635":{"__typename":"Conversation","id":"conversation:47635","topic":{"__typename":"ForumTopicMessage","uid":47635},"lastPostingActivityTime":"2025-08-08T12:06:43.748-04:00","solved":false},"ForumTopicMessage:message:47635":{"__typename":"ForumTopicMessage","subject":"Perte de connexion aléatoire","conversation":{"__ref":"Conversation:conversation:47635"},"id":"message:47635","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/message:47635","revisionNum":1,"uid":47635,"depth":0,"board":{"__ref":"Forum:board:internet-telephonie"},"author":{"__typename":"User","uid":34025,"login":"mrteefo","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-6.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":194},"postTime":"2024-12-05T12:04:10.069-05:00","lastPublishTime":"2024-12-05T12:04:10.069-05:00","readOnly":false},"Rank:rank:19":{"__typename":"Rank","id":"rank:19","position":37,"name":"Initiate","color":null,"icon":null,"rankStyle":"TEXT"},"User:user:33553":{"__typename":"User","id":"user:33553","uid":33553,"login":"martsg","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2024-08-29T23:37:24.987-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-7.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":2,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":1,"entityType":"USER","eventPath":"community:ogevo67675/user:33553"},"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0xOS0xOTYzaTQ5NzlDMEQyRjZBM0E0QUM\"}":{"__typename":"AssociatedImage","url":"https://forum.videotron.com/t5/s/ogevo67675/images/bi0xOS0xOTYzaTQ5NzlDMEQyRjZBM0E0QUM","mimeType":"image/svg+xml"},"ForumTopicMessage:message:46300":{"__typename":"ForumTopicMessage","uid":46300,"subject":"Helix Bridge Mode","id":"message:46300","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/message:46300","revisionNum":1,"repliesCount":3,"author":{"__ref":"User:user:33553"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:internet-telephonie"},"conversation":{"__ref":"Conversation:conversation:46300"},"moderationData":{"__ref":"ModerationData:moderation_data:46300"},"postTime":"2024-08-29T23:35:48.927-04:00","lastPublishTime":"2024-08-29T23:35:48.927-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":2100},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:46300":{"__typename":"Conversation","id":"conversation:46300","solved":true,"topic":{"__ref":"ForumTopicMessage:message:46300"},"lastPostingActivityTime":"2024-11-28T22:25:46.496-05:00","lastPostTime":"2024-11-28T22:25:46.496-05:00","isSubscribed":false},"ModerationData:moderation_data:46300":{"__typename":"ModerationData","id":"moderation_data:46300","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:46300":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:46300","relatedMessage":{"__ref":"ForumTopicMessage:message:46300"}},"Rank:rank:16":{"__typename":"Rank","id":"rank:16","position":34,"name":"Officer","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:32818":{"__typename":"User","id":"user:32818","uid":32818,"login":"GMARTIN","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2024-02-24T12:28:19.826-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-11.svg?time=0"},"rank":{"__ref":"Rank:rank:16"},"messagesCount":12,"kudosGivenCount":6,"kudosReceivedCount":2,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":1,"entityType":"USER","eventPath":"community:ogevo67675/user:32818"},"AssociatedImage:{\"url\":\"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yMC0xOTY0aUFDNjI2MTlFMDE2MjE2MEE\"}":{"__typename":"AssociatedImage","url":"https://forum.videotron.com/t5/s/ogevo67675/images/bi0yMC0xOTY0aUFDNjI2MTlFMDE2MjE2MEE","mimeType":"image/svg+xml"},"ForumTopicMessage:message:45485":{"__typename":"ForumTopicMessage","uid":45485,"subject":"Borne en Helix en Bridge avec la Télévision