p4bl03000
19-12-2020Initiate
Helix ethernet not working with D-Link ethernet switch
After setting up my Helix gateway I discovered that the ethernet is not working if I use my D-Link ethernet switch to add more ports. The wifi works, and the ethernet works if I don't use the switch....
Anonymous35
15-11-2022Initiate
my cable modem is a tm822G. can I install a switch to it with multiple clients so that all have public IP addresses? I noted that Videotron's DHCP puts me on a /24 subnet which means 14 IPs should be available. however, with a 2 client test network, I can only get 1 client to work at a time. separately, each client connects with different IP addresses on the /24 subnet. more to the point, does Videotron limit me to 1 active public IP address on the /24 subnet?
