Noneedfor
17-03-2021Initiate
Helix Fi 2 and Xbox Series X ethernet problems
new Helix Fi 2 router with 4 ethernet ports: 1 port to pc 1 port to Deco mesh unit 1 port to simple switch w 8 ports 1 port to Xbox Series X the Xbox CAN get Helix wifi connection (300 MBP...
- 21-03-2021
Hi Noneedfor. If you cannot make your Xbox work with one of the ethernet ports of the gateway, we strongly suggest you reach our technical support over here: http://bit.ly/FB_Contact_Us.
Thank you!
Grendizer
17-03-2021Admiral
Helix has only 2 Ethernet ports I think. The series X is the AC protocol, so using Wifi you should be higher.
Did uPnP is on? Port forwarding is not really needed when it's on
Noneedfor
17-03-2021Initiate
the new Helix Fi 2 does have 4 ports:
https://videotron.com/soutien/helix/equipements/borne-helix-fi
I will cehck uPnP when back home...merci