Helix","id":"message:45485","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:television-divertissement/message:45485","revisionNum":1,"repliesCount":2,"author":{"__ref":"User:user:32818"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:television-divertissement"},"conversation":{"__ref":"Conversation:conversation:45485"},"moderationData":{"__ref":"ModerationData:moderation_data:45485"},"postTime":"2024-06-02T16:42:37.741-04:00","lastPublishTime":"2024-06-02T16:42:37.741-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":2254},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:45485":{"__typename":"Conversation","id":"conversation:45485","solved":true,"topic":{"__ref":"ForumTopicMessage:message:45485"},"lastPostingActivityTime":"2024-06-03T07:08:04.690-04:00","lastPostTime":"2024-06-03T07:08:04.690-04:00","isSubscribed":false},"ModerationData:moderation_data:45485":{"__typename":"ModerationData","id":"moderation_data:45485","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:45485":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:45485","relatedMessage":{"__ref":"ForumTopicMessage:message:45485"}},"User:user:28312":{"__typename":"User","id":"user:28312","uid":28312,"login":"Deesan","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2022-03-11T23:53:16.014-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-4.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":1,"kudosGivenCount":0,"kudosReceivedCount":2,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:28312"},"ForumTopicMessage:message:32446":{"__typename":"ForumTopicMessage","uid":32446,"subject":"Unable to bridge Helix 2","id":"message:32446","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/message:32446","revisionNum":1,"repliesCount":5,"author":{"__ref":"User:user:28312"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:internet-telephonie"},"conversation":{"__ref":"Conversation:conversation:32446"},"moderationData":{"__ref":"ModerationData:moderation_data:32446"},"postTime":"2022-03-11T23:58:24.877-05:00","lastPublishTime":"2022-03-11T23:58:24.877-05:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":11354},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:32446":{"__typename":"Conversation","id":"conversation:32446","solved":true,"topic":{"__ref":"ForumTopicMessage:message:32446"},"lastPostingActivityTime":"2023-09-25T21:47:20.894-04:00","lastPostTime":"2023-09-25T21:47:20.894-04:00","isSubscribed":false},"ModerationData:moderation_data:32446":{"__typename":"ModerationData","id":"moderation_data:32446","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:32446":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:32446","relatedMessage":{"__ref":"ForumTopicMessage:message:32446"}},"User:user:31375":{"__typename":"User","id":"user:31375","uid":31375,"login":"myth0s523","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2023-05-15T15:28:45.085-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-3.svg?time=0"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":4,"kudosGivenCount":1,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:31375"},"ForumTopicMessage:message:41125":{"__typename":"ForumTopicMessage","uid":41125,"subject":"HELIX (mode bridge) et IPv6 sur pfSense","id":"message:41125","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/message:41125","revisionNum":1,"repliesCount":7,"author":{"__ref":"User:user:31375"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:internet-telephonie"},"conversation":{"__ref":"Conversation:conversation:41125"},"moderationData":{"__ref":"ModerationData:moderation_data:41125"},"postTime":"2023-05-15T15:27:32.091-04:00","lastPublishTime":"2023-05-15T15:27:32.091-04:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":6895},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:41125":{"__typename":"Conversation","id":"conversation:41125","solved":true,"topic":{"__ref":"ForumTopicMessage:message:41125"},"lastPostingActivityTime":"2023-05-31T08:24:30.612-04:00","lastPostTime":"2023-05-31T08:24:30.612-04:00","isSubscribed":false},"ModerationData:moderation_data:41125":{"__typename":"ModerationData","id":"moderation_data:41125","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:41125":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:41125","relatedMessage":{"__ref":"ForumTopicMessage:message:41125"}},"User:user:30942":{"__typename":"User","id":"user:30942","uid":30942,"login":"MariusMontreal","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2023-02-14T16:27:01.981-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-5.svg?time=0"},"rank":{"__ref":"Rank:rank:16"},"messagesCount":3,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ogevo67675/user:30942"},"ForumTopicMessage:message:39885":{"__typename":"ForumTopicMessage","uid":39885,"subject":"Helix