Noneedfor's avatar
Noneedfor
5 years ago
Solved
Helix Fi 2 and Xbox Series X ethernet problems
new Helix Fi 2 router with 4 ethernet ports:   1 port to pc 1 port to Deco mesh unit 1 port to simple switch w 8 ports 1 port to Xbox Series X   the Xbox CAN get Helix wifi connection (300 MBP...
  • CedrikS's avatar
    5 years ago
    Hi Noneedfor. If you cannot make your Xbox work with one of the ethernet ports of the gateway, we strongly suggest you reach our technical support over here: http://bit.ly/FB_Contact_Us.
    Thank you!