en mode Bridge et PPPoe","id":"message:39885","entityType":"FORUM_TOPIC","eventPath":"category:fr/community:ogevo67675board:internet-telephonie/message:39885","revisionNum":1,"repliesCount":2,"author":{"__ref":"User:user:30942"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:internet-telephonie"},"conversation":{"__ref":"Conversation:conversation:39885"},"moderationData":{"__ref":"ModerationData:moderation_data:39885"},"postTime":"2023-02-14T16:30:25.909-05:00","lastPublishTime":"2023-02-14T16:30:25.909-05:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":3358},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"isEscalated":null},"Conversation:conversation:39885":{"__typename":"Conversation","id":"conversation:39885","solved":true,"topic":{"__ref":"ForumTopicMessage:message:39885"},"lastPostingActivityTime":"2023-02-15T16:02:00.508-05:00","lastPostTime":"2023-02-15T16:02:00.508-05:00","isSubscribed":false},"ModerationData:moderation_data:39885":{"__typename":"ModerationData","id":"moderation_data:39885","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:39885":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:39885","relatedMessage":{"__ref":"ForumTopicMessage:message:39885"}},"CachedAsset:text:fr_FR-components/community/Navbar-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/Navbar-1749759678782","value":{"community":"Accueil de la communauté","inbox":"Boîte de réception","manageContent":"Gérer le contenu","tos":"Conditions d'utilisation","forgotPassword":"Mot de passe oublié","themeEditor":"Éditeur de thème","edit":"Modifier la barre de navigation","skipContent":"Passer au contenu","mon-videotron-link":"Mon Vidéotron","le-blogue-link":"Blogue","mobile-link":"Mobilité","super-utilisateurs-link":"Super Utilisateurs","mobilephone-english-link":"Mobility","television-divertissement-link":"Télé et Divertissement","en-link":"Forum","t-v-entertainement-link":"TV & Entertainment","fr-link":"Forum","the-blog-link":"Blog","internet-telephony-link":"Internet & Telephony","blog-link":"Blog","my-videotron-link":"My Videotron","internet-telephonie-link":"Internet et Téléphonie","forum-television-entertainment-link":"TV & Entertainment","forum-mobility-link":"Mobility","external-link":"Aide","forum-internet-telephony-link":"Internet & Telephony","forum-news-link":"My Videotron"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/NavbarHamburgerDropdown-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/NavbarHamburgerDropdown-1749759678782","value":{"hamburgerLabel":"Menu Latéral"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/BrandLogo-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/BrandLogo-1749759678782","value":{"logoAlt":"Khoros","themeLogoAlt":"Logo de la marque"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/NavbarTextLinks-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/NavbarTextLinks-1749759678782","value":{"more":"Plus"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/languages/UseLanguageText-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/languages/UseLanguageText-1749759678782","value":{"language.browserLanguage.label":"Par défaut du navigateur","language.ar-AE.label":"Arabe","language.bg-BG.label":"Bulgare","language.ca-AD.label":"Catalan","language.cs-CZ.label":"Tchèque","language.da-DK.label":"Danois","language.de-DE.label":"Allemand","language.el-GR.label":"Grec","language.en-GB.label":"Anglais (Royaume-Uni)","language.en-US.label":"Anglais (États-Unis)","language.es-ES.label":"Espagnol","language.es-MX.label":"Espagnol (Amérique latine)","language.et-EE.label":"Estonien","language.fa-IR.label":"Persan (Farsi)","language.fi-FI.label":"Finnois","language.fr-FR.label":"Français","language.he-IL.label":"Hébreu","language.hr-HR.label":"Croate","language.hu-HU.label":"Hongrois","language.in-ID.label":"Indonésien","language.it-IT.label":"Italien","language.ja-JP.label":"Japonais","language.ko-KR.label":"Coréen","language.lt-LT.label":"Lituanien","language.lv-LV.label":"Letton","language.ms-MY.label":"Malais","language.nl-NL.label":"Néerlandais","language.no-NO.label":"Norvégien","language.pl-PL.label":"Polonais","language.pt-BR.label":"Portugais (Brésilien)","language.pt-PT.label":"Portugais","language.ro-RO.label":"Roumain","language.ru-RU.label":"Russe","language.sk-SK.label":"Slovaque","language.sq-AL.label":"Albanais","language.sv-SE.label":"Suédois","language.th-TH.label":"Thaï","language.tr-TR.label":"Turc","language.uk-UA.label":"Ukrainien","language.vi-VN.label":"Vietnamien","language.zh-CN.label":"Chinois (simplifié)","language.zh-TW.label":"Chinois (traditionnel)","timezone.fieldLabel.label":"Fuseau horaire","timezone.delimiter.label":"------------------------------","timezone.Etc-GMT+12.label":"GMT -12:00 Dateline","timezone.Pacific-Samoa.label":"GMT -11:00 Samoa","timezone.US-Hawaii.label":"GMT -10:00 Heure hawaïenne des États-Unis","timezone.US-Aleutian.label":"GMT -10:00 Îles Aléoutiennes","timezone.Pacific-Marquesas.label":"GMT -09:30 Marquises","timezone.Pacific-Gambier.label":"GMT -09:00 Îles Gambier","timezone.US-Alaska.label":"GMT -09:00 Heure de l'Alaska, États-Unis","timezone.US-Pacific.label":"GMT -08:00 Heure du Pacifique, États-Unis","timezone.Pacific-Pitcairn.label":"GMT -08:00 Îles Pitcairn","timezone.US-Mountain.label":"GMT -07:00 Heure des montagnes, États-Unis","timezone.US-Arizona.label":"GMT -07:00 Heure des montagnes, États-Unis (Arizona)","timezone.US-Central.label":"GMT -06:00 Heure centrale, États-Unis","timezone.Mexico-General.label":"GMT -06:00 Mexique","timezone.America-Costa_Rica.label":"GMT -06:00 Costa Rica","timezone.US-Eastern.label":"GMT -05:00 Heure de l'Est, États-Unis","timezone.America-Bogota.label":"GMT -05:00 Colombie, Pérou, Amérique du Sud","timezone.Canada-Atlantic.label":"GMT -04:00 Heure de l'Atlantique","timezone.America-Puerto_Rico.label":"GMT -04:00 Porto Rico","timezone.Canada-Newfoundland.label":"GMT -03:30 Terre-Neuve, Canada","timezone.America-Buenos_Aires.label":"GMT -03:00 Argentine","timezone.Brazil-East.label":"GMT -03:00 Brésil","timezone.Atlantic-South_Georgia.label":"GMT -02:00 Atlantique central","timezone.Atlantic-Cape_Verde.label":"GMT -01:00 Cap Vert","timezone.Atlantic-Azores.label":"GMT -01:00 Açores","timezone.Europe-London.label":"GMT ------ Royaume-Uni","timezone.Iceland.label":"GMT ------ Islande","timezone.Europe-Madrid.label":"GMT +01:00 Espagne","timezone.Africa-Algiers.label":"GMT +01:00 Alger, Afrique","timezone.Europe-Amsterdam.label":"GMT +01:00 Europe centrale","timezone.Europe-Athens.label":"GMT +02:00 Europe de l'Est","timezone.Africa-Tripoli.label":"GMT +02:00 Tripoli, Afrique","timezone.Egypt.label":"GMT +02:00 Égypte","timezone.Israel.label":"GMT +02:00 Israël","timezone.Asia-Riyadh.label":"GMT +03:00 Arabie Saoudite","timezone.Iran.label":"GMT +03:30 Iran","timezone.Europe-Moscow.label":"GMT +03:00 Russie","timezone.Europe-Samara.label":"GMT +04:00 Samara, Europe","timezone.Asia-Dubai.label":"GMT +04:00 Arabie","timezone.Asia-Kabul.label":"GMT +04:30 Afghanistan","timezone.Asia-Karachi.label":"GMT +05:00 Pakistan, Asie de l'Ouest","timezone.Asia-Yekaterinburg.label":"GMT +05:00 Yekaterinbourg, Asie","timezone.Asia-Calcutta.label":"GMT +05:30 Inde","timezone.Asia-Thimphu.label":"GMT +06:00 Bangladesh, Asie centrale","timezone.Asia-Novosibirsk.label":"GMT +06:00 Novossibirsk, Asie","timezone.Asia-Rangoon.label":"GMT +06:30 Birmanie","timezone.Asia-Bangkok.label":"GMT +07:00 Bangkok, Hanoï, Jakarta","timezone.Asia-Krasnoyarsk.label":"GMT +07:00 Krasnoïarsk, Asie","timezone.PRC.label":"GMT +08:00 Chine","timezone.Singapore.label":"GMT +08:00 Singapour","timezone.Asia-Taipei.label":"GMT +08:00 Taïwan","timezone.Australia-West.label":"GMT +08:00 Australie (WT)","timezone.Asia-Irkutsk.label":"GMT +08:00 Irkoutsk, Asie","timezone.Japan.label":"GMT +09:00 Japon","timezone.Asia-Seoul.label":"GMT +09:00 Corée","timezone.Asia-Yakutsk.label":"GMT +09:00 Iakoutsk, Russie","timezone.Australia-North.label":"GMT +09:30 Australie (NT)","timezone.Australia-Adelaide.label":"GMT +09:30 Australie (ST)","timezone.Australia-Sydney.label":"GMT +10:00 Australie (ET)","timezone.Australia-Queensland.label":"GMT +10:00 Australie (Queensland)","timezone.Asia-Magadan.label":"GMT +10:00 Magadan, Asie","timezone.Australia-Lord_Howe.label":"GMT +10:30 Australie (Lord Howe)","timezone.Pacific-Guadalcanal.label":"GMT +11:00 Pacifique central","timezone.Pacific-Norfolk.label":"GMT +11:30 Îles Norfolk","timezone.Pacific-Auckland.label":"GMT +12:00 Nouvelle-Zélande","timezone.Pacific-Fiji.label":"GMT +12:00 Fidji","timezone.Antarctica-South_Pole.label":"GMT +12:00 Pôle Sud, Antarctique","UseLanguageText.language.en-US.label":"Anglais","UseLanguageText.language.fr-FR.label":"Français"},"localOverride":false},"CachedAsset:text:fr_FR-components/languages/LanguagePicker-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/languages/LanguagePicker-1749759678782","value":{"dropdown.title":"Sélecteur de langue","selected.language":"Langue sélectionnée actuellement","toast.successMessage":"Aller à la communauté {newLanguage}Revenir à {oldLanguage}","toast.successTitle":"Langue changée en {language}","toast.failureTitle":"Erreur - Action échouée","toast.failureMessage":"Un problème non identifié s'est produit lors de l'action que vous avez entreprise. Veuillez réessayer plus tard."},"localOverride":false},"CachedAsset:text:fr_FR-components/search/SpotlightSearchIcon-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/search/SpotlightSearchIcon-1749759678782","value":{"search":"Rechercher"},"localOverride":false},"CachedAsset:text:fr_FR-components/authentication/AuthenticationLink-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/authentication/AuthenticationLink-1749759678782","value":{"title.login":"Connexion","title.registration":"S'inscrire","title.forgotPassword":"Mot de passe oublié","title.multiAuthLogin":"Connexion"},"localOverride":false},"CachedAsset:text:fr_FR-components/nodes/NodeLink-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/nodes/NodeLink-1749759678782","value":{"place":"Lieu {name}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageView/MessageViewStandard-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageView/MessageViewStandard-1749759678782","value":{"anonymous":"Anonyme","author":"{messageAuthorLogin}","authorBy":"{messageAuthorLogin}","board":"{messageBoardTitle}","replyToUser":" à {parentAuthor}","showMoreReplies":"Afficher plus","replyText":"Répondre","repliesText":"Réponses","markedAsSolved":"Marqué comme Solution","messageStatus":"Statut : ","statusChanged":"Statut modifié : {previousStatus} en {currentStatus}","statusAdded":"Statut ajouté : {status}","statusRemoved":"Statut supprimé : {status}","labelExpand":"développer les réponses","labelCollapse":"réduire les réponses","unhelpfulReason.reason1":"Le contenu est obsolète","unhelpfulReason.reason2":"L'article manque d'informations","unhelpfulReason.reason3":"Le contenu concerne un produit différent","unhelpfulReason.reason4":"Ne correspond pas à ce que je cherchais"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageDeepLink-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageDeepLink-1749759678782","value":{"viewFullDiscussion@board:FORUM":"Voir la discussion complète ({repliesCount} Réponses)","viewFullDiscussion@board:BLOG":"Voir la discussion complète ({repliesCount} Commentaires)","viewFullDiscussion@board:TKB":"Voir la discussion complète ({repliesCount} Commentaires)","viewFullDiscussion@board:IDEA":"Voir la discussion complète ({repliesCount} Commentaires)","viewFullDiscussion@board:OCCASION":"Voir la discussion complète ({repliesCount} Commentaires)","showParents@board:FORUM":"Afficher les réponses parentes","showParents@board:BLOG":"Afficher les commentaires parentaux","showParents@board:TKB":"Afficher les commentaires parentaux","showParents@board:IDEA":"Afficher les commentaires parentaux","showParents@board:OCCASION":"Afficher les commentaires parentaux"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageReplyCallToAction-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageReplyCallToAction-1749759678782","value":{"leaveReply":"Laisser une réponse...","leaveReply@board:BLOG@message:root":"Laisser un commentaire...","leaveReply@board:TKB@message:root":"Laisser un commentaire...","leaveReply@board:IDEA@message:root":"Laisser un commentaire...","leaveReply@board:OCCASION@message:root":"Laisser un commentaire...","repliesTurnedOff.FORUM":"Les réponses sont désactivées pour ce sujet","repliesTurnedOff.BLOG":"Les commentaires sont désactivés pour ce sujet","repliesTurnedOff.TKB":"Les commentaires sont désactivés pour ce sujet","repliesTurnedOff.IDEA":"Les commentaires sont désactivés pour ce sujet","repliesTurnedOff.OCCASION":"Les commentaires sont désactivés pour ce sujet","infoText":"Arrêter de me piquer!"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/common/QueryHandler-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/common/QueryHandler-1749759678782","value":{"title":"Gestionnaire de requêtes"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/common/BuildInformation-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/common/BuildInformation-1749759678782","value":{"buildHash":"Build Hash : {buildHash}","buildNumber":"Numéro de build : {buildNumber}","buildTime":"Date de build : {buildTime}"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/KhorosLogo-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/KhorosLogo-1749759678782","value":{"alt":"Propulsé par Khoros"},"localOverride":false},"Category:category:en":{"__typename":"Category","id":"category:en","displayId":"en"},"CachedAsset:text:fr_FR-components/customComponent/CustomComponent-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/customComponent/CustomComponent-1749759678782","value":{"errorMessage":"Erreur lors du rendu de l'ID du composant : {customComponentId}","bannerTitle":"Le fournisseur de vidéos nécessite des cookies pour lire la vidéo. Acceptez pour continuer ou {url} directement sur le site du fournisseur.","buttonTitle":"Accepter","urlText":"regarder"},"localOverride":false},"CachedAsset:text:fr_FR-components/community/NavbarDropdownToggle-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/community/NavbarDropdownToggle-1749759678782","value":{"ariaLabelClosed":"Appuyez sur la flèche vers le bas pour ouvrir le menu"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/EscalatedMessageBanner-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/EscalatedMessageBanner-1749759678782","value":{"escalationMessage":"Escalation vers Salesforce par {username} le {date}","viewDetails":"Voir les détails","modalTitle":"Détails de l'affaire","escalatedBy":"Escaladé par :","escalatedOn":"Escaladé le :","caseNumber":"Numéro d'affaire :","status":"Statut :","lastUpdateDate":"Dernière mise à jour :","automaticEscalation":"escalade automatique","anonymous":"Anonyme"},"localOverride":false},"CachedAsset:text:fr_FR-components/users/UserLink-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/users/UserLink-1749759678782","value":{"authorName":"Voir le profil : {author}","anonymous":"Anonyme"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/users/UserRank-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/users/UserRank-1749759678782","value":{"rankName":"{rankName}","userRank":"Rang d'auteur {rankName}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageTime-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageTime-1749759678782","value":{"postTime":"Publié : {time}","lastPublishTime":"Dernière mise à jour : {time}","conversation.lastPostingActivityTime":"Heure de la dernière activité de publication : {time}","conversation.lastPostTime":"Heure du dernier poste : {time}","moderationData.rejectTime":"Heure de rejet : {time}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageSolvedBadge-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageSolvedBadge-1749759678782","value":{"solved":"Résolu"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageSubject-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageSubject-1749759678782","value":{"noSubject":"(sans objet)"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageBody-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageBody-1749759678782","value":{"showMessageBody":"Afficher plus","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} n'est plus disponible","mentionsErrorMessage":"Le {mentionsType} que vous essayez de consulter a été supprimé de la communauté.","videoProcessing":"La vidéo est en cours de traitement. Veuillez réessayer dans quelques minutes.","bannerTitle":"Le fournisseur de vidéos nécessite des cookies pour lire la vidéo. Acceptez pour continuer ou {url} la regarder directement sur le site du fournisseur.","buttonTitle":"Accepter","urlText":"visionner"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageCustomFields-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageCustomFields-1749759678782","value":{"CustomField.default.label":"Valeur de {name}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageReplyButton-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageReplyButton-1749759678782","value":{"repliesCount":"{count}","title":"Répondre","title@board:BLOG@message:root":"Commentaire","title@board:TKB@message:root":"Commentaire","title@board:IDEA@message:root":"Commentaire","title@board:OCCASION@message:root":"Commentaire"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/MessageView/MessageViewInline-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/MessageView/MessageViewInline-1749759678782","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonyme","place":"Endroit {bylineBoard}","gotoParent":"Aller au parent {name}"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/common/Pager/PagerLoadMore-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/common/Pager/PagerLoadMore-1749759678782","value":{"loadMore":"Afficher plus"},"localOverride":false},"Rank:rank:18":{"__typename":"Rank","id":"rank:18","position":36,"name":"Squire","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:33202":{"__typename":"User","id":"user:33202","uid":33202,"login":"markrobert","deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://forum.videotron.com/t5/s/ogevo67675/m_assets/avatars/default/avatar-9.svg?time=0"},"rank":{"__ref":"Rank:rank:18"},"email":"","messagesCount":4,"biography":null,"topicsCount":0,"kudosReceivedCount":0,"kudosGivenCount":0,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2024-06-12T23:44:52.035-04:00","confirmEmailStatus":null},"followersCount":null,"solutionsCount":1},"ModerationData:moderation_data:45554":{"__typename":"ModerationData","id":"moderation_data:45554","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:45554_1":{"__typename":"Revision","id":"revision:45554_1","lastEditTime":"2024-06-12T23:57:52.312-04:00"},"QueryVariables:ReplyList:message:45554:1":{"__typename":"QueryVariables","id":"ReplyList:message:45554:1","value":{"id":"message:45554","first":10,"sorts":{"kudosSumWeight":{"direction":"DESC","order":0},"postTime":{"direction":"ASC","order":1}},"repliesFirst":3,"repliesFirstDepthThree":1,"repliesSorts":{"kudosSumWeight":{"direction":"DESC","order":0},"postTime":{"direction":"ASC","order":1}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":true,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":false,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:text:fr_FR-shared/client/components/users/UserAvatar-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/users/UserAvatar-1749759678782","value":{"altText":"Avatar de {login}","altTextGeneric":"Avatar de l'utilisateur"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/ranks/UserRankLabel-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/ranks/UserRankLabel-1749759678782","value":{"altTitle":"Icône pour le rang {rankName}"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/AcceptedSolutionButton-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/AcceptedSolutionButton-1749759678782","value":{"accept":"Marquer comme résolu","accepted":"Marqué comme résolu","errorHeader":"Erreur !","errorAdd":"Une erreur est survenue en marquant comme résolu.","errorRemove":"Une erreur est survenue en révoquant le marquage comme résolu.","solved":"Résolu","topicAlreadySolvedErrorTitle":"La solution existe déjà","topicAlreadySolvedErrorDesc":"Rafraîchissez le navigateur pour voir la solution existante"},"localOverride":false},"CachedAsset:text:fr_FR-components/messages/ThreadedReplyList-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-components/messages/ThreadedReplyList-1749759678782","value":{"title":"{count, plural, one{# Réponse} other{# Réponses}}","title@board:BLOG":"{count, plural, one{# Commentaire} other{# Commentaires}}","title@board:TKB":"{count, plural, one{# Commentaire} other{# Commentaires}}","title@board:IDEA":"{count, plural, one{# Commentaire} other{# Commentaires}}","title@board:OCCASION":"{count, plural, one{# Commentaire} other{# Commentaires}}","noRepliesTitle":"Pas de Réponses","noRepliesTitle@board:BLOG":"Aucun Commentaire","noRepliesTitle@board:TKB":"Aucun Commentaire","noRepliesTitle@board:IDEA":"Aucun Commentaire","noRepliesTitle@board:OCCASION":"Aucun Commentaire","noRepliesDescription":"Soyez le premier à répondre","noRepliesDescription@board:BLOG":"Soyez le premier à commenter","noRepliesDescription@board:TKB":"Soyez le premier à commenter","noRepliesDescription@board:IDEA":"Soyez le premier à commenter","noRepliesDescription@board:OCCASION":"Soyez le premier à commenter","messageReadOnlyAlert:BLOG":"Les commentaires ont été désactivés pour ce poste","messageReadOnlyAlert:TKB":"Les commentaires ont été désactivés pour cet article","messageReadOnlyAlert:IDEA":"Les commentaires ont été désactivés pour cette idée","messageReadOnlyAlert:FORUM":"Les réponses ont été désactivées pour cette discussion","messageReadOnlyAlert:OCCASION":"Les commentaires ont été désactivés pour cet événement"},"localOverride":false},"CachedAsset:text:fr_FR-shared/client/components/nodes/NodeIcon-1749759678782":{"__typename":"CachedAsset","id":"text:fr_FR-shared/client/components/nodes/NodeIcon-1749759678782","value":{"contentType":"Type de contenu {style, select, FORUM {Forum} BLOG {Blog} TKB {Base de connaissances} IDEA {Idées} OCCASION {Événements} other {}} icône"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"boardId":"internet-telephonie","messageSubject":"solution-pour-helix-wifi-actif-meme-en-bridge-mode","messageId":"36635","replyId":"45554"},"buildId":"3XH0qYWYCnEYycuN5W4S8","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","surveysEnabled":true,"openTelemetry":{"clientEnabled":false,"configName":"videotron","serviceVersion":"25.4.0","universe":"prod","collector":"http://localhost:4318","logLevel":"error","routeChangeAllowedTime":"5000","headers":"","enableDiagnostic":"false","maxAttributeValueLength":"4095"},"apolloDevToolsEnabled":false,"quiltLazyLoadThreshold":"3"},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["components_seo_QAPageSchema","components_customComponent_CustomComponent","components_community_Navbar_NavbarWidget","components_community_Breadcrumb_BreadcrumbWidget","components_messages_TopicWithThreadedReplyListWidget","components_messages_RelatedContentWidget","components_messages_MessageListForNodeByRecentActivityWidget","components_community_FooterWidget","components_languages_LanguagePicker","components_messages_MessageView_MessageViewStandard","components_community_FooterWidgetHelpLink","components_community_KhorosLogo","components_customComponent_CustomComponentContent_HtmlContent","components_messages_EscalatedMessageBanner","shared_client_components_common_List_UnstyledList","components_messages_MessageView","components_messages_MessageView_MessageViewInline","shared_client_components_common_List_ListGroup","shared_client_components_common_Pager_PagerLoadMore","components_customComponent_CustomComponentContent_CustomComponentScripts"],"appGip":true,"scriptLoader":[]}
